Results 1 to 13 of 13
    Manitou Minute Elite TPC Forks
    does anybody have them or know if they are any good?
    Dirt Deviant
    Reputation: savagemann's Avatar
    I have the minute elite absolute in 120 and the same fork in 140mm with IT travel adjust. I like em both alot.
    Don't know about the tpc model though as I have never had one. Most of the 2008-2009 manitou stuff is pretty good though.
    Aug 2005
    I have a 2008 120mm tpc elite with a 20mm. So far, love it. Plush, pretty stiff (I'm a big guy) great fork for the value.
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    TPC is good just make sure to grease the seals with seal lube to reduce stickshion.
    Formotion Products
    http://www.formot
    Don't be hasty.
    Really liking mine, however I bought it about 3 weeks ago and it seems the seals are leaking.
    Jan 2005
    Quote Originally Posted by Soya
    Which side??
    Formotion Products
    http://www.formot
    Reputation: delnorte's Avatar
    Does anyone ever hear a clanking noise in a 140mm Minute Elite when the fork tops out from a compression? Anyone know what that might be?
    would i gain anything by getting them with the absolute instead of the tpc?
    Jan 2005
    Quote Originally Posted by delnorte
    Manitou recommends 50psi minimum sometimes you need to bump it up a couple more psi. If you run less air or none it tops out making a clacking noise.
    Formotion Products
    http://www.formot
    MattSavage
    Reputation: mattsavage's Avatar
    Sep 2003
    Quote Originally Posted by jeremy5000
    You'd gain a more complex damper, but not necessarily better one... I swear by my TPC forks. Easy to custom tune, reliable...
    "I wrote a hit play! What have you ever done?!"
    Have Ashtray, Will Travel....
    squish is good
    Reputation: Clutchman83's Avatar
    I agree with mattsavage, TPC is simple and it works great. The Absolute damper gets you a platform adjustment rather than a compression adjustment, I'd take compression adjust over a platform every time you gave me the option.
    Bike good, work bad.
    Don't be hasty.
    Quote Originally Posted by dogonfr
    Which side??
    Both.
    Jan 2005
    Both.
    Right side is the only side with oil most likely your seeing the Prep M lube that Manitou uses on dampers and seals and not oil, nothing to worry about.
    Formotion Products
    http://www.formot
