Longer bolts for bashguard?
Hey,
So i am ordering stuff online for xmas, and i just got a new to me bashguard(thanks to kntr) and my old crank bolts arent long enough, as i suspected...
So my question is is there a set size for a crank bolt that fits an e13 bash? Also, can anyone find them on pricepoint cause im having trouble...
Thanks.
2008 Kona Caldera
"Today I saw my own son use a bicycle as a weapon....
I seriously thought he was going to rape me"
Yep
Any 15mm chainring bolt should do it (with spacers)
Like these...
http://www.chainreactioncycles.com/M...x?ModelID=5995
e13 bash guards require an intermediate sized chainring nuts and bolts. 12mm to 13.5mm, which are said by e13 support to be common on many downhill cranks, but not on lighter weight triple cranks which are normally 8mm. (I found out the hard way after buying e13 brand 15mm bolts that were too long for the e13 Turbocharger bash.)
Spacers with common 15mm chainring bolts could work if single ring, but interfere with shifting if a duel ring.
Ya, i have a dual ring, so should i look for 13.5mm bolts then? cause i do want to be able to shift in the front....
Thanks.
2008 Kona Caldera
i couldnt find any bolts the right size.
so i filed down some 15mm bolts
Stylo triple running turbo bash instead of big ring.
Nicko
- You may not post replies
- You may not edit your posts
Forum Rules
