Results 1 to 56 of 56
    Reputation: plummet's Avatar
    Light weight 160mm + bikes
    Post up your 160mm travel (or more) light weight builds.
    What's the spec and how much does it weigh?.
    I wonder what the lightest practical build is for a big hitting all mountain bike.
    Yeet so hard
    Reputation: tims5377's Avatar
    Oct 2010
    Does weight really matter when you break something?
    Guerrilla Gravity BAMF
    Smash
    I'm not a weight weenie and will not compromise performance for light weight.
    But if you can retain descending performance and durability and at a lighter weight you will increase climbing ability and have an overall better bike.
    Or you may be able to increase travel and descending ability while retaining equivalent climbing ability by speccing a lighter longer travel bike.
    What are the practical limits? I'm interested to know.
    Reputation: Timothy G. Parrish's Avatar
    Apr 2014
    Quote Originally Posted by plummet View Post
    The lightest practical build would probably be dependent on rider weight. Someone who weighs 130 lbs is going to put less stress on a build than a 210 lb person would.
    Sent from my MotoG3 using Tapatalk
    Reputation: Gman086's Avatar
    I have a medium aluminum Balance that is 31 pounds on the nose with Nox Farlow carbon wheels and CCDBA shock. I have a lot of product knowledge and my personal opinion is that you can't get under that weight safely on a big travel bike if used for park/big hit riding. You can shave off a pound or two by going with a carbon frame bike like a Nomad. And I don't agree at all on the rider's weight coming into play... once you start hitting big stuff things are going to break regardless unless they are up to the task. Aggressive trail riding is a different story.
    Have FUN!
    G MAN
    "There's two shuttles, one to the top and one to the hospital" I LOVE this place!!!
    mbtr member
    Reputation: scottzg's Avatar
    Quote Originally Posted by Gman086 View Post
    You must be fairly small if you think that.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    These days, 28lb can be a beefy 160mm build. Not crazy beefy, but strong rims and useable parts.
    I had a Santa Cruz Nomad that was just over 27 pounds.
    CC Version with the XX1 Kit
    Bike could handle way more than I could.
    I'm riding a large Turner RFX, XO 11spd, RS Lyrik fork, Knight carbon wheels, KS Integra dropper, so really nothing extremely light, but everything is durable. Bike weights 28lbs with pedals and bottle cage.
    EXODUX Jeff
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    It's three.
    Jan 2009
    How much money have you got?
    Aug 2005
    Quote Originally Posted by thesmokingman View Post
    Exactly.
    As they say: light, strong and inexpensive. Pick 2
    2016 Santa Cruz Hightower 29er
    2016 Chromag Surface 27.5+
    2013 Transition TransAM 29er
    2017 Motobecane Lurch FS 26 fat
    bike rider
    Reputation: Lelandjt's Avatar
    My Nomad with 150mm Reverb, no chainguide, Monarch+ shock, and 2.4 HRII Exo tires is 26.3lbs. It spends much more time wearing 2.5 WTB Breakout Toughs, 200mm 9point8, a carbon MRP, and sometimes even a Vivid Air which bumps it to 29.1lbs.
    Everything that can be weight weenied on the bike is including every bolt being Ti or Al but it still has held up to pro enduro racing since 2014 with no problems.
    I'm about to give the same treatment to a 170mm 29" Capra and I expect it to be just over 30lbs with 2.5" Double Down tires. For reference I have a 26" V10 that's 31.5lbs with 2.7" Minion DH casing tires.
    Keep the Country country.
    Mar 2015
    My bike setup depends largely where I'm riding, and if I'm riding or racing. Weight difference between my heaviest tire/wheelset and lightest combo is 1160g or 2.5lb. When you shed weight you give up a little bit of reliability and as long as you understand and change your riding style accordingly you should be fine. If you are doing 6000 ft of climbing, you may not want to carry 2.5lb additional rotating weight. But if you are doing 25 mph through a rock garden, you wouldn't want a flat or worse a busted wheel. Riding conditions (rocks or loam), rider weight, aggressiveness (my 17 year old rides much differently than I do) are some of the things I think about. 2.5lb difference is just wheels and tires.
