Results 1 to 43 of 43
Thread: mtn bike grease
    ninja
    Reputation: nighlwing's Avatar
    mtn bike grease
    I am relatively new to bike maintenance and was wondering if you guys could recommend a type or types of grease for every thing. like bottom bracket, general purpose, chain and a good place to buy it from would be great to.
    erm..I think Park Tools has chainlube and grease for everything. There are likely dozens of other vendors for lube and grease just so you know. As for where to get em, your LBS or my go-to place...Amazon.com.
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    My recs...
    Grease - Molybdenum (Moly) Grease - big tub
    Oil - Bar/chain (saw) oil - Gallon
    Spray (for derailleurs, stanchions etc) - Silicone spray (~20oz.)
    Where to get - any hardware/home builders supply store.
    Buying any "bike specific" stuff is just silly/stupid - unless you like wasting $$
    Honestly... ahh I give up
    Reputation: Fix the Spade's Avatar
    Don't put grease on your chain, it just picks up crap and wears the chain even faster.
    Buy a bottle of specific chain lube for your chain/gears. For everything else except forks a decent teflon grease works fine, apply sparingly.
    I've always used Finish line Dry chain lube :http://www.chainreactioncycles.com/M...px?ModelID=317
    and grease http://www.chainreactioncycles.com/M...px?ModelID=980
    I use those because my LBS carries it, they use it and it's always worked fine for me.
    You can get them or something similar from all decent bike shops, just go in and ask for a decent grease and a bottle of chain lube. Or get it off a website.
    #Edit, or take Highdell's suggestion and get a gallon of it for the price a bike shop will charge you for 3oz.
    the ease of use of prolink makes it worth every penny to me.
    im sticking with my big tub of marine grease for everything else though.
    ninja
    thx guys
    Reputation: BurnNotice's Avatar
    I love the Tri-Flow red grease.
    Aug 2005
    Phil Wood waterproof grease is the best!
    2016 Santa Cruz Hightower 29er
    2016 Chromag Surface 27.5+
    2013 Transition TransAM 29er
    2017 Motobecane Lurch FS 26 fat
    Crainius Maximus
    Rock-N-Roll Super Slick grease for fork/shock rebuilds
    Rock-N-Roll Super Web grease for bearings
    Pedro's Ice Wax or similar dry chain lube...I gave up on wet chain lubes!
    Reputation: mikerod87's Avatar
    I used Marine Grease on my I drive and it has been awesome. Use triflow on the chain.
    Anyone make their own chain lube?
    I have heard chain saw barr oil and canola oil make a nice lube? Is it 50/50?
    Huh?
    Reputation: airs0ft3r's Avatar
    Bacon
    In a more serious note, never use WD-40. It wasn't anything you said or anything, no one has recommended it, but better you know just in case.
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    Pretty much any grease will work. For the most part, grease is grease. But don't use it on your chain.
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
    Synthetics will be safer for o-rings and rubber parts when necessary. I also use regular store brand lubes and stuff.
    Reputation: BaeckerX1's Avatar
    Oct 2007
    I hear KY works awesome.
    Gotta get up to get down.
    LMB
    fuggansonofahowa
    Reputation: Hawseman's Avatar
    Quote Originally Posted by BaeckerX1
    The wife, her friend and I agree, KY does work awesome.....
    BOT: I used Phil's Waterproof for most general purpose applications....'cept on shocks & forks. Also, I use Rock n' Roll Super Web Grease on partial-rotating bearings like headsets and pivot bearings. This messy stuff doesn't tend to pack up to one side like others do.
    Call me "old school", and I've tried quite a few, but I always end up applying the Cross Country Wet Lube to my chain (Mobile 1 in winter). I will give ChainL a try one of these days.....but CCWL just works well for the mixed conditions I generally ride in.
    Why is WD-40 so bad?
    I use Castrol LG greased for any bearings, BB etc.
    Is it common to use Chail saw oil for the chain? I've never considered it before but it seems logical as surely its designed to reduce wear on the chainsaw blade? Its 'stickiness' may be a problem as its being constantly applied in a chain saw.
    Come see me after class
    Dec 2005
    WD40 is a degreaser
    Dec 2005
    marine grease and silicone spray. done.
    Underskilled
    Reputation: CaveGiant's Avatar
    I heard about the chainsaw oil thing here a few months back.
    It is discusting stuff, but made chain maintainence so easy.
    I have a pair of plastic gloves and two rags next to my bike.
    One rag is full of oil, the second is occasionally cleaned and is used to wipe off excess.
    Takes 20s every week, but worth it.
    Why would I care about 150g of bike weight, I just ate 400g of cookies while reading this?
    Underskilled
    The best grease I have tried is finishline ceramic.
    Expensive but is the most weather resistant grease I have found (I have not tried phill wodds).
    Reputation: string's Avatar
    I 3rd the marine grease. I use Lithium marine grease and have for years. (it is cheaper than bike specific and works better in wet conditions (and as good in dry))
    Reputation: Gman086's Avatar
    Quote Originally Posted by Hawseman
    Ditto - super web grease doesn't migrate out like marine grease/Phil's and stays on the bearings but doesn't roll as well so perfect for headsets and pivots. Hub bearings get Phil's but may try RWC's grease for lower resistance. My chains will never see anything other than Rock & Roll.
    Great tip on the silicone spray for the ders Highdelll! I had always used Tri-flow but that attracts dirt.
    Ring gear - Chris King's proprietary ring gear lube for those; good luck finding anything remotely close to that at a marine/hardware store!
    Have FUN!
    G MAN
    "There's two shuttles, one to the top and one to the hospital" I LOVE this place!!!
    ~Disc~Golf~
    Quote Originally Posted by twilk
    as alexrex20 said - it's a degreaser - it contains mostly solvent - what oil it does have is too light for any chain lube - it's great for cleaning lube out.
