Eh, why not? Here's the other one. Gets on the same trails as the other bike, and has done well at a couple lift areas before I got the big bike going. I think it's capable of everything (nearly) that the rubber bullit is, it's only the rider that is holding it back!
The Descender post is a new thing; I'm digging it so far. No urge at all for the bar mount version, as I dislike more crap on my bars.
Peyto Cycles Wild Bill frame www.peytocycles.com
* Frame Size & Color: small/green
* Fork: 05RS Pike Team
* Brakes: Avid Juicy 5 185mm front/160mm rear, alu lever bolts
* Cranks: Race Face Deus XC with alloy granny, alu crank and ring bolts, MRP bash ring
* Front Derailleur: SRAM X-gen
* Rear Derailleur: SRAM x.9 short cage
* Shifters SRAM 9.0 rear/Suntour XC Expert front
* Pedals: Wellgo ti axle Ritchey clones/Shimano M646 (they get swapped out sometimes)
* Stem: Thomson 70mm
* Handlebar: Easton EA-70 2" rise, uncut
* Seatpost: Gravit Dropper Descender 1"-4" version, Hope seat clamp
* Saddle: ti rail SDG BelAir
* Bottom Bracket: Race Face Deus XC
* Cassette: Shimano XT 11-34, only using 8 cogs, with SRP alu lockring
* Headset: Chris King
* Grips: Rogue lock ons
* Front Tire: varies
* Front Rim: Mavic xc 317 or something; i forget
* Front Hub/Skewer: Hope Bulb 20mm
* Rear Tire: varies
* Rear Rim: Mavic something or other; it was a cheap replacement for a blown rim
* Rear Hub/Skewer Chris King 135mm & ti bolt on QR
* Weight 28# A few ti and alu goodies here and there. At my whopping 165# all loaded up and ready to ride, I get away with the light stuff on a big bike. (yep, same as the big bike.)
Yep, comparable parts/build to the big bike. This way I can swipe a part from one to the other if needed. Keeping spare brake pads and other parts around is nice and easy too, when everything is compatable.
I am not dissing your bike, it is a hell of alot nicer than mine, but the Yeti 575's look pretty weak as far as top tubes goes. I'm sure it is a great trail bike, but I really don't see it being a great all around bike. One case, and that frame looks like it would be trashed. No disrespect, just a observation.
For my 2003 Horst Link 5-spot, with weights (PS straight or bent? It is better bent, just look at the 19th century style reinforcement on the 5-spot top tube).
Grease and stuff 100
BRAKES
Brakes Complete Magura Marta (180/160 tuned alu/titanium) 690
DRIVE TRAIN TNT Titanium BB 158
Race Face LP 170 mm with Sugino rings titanium/aluminum bolts 590
Pedals Frog (steel) 240
Rear Der Sachs Tuned alu 199
Front Der (tuned alu) 126
XT Cassette 12-32 260
Chain (SRAM PC99) 275
Medium Silver Frame (RP3/PUSH) (titanium kit) 2791
Seatpost collar (titanium bolt) 16
Chris King headset (tuned/titanium/home made carbon top cap 4gr) 120
Seat Post (Thompson) 230
Seat (WTB Stealth) 230
It goes something like this:
* Frame Size & Color: 2002 Turner RFX with custom rockers, using an 8.5 by 2.5 shock, yielding 7 inches of travel at a 2.8 to 1 leverage ratio. Currently using a pushed RC, soon to be a pushed fox DHX coil shock.
* Fork: '06 Marz. 66SL, also have an "04 Super T
* Brakes: 8 inch hayes mag's F&R
* Cranks:Specialized strongarm cranks, custom bashguard
* Front Derailleur: XT
* Rear Derailleur:XTR
* Pedals: Shimano clipless and azonic platforms, depending upon use
* Stem: Thomson
* Handlebar: Truvativ 31.8
* Seatpost: Gravity dropper, 4 inch
* Saddle: Titec berserker dh
* Bottom Bracket: FSA Ti
* Cassette:Shimano 8 speed
* Controls: SRAM twist shifters
* Headset:Chris King
* Grips:Oury lock ons
* Front Tire:varies
Two wheel sets: Mavis 819's laced to gold hadley hobs, 20mm front, 10mm through rear.