    Yeti SB6c
    currently 29.5 lb with XT Trail Pedals
    Light Build 28.2 lb with XT Trail Pedals
    Bike Park build 32.2 lb with XT Trail Pedals (coil shock, bash guard, etc)
    I have 2 wheelsets, Spank Oozy 345 2050g , and Ibis 742 1630g
    Front Tires options:
    2.5WT DHF DD Max Grip or 2.5WT DHF Maxx Terra (1170g/945g)
    2.35 Magic Mary Super Gravity or Snakeskin (1100g/835g)
    Rear tire Options:
    2.5WT Aggressor DD 1100g
    2.4 WT DHRII 900g
    Rock Razor Super Gravity or Snakeskin (965g/695g)
    Yeti SB6c
    Cannondale Jekyll Carbon Team
    Ibis Ripley LS
    Cannondale Scalpel
    My new orbea occam is 27.8lb. Still has the stock 580g rear rim and heavy hub. 350g bars. The crank has to be close to 900g... its still a 2x setup.
    I have room to trim it down using strong parts. Its going to be around 26lb. Its not even an expensive build.
    Bike was $1599. I didnt spend much on upgrades either. Things are cheap, strong, and light now.
    To be clear... my statement was for a "big hitting" build which to me is a build you can use every day at a bike park; a big difference as both Lelandjt and LegionX correctly point out. A bike build like BluePitch's with 2.3 single ply Minions and a Monarch Plus shock is just not "big hitting" IMHO so it depends on your own expectations.
    Have FUN!
    G MAN
    Have FUN!
    G MAN
    I also had a DHX2 with steel coil and 2.5WT tires that quickly switched my small hitting N3 to a medium hitting N3. Was closer to 29lbs in that trim.
    Quote Originally Posted by BluePitch View Post
    Yup, that makes sense to me and starting to see a pattern here... about 29ish or so pounds is about as light as you can go for that type of riding.
    Cheers,
    G
    bike rider
    Quote Originally Posted by One Pivot View Post
    You're sure your scale is accurate? That weight just doesn't seem possible. Not even with Exo tires.
    bike rider
    I'm just gonna mention that the Monarch+ and DPX shocks are pretty legit for real enduro riding, especially after some customizing from someone like Diaz Suspension. I rarely replace the Monarch+ with the 1/2lb heavier Vivid Air since Anthony got it feeling how I want.
    Jan 2009
    Quote Originally Posted by Lelandjt View Post
    That's what I was thinking. At $1600, I'm guessing on sale it might be the alu H30 variant that is spec'd at 31lbs.
    Bone stock it was 29.8lb. I had parts laying around, but they were cheap too. Xfusion sweep measured a tad under 1900g. Not bad for a 160mm fork, for $250 new. Changed one wheel and tire, plus the fork, and got under 28lb.
    The Occam AM ships under 25lb in its highest trim.
    Jan 2009
    Sure but it also stickers for 8G's! Thus post #11.
    Reputation: Mudguard's Avatar
    30.11lbs?
    170mm front, 165mm rear. 2.35 tires though. I rarely go wider unless I was going to be uplifted for several days in a row.
    I think the only carbon parts are the bars. Could probably shave some weight with new cranks and a no Saint parts.
    Mar 2015
    What are the specs on your Build? Is weight with or without pedals?
    If I want to weight weenie my build, I’ve gotten it down to 26 lb without pedals. Top shelf Occam comes with a Fox 34 and Ardents. Also comes with DT-Swiss XMC1200 which are 1450g and good for regular trail riding, but not my definition “big hitting all mountain” wheel set. DT’s EX series are more my definition and come in at 1860g. Everybody has there own ideas of what is light. I ride a lot in the Lake Tahoe area in Northern California and 1000g tires are the norm.