    Bar-oil - yeah, the 'stickiness' might seem like a problem, but in reality, it doesn't really collect all that much - especially if you wipe down the chain (and compared to many other oils)
    take this pic for example - there seems to be more dust attracted to the 'dry' parts than the chain.
    Pretty good overall for fine volcanic ash I'd say.
    Justa Dude
    Reputation: khcaver's Avatar
    More on WD-40
    I was told during a locksmithing seminar not to use WD-40 on lock parts as a lubricant because of its tendency to remove any plating that are on many internal parts to a lock. I have witnessed this firsthand to be true. What seems to happen is that nickel plated parts are the most affected. The plating seems to peel off and eventually turn to goo that gums up everything that comes in contact with it. On a side note it works fantastically as a water displacement product. (WD = Water Displacement 40 = the 40th concoction that was produced.)
    Quote Originally Posted by highdelll
    My recs...
    +1
    I confess to liking one bike-specific chain lube (Rock N Road) but have used Lubriplate grease for decades and a pump from industrial supply for a fraction of bike branded stuff. Lubriplate was suggested for Campy at one point and I knew it from maintaining expensive industrial equipment.
    I4NI
    Reputation: S_Trek's Avatar
    May 2010
    Amsoil racing grease! Good for an extra .10 or 2
    There....Are... Four...Lights!
    Mar 2005
    Quote Originally Posted by Gman086
    G MAN
    The King grease is a NLGI #1 grease. Standard greases are NLGI #2. The lower the number the thinner the grease. You can purchase and NLGI #1 bearing grease from your local industrial supply store for the same price as 'regular' grease. It is not like Chris King or Phil Wood or any of these other bike lube companies actually makes their own stuff. They purchase it from a petro-chemical company and sell it to you for more.
    Quote Originally Posted by myarmisonfire
    NOT - it's a proprietary fluorinated grease that they had a grease manufacturer make to their specs. You peeps apparently have no clue what toll manufacturing is all about??? Just because King isn't a grease company doesn't mean they can't have one developed for them that improves their product for a specific application. Aks BRP engineers at SkiDoo how their oil stacks up to the competitors for sleds - they have Castrol make it but to their specs and good luck finding it elsewhere, even at Castrol who cannot release any info about it (they have a secrecy agreement). School is OUT!
    Have FUN!
    G MAN
    Reputation: Broccoli's Avatar
    While standard grease by the gallon will certainly work - I do not find that buying a tube of Phil Wood or a bottle of good chain lube is a noticable expense compared to everything else.
    I find that some brands work better for me - last longer, attract less dirt. Spending a few extra $ for that does not seem like a big deal.
    Singletrack Slayer
    Reputation: DavidNeiles's Avatar
    I prefer to use Finish Line teflon grease for installs, HS, BB threads, Open BB's axles, etc, Good water-proof seal, Also love Phil Wood.
    Rock N Roll(blue) for chain, works the best out of anything else I've tried, even chainsaw lube or 3 in 1 oil, like some mention.
    Like Finish Line green bottle of syn lube for spoke nipples on Mavic CMxs, cables, as it works great for keep the $hit out.
    I use 3n1 for my mavic freehub body though..or Road Rage from Pedro's
    I use a teflon spray lube to clean out derailleur parts and usually use a water/rubbing alcohol to clean casette and parts and citrus degreaser for the real dirty crap with a brush
    ~~~~~~Singletrack Slayer~~~~~~~
    Give it a crank
    Reputation: Mtn-Rider's Avatar
    May 2010
    I used Slickoleum to relube my XCR fork and it rides like a totally new fork now. I also prefer Slickoleum on the stanchions over oil because it collects all the dirt for easy wiping off after a ride. Works nice on cables too.
    7.99 at yer local Auto Zone
    http://www.greengrease.net/PDF/GreenGease.pdf
    "Suitable for bearings, seals, o-rings, bushings and open gears."
    rebmem rbtm
    Reputation: Instigator's Avatar
    valvoline synlube, its amazing for bb's and hubs.
    ~Disc~Golf~
    Quote Originally Posted by Mtn-Rider
    ^I've never heard of it and for good reason upon looking it up it is a grease for paint ball guns.
    Give it a crank
    May 2010
    This stuff works, keep looking it up on the internet and you might read it's also used for artificial insemination.
    ~Disc~Golf~
    ....it's also used for artificial insemination.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Awesome
    ~Disc~Golf~
    Quote Originally Posted by AZ.MTNS
    Awesome
    EV-ER-Y-time homie!
    Give it a crank
    May 2010
    Guess I'll have to add paintballs to my XCR, I bet it would only make it better!
    Singletrack Slayer
    EV-ER-Y-time homie!
    LOL Paintball guns., that's a new one
    Former Bike Wrench
    Grease...I started using Lubrimatic Green LMX "Red" grease, a soy based biodegradable grease for a general bearing grease last winter, tested all winter and worked great. For forks (and paint guns ), nothing beats Slickoleum.
    Chain Lube...Renewable Lubricants 15W-50 Bar and Chain Oil (canola based), cut 50/50 with canola oil.
    Both available through Grainger
    ~Disc~Golf~
    Quote Originally Posted by mtnbiker72
    Man, everybody I used to know had them - Now, when I'm over at someone's place, no one's got 'em...
    (am I showin' my 'oldness' )
    I think I can point out a bunch of needed fittings/boxes/parts...faster through that catalog than the interwebs
    (oh^^^, I do handyman work - basically a JOATMON)
    Reputation: ToneyRiver's Avatar
    I bought a huge tube for really cheap at Walmart. It is probably the same stuff as used by some of the same bike brands but for way less. It works well too!
Members who have read this thread: 18
