Results 1 to 6 of 6
    i drink shower water
    Reputation: hab1b's Avatar
    manitou nixon question
    i have a 2007 nixon super 160mm. is anyone else running this fork? i have about 80 psi in the air spring and it still seems too soft. i dont know maybe im just use to the 8 inch forks am i missing something? how much psi are you guys running? is it ok to go above 80? im afraid of messing something up.
    Prison is hard, everything else is easy
    wpg then, van now
    Reputation: WpgRider's Avatar
    I have 120psi for over a year now in my 145mm Nixon...no issues. What's your manual say?
    manual just says no more than 300psi. who would ever need 300!
    Quote Originally Posted by hab1b
    If the manual says max pressure 300psi, why are you worried about going over 80psi?
    Increase the pressure by say 10psi at a time, check sag, see how it rides. If you are within the allowed range, use what works.
    because i just checled the manual after i posted.
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Now why would you read the manual, that is just foolishness.
    Formotion Products
    http://www.formot