    You can make most bikes light. Light and strong is possible if you throw enough $$$ at the problem.
    Please share the details of your build. What tires and wheelset are you running? Wheel size?
    Yeti SB6c
    Ibis Ripley LS
    Cannondale Scalpel
    How much travel does an Occam have?
    Mar 2015
    Quote Originally Posted by Mudguard View Post
    2018 Orbea Occam AM is 150/150, comes with Fox 34.
    2018 Orbea Occam TR is 130/120, also comes with Fox 34.
    One Pivot has a custom build.
    Orbea also makes the Rallon which is a 160/150 29er. Rallon ships with Fox 36.
    For the OP, the fun part of this hobby is trying out different components and seeing what works for you. When my son started riding, we went to Northstar Bike Park and he rode a 2012 Ibis Mojo SL 140/140. 26” XC bike with 700g tires. Bike held up ok, but he was 14, 140lb and just starting to ride. Now, he is 180lb, raced the North Star Enduro last year and would probably destroy his old bike on his fun run down.
    For a dependable bike, 27lb -30lb seems to be the range for “light” builds with pedals. <27lb in my experience is where compromises are made or $$$ becomes a bigger issue. I know Scott and a couple other brands make good lighter bikes, but these are my “general” experiences.
    Yeti SB6c
    Ibis Ripley LS
    Cannondale Scalpel
    Quote Originally Posted by LegionX View Post
    So not a 160mm bike then. You could get a light hardtail and chuck a 160mm fork on it. Voila. Think of the weight savings!
    Reputation: LargeMan's Avatar
    May 2017
    2018 Giant Reign SX
    Race Face Next R crank / kept the stock MRP chain guides on
    SRAM XX1 cassette, der and shifter
    Renthal FatBar Carbon 800mm
    ENVE HV60 with 240 hubs
    ProLogo Ti saddle
    RaceFace Turbine 35 stem
    Maxxis Minion 2.8 EXO front, Maxxis Rekon 2.6 rear
    30.12lbs with Zipp carbon cage and TIME carbon pedals.
    Really was shooting for just under 30lbs, did not make it.
    Oct 2007
    I have a 2017 Canyon Strive CF Race 9.0 I’m about to put on a diet. Spec sheet gave it 12.9kg in OEM spec (28.43lb)
    My wife has just brought a 2017 Bronson 2 CC with a 2018 build kit that is also going on a diet. Haven’t weighed it yet
    Because Natalie is quite light it makes a big difference if her bike is light
    First up for the Bronson will be Carbon wheels with CX-Ray spokes & hope pro 4 hubs are first up. T800/T700 Carbon with 365g rim weight. 26mm internal width
    Quote Originally Posted by LargeMan View Post
    2018 Giant Reign SX
    That's impressive. The slightly OCD part of me would try find the last part to tip in under 30. You could probably do it easily with tires.