: Hayes/Hugi hubs laced to mavic D321 rims
* Weight: somewhere around 37 pounds
* Frame Size & Color: Sm Ellsworth Moment
* Fork: Marzocchi AM 1
* Brakes: Hope Mini
* Cranks: Race Face Dues
* Front Derailleur: Shimano XT
* Rear Derailleur: SRAM X.7
* Pedals: Crank Bros Mallet C
* Stem: Thomson X4 90mm
* Handlebar: Race Face Dues LR
* Seatpost: Titec
* Saddle: Terry Fly Ti
* Cassette: SRAM 970
* Grips: Profile Designs shorty
* Front Tire: Kenda Nevegal 2.35 DTC
* Front Rim: Syncros DS 25
* Front Hub/Skewer: Chris King
* Rear Tire: Kenda Nevegal 2.35 DTC
* Rear Rim: Syncros DS 25
* Rear Hub/Skewer: Chris King
* Weight???
Well I'm standing next to a mountain...and I chop it down with the edge of my hand
my everything bike, just back from a little 6 mile ride to the store. it not as burly as most of your bikes and it was built on the cheap and does what i ask it to. plus i love this frame for my short self.
* Frame Size & Color: 2002 K2 Funky Monkey small, green
* Fork: 2001 Mazocchi Z.1 air
* Brakes: Deore disks (probably the weakest part of the bike) with Avid levers
* Cranks: Coda PX3 ($10 on ebay and doing fine) w/Core Rat bash ring
* Front Derailleur: '04 LX
* Rear Derailleur: '04 LX
*Shifters: Sram Attack
* Pedals: Mallet C
* Stem: K2
* Handlebar: Kalloy 1" rise
* Seatpost: from my basement
* Saddle: from my old GT, needs to be replaced bad
* Bottom Bracket: Shimano, i forget what model
* Cassette: Nashbar with a big ass granny gear (I'm cheap!)
* Headset: FSA Pig (totally cool yellow)
* Grips: Serfas
* Front Tire: IRC Mudmad DH 2.25
* Front Rim: Sun RhynoLite
* Front Hub/Skewer: Deore Disc
* Rear Tire: IRC Mudmad DH 2.25
* Rear Rim: Sun RhynoLite
* Rear Hub/Skewer Deore Disc
* Weight: 31 pound-ish would probably be under 30 with lighter tires but they were cheap, and the rider's where i really need to lighten the bike.
* Frame Size & Color: Yet 575 XL Raw
* Fork: Fox Talas 130 may get a 140 Talas
* Brakes: Hayes Hydro's
* Cranks: Shimano XT
* Front Derailleur: XT but its coming off soon
* Rear Derailleur: XTR
* Pedals: Shimano
* Stem: Thomsen 90mm
* Handlebar: Easton Carbon
* Seatpost: Thomsen
* Saddle: Specialized
* Bottom Bracket: XT
* Cassette: XT
* Grips: Oury lock-on
* Front Tire: Specialized Adrenalines 2.25
* Front Rim: Mavic 819
* Front Hub/Skewer: Chris King/Salsa
* Rear Tire: Specialized Adrenaline 2.10
* Rear Rim: Mavic 819
* Rear Hub/Skewer Chris King/Salsa
* Weight 30lbs
The fork and seatpost have been changed since this picture, and the tires in the picture is my summer set up. This year the summer tires will be front Kenda Nevegal 2.5 stick-e, and a Kenda Nevegal 2.35 in the rear. Its a heavier set up but very grippy.
Sean
Gears and suspension are for girls and old men. Feel free to quote me in your signature. - Fast Eddy
