• 01-15-2013
    Dogbane
    Mavic Crossmax ST Wheels and Cassette Compatability
    So after purchasing my Crossmax ST set, I noticed that the freehub is not compatible with cassettes that don't have a spider. Is that indeed what this little diagram on the freehub is telling me? Are there exceptions to this, or should I follow Mavic's recommendation and buy a new cassette with a spider? I was originally planning on throwing my XT 11-36 cassette on this freehub, but because it doesn't have a spider, I've decided to hold off. Do you guys have suggestions for a decent 10 speed 11-36 (with spider) cassette? I have a 10-speed Sram drive train. As always, any input is greatly appreciated! :thumbsup:
    -DB-
  • 01-16-2013
    kmorast
    The XT 11-36 is compatible with the Mavic ST freehub.
  • 01-16-2013
    the-one1
    XT from 750 up is a spidered cassette
  • 01-17-2013
    maviczack
    Hi -
    to the OP, yes you interpret the little sticker correctly. the problem with individual cogs is that they exert a lot of force on the aluminum freehub body and they can make little notches in it. But most cogsets these days are joined in some way, either pinned together or carried on an aluminum backing spider.
    so, I would say, use almost any cogset and you will not have problems.
    happy riding, zack
  • 06-13-2013
    FireLikeIYA
    Originally Posted by maviczack View Post
    Hi -
    happy riding, zack
    Zack,
    I have a set of '12 Crossmax ST 26" and I am using a Shimano XT 11-36 10 speed cassette. The Shimano XT 11-36 cassette uses spiders for all the gears above 19t but the 11t, 13t, 15t and 17t are loose gears. The 11t and 13t have a wider contact point on the freehub with the 15t and 17t gears being your standard loose gears with spacers. I just serviced my hub and noticed that it appears the 15t and 17t cogs are digging into the freehub. Is there a fix for this? I have roughly 400 miles on the wheelset. I am posting this here because I feel it relates to the OP's question. Thank you.
  • 07-14-2013
    gexas
    I have a set of Mavic Crossmax ST's and just upgraded from 9spd to 10spd. i bought a Sram PG1070 cassette and it seems to fit on the hub without any side to side wobble. i do not have the little mavic spacer in there. I've had some people say you need the spacer and others that say you don't need it. I'm not sure who to believe. However, i guess if the cassette fits there without the spacer and doesn't wobble. I should be good.
    Any info. is appreciated if something seems messed up here. I didn't use the spacer when i had the sram 9spd cassette on there.
    E
  • 12-21-2013
    Bosplya
    This thread and Mavic replying to it really helped me. I just bought a set of 13' Crossride's for my version of a bad boy. I thought the sticker was indicating I needed a SRAM cassette only. I too was planning the use of an older XT drivetrain with loose cogs. I guess a spider cassette will have to be ordered.
  • 12-21-2013
    gexas
    Well, several long mileage races and rock gardens later the cassette seems to be rock solid.
  • 12-21-2013
    Bosplya
    Gexas, the cassette you are referring to is not a spider?
  • 12-24-2013
    gexas
    you are right it isn't a complete spider. the biggest three chain rings are on a spider set up. the other 7 i guess are loose rings.
  • 07-02-2017
    helo300
    I have the Crossmax ST 26" wheel set, and wanted a lighter 1x11 cassette than my SunRace, which I took off my new 2017 Salsa Beargrease 1x11. I ordered an XT 11-42 11 speed cassette which had the individual cassette gears and spacers for the last 4-5 cogs. It did not work, binding up and not spinning freely. I put the old SunRace fully spidered/pinned cassette back on and it worked fine.