    Oct 2007
    Original Canyon Strive Spec:
    MODEL YEAR 2016
    FRAME CANYON Strive CF Med 9.0 Race 2016 colour: factory enduro team, ISCG 05, rear brake 180mm post mount
    REAR SHOCK FOX FACTORY FLOAT X EVOL 200×57 Tune code C236
    FORK FOX FACTORY 36 FLOAT 27,5 170 RC2 KASHIMA 20 TA 1,5T
    HEADSET CANE CREEK 40
    REAR DERAILLEUR X01 X-HORIZON™ Rear Derailleur, 11S
    CHAIN GUIDE MRP 1X V3
    SHIFTERS SRAM X01 TRIGGER, 11S
    BRAKES SRAM GUIDE RSC
    CASSETTE SRAM XG-1180 10-42
    WHEELSET DT SWISS EX 1501 SPLINE
    TYRE Front 650b x 2.4 MAXXIS HIGHROLLER II EXO TR 3C MAXX TERRA 2.3
    TYRE Rear 650b x 2.4 MAXXIS MINION SEMI SLICK 2.3
    CRANKS* RACE FACE NEXT SL DIRECT MOUNT, 11S
    CHAINRINGS 34T raceface cinch direct mount
    BOTTOM BRACKET External bearings BSA thread RACE FACE
    STEM RENTHAL Apex 40mm Stem
    HANDLEBAR RENTHAL FAT BAR CARBON 790mm
    GRIPS ERGON GE1 SLIM
    SADDLE SDG CIRCUIT MTN
    SEAT POST 30.9mm 125mm ROCKSHOX REVERB STEALTH
    PEDALS
    WEIGHT Original specification 12,90KG
    bike rider
    2018 Giant Reign SX
    ProLogo Ti saddle
    Ti bolts will get you there. Start measuring and go to TorontoCycles.com
    An interesting discussion thanks guys.
    Looks like theres 2 build types typically.
    1) Bike park limited climbing set up , robust wheelset/tyres comming in a around 13.2kg 29 pnd typically lightest.
    Or
    2) Climb,decend set up with llighter tyres/wheels for better climbing ability with the sacrifice of some descending ability. 27 pnd 12.2kg being the typically lightest.
    Looks like i'm right in the zone then of light weight, but i have savings to make if i get my wallet out.....
    My wifes bike on the other hand. Pretty much at the pointy end of light weight.
    My bike.
    Rocky mountain slayer
    Fox factory 36 limited climbing set up
    Fox x2 rear
    xt drive train and brakes
    Roval wheels
    Renthal bars,step
    KS 125mm dropper.
    Minion dhf2 2.3
    XTR pedals (cageless)
    13.1 kg, 28.9 pnd
    Wifes bike
    Intense T275
    Enve M60, chris king
    Thomson stem, enve bar
    XX1 drive train
    Thomson 150mm dropper
    Pike
    Cancreek DB Air
    XTR pedals (caged), brakes.
    Highroller 2 2.3
    12.5kg, 27.6pd
    Mar 2015
    Those are great looking bikes and nice builds. Looks like your wallet has already done a lot of work . Love the color of the Slayer.
    Yeti SB6c
    Ibis Ripley LS
    Cannondale Scalpel
    Reputation: cookieMonster's Avatar
    A point that a lot of people don't really discuss is that perhaps there's a weight threshold at which, if you go under it, descending performance suffers?
    I have owned a 30-31 pound 150mm bikes and currently a 35 pound 180mm bike. The lighter bikes, while fun on flatter descents, lose stability at super high speeds and/or gnarly conditions. My heavier bike pulls away from them in those conditions.
    It could be that I'm a big guy (190 pounds during peak riding season) -- but every time I ride a 28-30 pound bike in DH-like conditions I feel a little out of control, because I'm overpowering the bike.
    Dear U.S. Forest Service: Please ban all wilderness in my riding areas.
    There are certain things a bike like this needs IME, it needs tough enough and wide enough tires. Those usually come around at least 800g. It needs a dropper post for versatility, that is a pound over a bike without. It needs a beefy enough shock, this doesn't have to be a coil, but a reservoir-type air shock at least, like a Monarch+, CCDB Air, DPX2, etc. It needs a 200mm front brake. It needs decent enough rims (doesn't need to be 40mm, but 25mm internal or close to that is not appropriate).
    You'll find guys with lighter builds, but you'll also find a lot of parts that aren't appropriate to that kind of riding. As many here have said, it IS possible to keep the weight down on a modern frame and still have a good riding bike. There are drivetrains that will save a lot of weight and modern carbon frames save at least a good pound over a comparable alloy frame, two at the more extreme end.
