Light, strong crankset
Printable View
  • 12-19-2012
    helidave
    Can anyone recommend a good crankset and bb that is less than 800 grams and will hold up to rocky, technical, am riding. I'd like to keep it below $350. Will be used 1x10
  • 12-19-2012
    hitechredneck
    Its a bit above 800 but with a single chain ring will be pretty close but I have had great luck with XT cranks with tons of rock hits and still going. Im trying out a XO setup right now we shall see if that gives me as much faith. I have had my XTs for 3 summers now and still going strong.
  • 12-19-2012
    TwoHeadsBrewing
    Another vote for an XT double, just replace the big ring with a bash. It'll help keep the chain on and protect the chainring in the chunk. 820g with both rings, probably a bit less just a bash on the outside.
  • 12-19-2012
    helidave
    Just saw the new sram xx1. 650 grams and should still work with 10 speed chain.
  • 12-19-2012
    Calhoun
    I have been looking at that crankset too, and according to this thread it will work fine with 10 speed.
    http://forums.mtbr.com/sram/sram-xx1...ed-818475.html
  • 12-19-2012
    motochick
    Middleburn or devinci. Ti bottom bracket.
  • 12-19-2012
    Rock dude
    I'm running XO with MRP Bling ring with no problems.
  • 12-19-2012
    jgusta
    I would check out E13's TRS+ cranks that just came out. Will be my next cranks to replace my very robust and heavy Saints on my AM bike.
  • 12-20-2012
    helidave
    It looks like the xx1 will be hard to beat for the price and weight.
  • 12-20-2012
    bikerjay
    I am of the opinion that 2 piece with a pinch bolt (shimano and a few others) is the best design around. The pinch bolt design lets you set the bearing pre load exactly.
  • 12-20-2012
    sonoranbiker
    Stay away from Rotor. I had one of their cranksets on my RIP 9 when I bought it used; broke the spider in 2 weeks. Now have a XT triple w/ bashguard and it seems to be working great.
  • 12-20-2012
    jgusta
    Yep, would be my prefered 1x trail/AM set-up, but after you buy the required cassette, rear der, shifter, chain, your in it well above a grand, ouch! And the idea of having to replace the cassette and ring every year for well over $500 for disposable parts that need to be replaced somewhat regularly is crazy talk, unless you are made of money of course.
  • 12-20-2012
    helidave
    Originally Posted by jgusta View Post
    Yep, would be my prefered 1x trail/AM set-up, but after you buy the required rear der, shifter, chain, your in it well above a grand, ouch! And the idea of having to replace the cassette and ring every year for well over $500 for disposable parts that need to be replaced somewhat regularly is crazy talk, unless you are made of money of course.
    None of that stuff is required... Plenty of people are running the xx1 crank with 10 speed chain/cassette/derailleur :thumbsup:
  • 12-20-2012
    jgusta
    Nice...if that's the case then should definitely be a good option for ya. If I went 1x, I would have to get all the other XX1 stuff to take full advantage of the 10-42 gears out back. 1x10 is not enough gears for me as I like to run at least a 36t ring up front and do a lot of long, sustained steep climbs to get to good descents around my neck of the woods, so it's 2x9 for me all day. Come Enduro season, probably go 1x9 for optimal chain retention (but thicker rings such as Blackspire SuperPro's w/bash and front der does pretty good as well for not losing chains).
  • 12-20-2012
    string
    Jensonusa has the SRAM XO GXP 2x10 for $179 (plus bottom bracket). I picked up one with the Truvative bottom bracket and and MRP Bling Ring for around $260. They only have 170mm left but its a great deal if the lenght worked.
    Weight was around 600 grams. Add the Race face rubber boots for $10 and you have your rock protection.
  • 12-20-2012
    arkon11
    Saint. You'll never need to buy another crankset.
  • 12-20-2012
    jgusta
    True that as that is what I am running on my AM bike as well. But Saints are about 1/2 lb heavier and more money than was OP is looking for.
    Saints are solid as f%#% though and I noticed them to be much stronger and stiffer than XT or SLX, especially when stomping landings when jumping, railing turns w/angst and standing and mashing on the pedals thru chunky terrain. Bombproof they are :thumbsup: My only dis with them is they are noticeably the stiffest thing on my bike, lending notice to some frame and wheel flex with hard riding on my "AM" bike and they are much heavier than other cranks of course.
  • 12-20-2012
    FM
    If you're crank shopping, buy Jgusta's E13 cranks in the classifieds!
    I am running E13 cranks & BB on my banshee prime, they are hands down the best cranks I've ever owned (and yes, I've owned saints). Noticebly stiffer than the XT's they replaced, totally silent, super Quick & easy install & removal.
    Personally I am not a fan of the NDS pinch-bolts on shimano's crank designs. They are in an impact area and tend to get packed up with bark & rock. It's also difficult to use a torque wrench on them as the cranks want to spin as you are applying leverage to the wrench, which can round out the bolt heads. Lastly, they get creaky if you don't use a torque wrench.
  • 12-20-2012
    clydecrash
    Well, the RF Sixc crankset would easily meet your <800 grams, but not for $350. Jenson is selling the double/bash 9s for 410 right now though. I am interested, just concerned with ending with a well-beaten carbon crank to look at, but just looks (supposed to be strong and very stiff). I don't ride South Mountain, but enough of that kind of stuff around Tucson.
  • 12-20-2012
    gurp
    Ah, if only Shimano would give us XT with steel pedal inserts...or even an updated SLX crankset with them.
  • 12-20-2012
    jgusta
    Cheers..thanks for the promo man! I just got these from E13 direct last week, along with a bunch of other goodies from them that I'm keeping (guide, rings, BB) for placing 1st in my Cat at Oregon Enduro Finals race in Sept. They look like very nice cranks and some lighter than Saints I think. Would keep them if I already didn't have the Saints and wanting the TRS+ cranks for a little lighter package. E13 would only send me the LG1+'s or XCX's for winning, not TRS's so selling them.
  • 12-20-2012
    FM
    I'd pick 'em up myself for the winter hardtail build project, but alas the holidays killed my budget (and I have some beatdown XT's that will get 'er done for now).
  • 12-20-2012
    b-kul
    if your going xt might as well go slx. cheaper and barely heavier. i think when you replace the ring with a ss ring any weight difference shakes out in the wash.
  • 12-20-2012
    Stumpjumpy
    I recently just picked up a set of '11 FSA SL-K Light carbon cranks w/ BB30 for about $250 on e-bay. Been running them for about 3 months. Have had a few major rock strikes, but zero damage. Quite stiff and reasonably lightweight (below your limit), bling-blingy too.
  • 12-21-2012
    dump
    Have two sets of e13 cranks... good stuff, stiff strong, solid.
  • 12-21-2012
    kcvpr
    Light, Strong, Cheap.
    Pick two.
    Otherwise it doesn't exist.... LOL
  • 12-22-2012
    Stumpjumpy
    Does not pretty much anything that does not use wave washers have a precise way of setting preload? I know my FSA's do.
  • 12-22-2012
    aedubber
    2012 Shimano XT Triple stripped down to a 1x10 setup . Have a 32T e-13 ring with a CK BB , and a cSixx chainguide/bash . Works great for me and feels pretty good .