    The other big game-changer IMO is tuned suspension. With the Avy stuff I have on both ends, I do not ever "want for" a bigger bike or more suspension. If I go to a big park, like Whistler, then sure, a full DH bike would be more fun, but at my local park and all of my local riding, the bike is great on the descents with the tuned suspension. Suspension quality far outweighs having 20mm more or less travel.
    My RFX is around 29.0 with the Monarch+, more like 30 when I put the coil on it. It's nice having two shocks that I can switch between.
    Mar 2015
    ^^^ couldn’t agree more. Jayem articulated it perfectly
    Yeti SB6c
    Ibis Ripley LS
    Cannondale Scalpel
    I'm with stupid
    Reputation: hitechredneck's Avatar
    2018 Knolly Warden Carbon size large with push 11-6, 2.5 dhf wt aggressor wt rear both in double down with cush core installed fox 36 at 170mm eagle drive train, crabon cranks, bars, wheels. 32.6 lbs hanging from park tools scale. It is my enduro race bike so it hase quite a bit of beef built into the suspension and tires/cushcore.
    Cheers man. My wallet has done about 50% the work you expect. I'm a near new second hand buyer. None the less they are aweseomest bikes i've owned.
    Quote Originally Posted by cookieMonster View Post
    Is weight the reason or is it that fact that the heavier bike has better travel, thicker wall tyres that grip better and better angels for descending?
    I'm of the opposite opinion. All other factors being equal if the bike is lighter it has better descending perfomance. You can muscle it easier, pop the bike float over stuff better. U see no advantage in a heavier bike if you havent gained a suspension, tyre, geoemetry advantage.
    May 2017
    Yep, I have a different bashguard coming that will get me there. Not ready to go full weight weenie yet. I am at 238lbs myself! And I love my tire combo for how I ride, but for sure could drop another pound in tire weight.
    bike rider
    I agree, light always helps. Riding my 31lb V10 vs normal 35lb DH bikes is a revelation. You get to have DH tires and 200+mm suspension but it still tosses around like an enduro bike. The key is not giving anything else up while dropping weight.
    May 2018
    My new YT Capra CF Pro 27.5 in size XXL weighs 31.0lbs on my digital shipping scale with Race Face Atlas flat pedals, ready to ride. Could easily drop 2.5lbs with a good selection of wheels/tires and a carbon bar.
    Reputation: ColinL's Avatar
    Feb 2012
    A lot of people misread that scale. Your bike was 27 pounds 7 ounces. 8 ounces would be a half pound. So it's much more accurate to say that your nomad was 27.5 pounds.
Name:	s-l1600 (10) (Medium).jpg
    Sent from my XT1635-01 using Tapatalk
    i like rocks
    Reputation: euroford's Avatar
    I suppose everybody will have a slightly different version of what "lightweight" is, but for me i'd like it as light as possible, without compromising durability and hopefully within a reasonable budget. Fortunately I cheated on the budget aspect and scored my beast at a clearance price. Weight wise, she's just a hair over 30 pounds. Durability has been impeccable, running Minion DHF DD 2.5 tires she has not once let me down on the trail up until I was blessed with the Sram Guide brake lever failure yesterday. She's put up with a fair bit of abuse, including 30+ days at trestle bike park, 6 laps of TWE (plus other gnarly Moab trails) and trips to Whistler/Squamish/Pemby and Sedona amongst others.
    2017 Nukeproof Mega 290 with the following changes
    Diety Bars, Silicone grips, KMC Chain, Deity seat (not shown), 28t oval, X0 carbon cranks (not shown, 165mm), 200/180 rotors, deity pedals, a handful of ti bolts, tubeless with lots of sealant.
    Weight of 30.1 pounds is with tube, levers, pump and empty water bottle, with pedals of course (weighing your bike without pedals is stupid).
    here she is waiting her turn on the pemby heli.
    Tim M Hovey
    Nukeproof Mega 290
    1950 CJ3a
    1999 BMW 540i
    1999 F350 PSD
    DFL
    Reputation: askibum02's Avatar
    I honestly could care less about weight. I'm 245 in my birthday suit, closer to 260 with my CamelBak, I have a '17 Bronson CC that I bought because it was on clearance, and I paid what I would have paid for a current model aluminum bike in other manufacturers. I replaced the 150mm fork with a 160mm Fox Factory because I couldn't get the Pike feeling the way I wanted. I bought carbon wheels, not because they were lighter, but because they were stiffer. I was flexing the Race Face ARC27 28h wheels that came on the bike, so I bought 30mm 32h carbon wheels. They weighed almost exactly what the Race Faces weighed. I sliced the sidewall of a EXO DHRII so I replaced it with a DD. Everything I have done was for strength and durability. I don't think losing a 1/2 pound on the bike is going to make that much of a difference with what I weigh. I always have been, and always will be DFL. I'd rather have durability than light.
    Untitled by Brett Valentine, on Flickr
    I wouldn't **** you, you're my favorite turd.
    Quote Originally Posted by askibum02 View Post
    First up. Your bike doesn't make the grade for this discussion because it's only 150 mm travel...... Hehe.
    Secondly light weight is relative to the riders weight. I have. A buddy who weighs about your weight his bike has to be about 1.5 to 2kg heavier build than mine or he starts breaking stuff.
    DFL
    Uh, the fork is 160mm, that has to count for something.
    Sep 2016
    Kona 153 2016 XL
    Carbon bars
    2.5 DD front
    2.3 rear
    Tubes all round
    Saint flats
    150 dropper
    32.4 lbs
    If I need to drop weight I should go on diet,just checked in lbs(114kg=250lbs)jeeperz I'm a fat f***
    IMG_7794 by Clarkie194, on Flickr
    Oct 2015
    I'm 100kg and my large Rocky Mountain Altitude is at 14.2kg now and soon to be just under 14kg/30lb. That's with 170mm Lyrik, 2.5 dual ply rear, 2.8 front, alloy cranks, bash guard, dh rated carbon wheels, 150mm dropper post, bottle cage etc. <30lb is quite achievable these days without sacrificing strength or usability.
    May 2017
    Sold the Reign and picked up a Norco Range 29er C3.
    Swapped out almost all of the parts from the Giant
    DVO Diamond Front Fork 160mm
    DVO Topaz Rear
    RaceFace Turbine Wheels with Minions 2.5 WT F/2.4 DHR R
    RaceFace Next R Crank
    SRAM XX1 11 Speed Drivetrain
    SRAM Guide RS Brakes with 180mm Rotors
    Bikeyoke Revive 125mm Dropper
    Renthal Carbon FatBar 35.0 x 800mm 30mm Rise
    RaceFace Turbine Stem 35.0 x 50mm
    ProLogo Scratch 8 Ti Saddle
    Zipp Cage and Time Carbon Pedals
    30.04 - ALMOST THERE!
    Put 160mm fork on carbon xc hardtail. Win thread?
    Stupid is, as stupid does
    Reputation: spunkmtb's Avatar
    So I have to chime in on this. I am 6'2 currently 235lbs. I've been mountain biking for 30 years. My philosophy on bike builds. I like to pedal. I like to earn my downhills. This being said shorter people are lucky. Their frames do not weigh as much and also they generally weigh less so the uphills are easier. Over the years I have learned what parts to go light weight on and what parts not to. Beofre the days of droppers I have had many a snapped seatpost. I was one of the first people in the US to snap an easton carbon seatpost back in the 90's (As told to me by easton when I warrantied it). Needless to say I don't put easily breakable lightweight parts on my bike anymore. However I still try to keep them light. I consider a FS bike light if it is 27.9lbs or less.
    My current "Enduro" bike which I just built up a few months ago is an Ibis HD3 (Weighs 28.1 sigh........
    Wheels-Light bike 38mm rims with Sapim CX-ray spokes. (Alloy Niplles (I will no longer use Alloy. Switching to brass after 4 years the nipples are separating)
    Hubs-DT Swiss 240 SP 28 hole 52T ratchet (I will never use 28 hole hubs again. Broke two spokes and the wheel became super wobbly)
    Wheel Axle- F: Wolf Tooth Components Wolf Axle R: MRP Race Axle
    Handlebar Race Face Six C 31.8 800MM
    Stem Syntace Mega Force 2 stem-40mm
    Top cap- Push Industries
    Grips- ESI chunky
    Brakes-Shimano XTR trail (I was a formula man for years with the Oro Puro's but got sick of having to constantly adjust the R1's).
    Shimano XTR Centerlock 203F 180R with cooling fins (The fins are no joke. Worth the weight when you are my weight and riding in hot summer temps).
    Shifter-XTR 11 speed
    Stem spacers-Box Componenets (Check these out, they look sick, are super light, and the cost is reasonable),
    Fork- 1st Gen Pike 160mm RLT W/MRP Ramp Control
    Dropper Remote- Wolf Tooth Components Remote light action
    Dropper- KS Lev external 150mm (Weighs less than the integra)
    Saddle- Selle SMP Pro (Due to Protrater issues I must use this saddle. It weighs more than most, bit puts zero pressure on my man part)
    Shock-CCDB Inline with Cane creek remote actuator
    Crankset-Race Face next Sl
    Chain Guide: One Up ISCG05 chain guide
    Chainring- Oneup 28T Elliptical
    Bottom Bracket- Wheels Manufacturing Angular Contact bearings (Abec 5)
    Cassette- Shimano XT 11-42 W/OneUp 47T (I hate the weight of the XT cassette but the 11-40 XTR spread won't work with the oneup 47T. Considering switching to an XD driver and using another brand cassette)
    Rear D: SHimano XTR with WTC 11sp Goat Link
    Chain-KMC 11sl Ti-Nitride
    Pedals- Xpedo Baldwin W/Ti spindle (I am way over the weight limit but so far so good)
    Tires-Front: Hand Dampf 2.35 Apex Rear: Maxxis Ardent EXO TR (If i go to a ski area or somewhere else burly I will swap the rear tire out for a DHR2 or DHF)
    Bolts-Both TI & aluminum bolts where safely applicable)
    Yeti SB95C
    Carver Ti 420
    Ibis HD3
    I always wanted a SC Bullit. 170mm travel with a 170mm 40mm Totem...single pivot built at 27lbs. Could take a big nasty hit. Wish they still made them b/c bikes like that were incredible for drops to flat like some of our local builders like to make for some odd reason.
    Quote Originally Posted by spunkmtb View Post
    Grips- ESI chunky
    A cool solid light weight build,. But correct me if i'm wrong. Its only a measly 150mm rear travel and doesnt make the minimum spec of this thread.! hehe
  1. Which 2016 Fork? 160mm Pike or 160mm Lyric for 650b
    By JNG in forum Shocks and Suspension
    Last Post: 09-07-2015, 11:36 AM
  2. Fox rc2 2011 (160mm) vans vs fox rc2 2014/2015 float (160mm)
    By jabba69 in forum Shocks and Suspension
    Last Post: 11-07-2014, 10:27 AM
  3. 2014 Pike 160mm Air Spring compatible with a 160mm Lyrik?
    By hafnz in forum Shocks and Suspension
    Last Post: 05-05-2014, 10:55 AM
  4. Downsizing rotors from 185mm/160mm to 160mm/140mm
    By xterrafreak in forum Brake Time
    Last Post: 02-26-2013, 12:03 PM
  5. Decent light weight rotos (160mm)
    By HighLife420 in forum Weight Weenies
    Last Post: 06-04-2011, 09:59 AM
Members who have read this thread: 366
