FAT BIKES
WINTER APPAREL
TRAINERS
Page 276 of 373 FirstFirst ... 176 226 266 272 273 274 275 276 277 278 279 280 286 326 ... LastLast
Results 6,876 to 6,900 of 9319
  1. #6876
    May 2010
    * Frame Size & Color: Material Kona Scandium 69 Butted Aluminum 100 -160mm travel
    * Fork: FOX 32 Talas RL 150mm w/15mm Kashima
    * Brakes: Shimano SLX
    * Cranks: Shimano M552
    * Front Derailleur: Shimnao SLX
    * Rear Derailleur: Shimano Deore XT Shadow SGS
    * Pedals: Shimano M530 Clipless
    * Stem: Kona XC/Road 90mm
    * Handlebar: Kona XC/BC Riser 710mm
    * Seatpost: Kona Double Clamp w/offset 31.6, 375mm
    * Saddle: WTB Silverado
    * Bottom Bracket: Shimano
    * Cassette: Shimnao SLX
    * Headset: FSA No.57E
    * Grips: Kona Race Light LOG
    * Front Tire: Maxxis Ardent 26x2.25 Kevlar
    * Front Rim: Easton XC
    * Front Hub/Skewer: Easton XC, 15mm
    * Rear Tire: Maxxis Ardent 26x2.25 Kevlar
    * Rear Rim: Easton XC
    * Rear Hub/Skewer: Easton XC, 142mm
    * Weight: 13,8kg
  2. #6877
    Awesome pics!
  3. #6878
    Quote Originally Posted by general lee View Post
    Very sharp bike
    http://kevinboyer.zenfolio.com/
    *2015 Knolly Warden...Custom Build*
    *2014 Knolly Endorphin...Custom Build*
  4. #6879
    Reputation: fujiblue1's Avatar
    My almost finish all-mountain setup...just need to dial in the drivetrain and take a test spin....
    Attached Thumbnails Attached Thumbnails Let's see those AM setups-5z6a3655.jpg
    2014 Specialized Enduro S-Works
    2012 Specialized SJ FSR Elite
    2012 DB Scapegoat
    2012 Canfield Yelli Screamy 25.8lbs
  5. #6880
    Gave my Nuke a little update
    XT Shadow+ derailleur
    Lyrik RC2DH solo-air
    Spank Spike pedals
    Yellowish cable hoses
    Coil Vanilla R for winter time
  6. #6881
    Reputation: Fix the Spade's Avatar
    I want that atomic banana!
  7. #6882
    Livestrong colors.
  8. #6883
    father, mountain biker
    Reputation: shredjunkie's Avatar
    May 2012
    Quote Originally Posted by Mountain Cycle Shawn View Post
    Livestrong colors.
    That bike has definitely been doping.
    "He seems quite arrogant and ignores quite some valid points." -Millfox
    "I don't like you" -ne_dan
  9. #6884
    LMAO! It's just plain dope!
  10. #6885
    Reputation: socalMX's Avatar
    My latest build, had several Nomads and still have my Yeti ASR-7! This custom painted carbon Remedy will be the lightest at 28.5lbs with a dropper post! Thought it would be funny to post this pic, almost done!!!
    Attached Thumbnails Attached Thumbnails Let's see those AM setups-remedy5.jpg
  11. #6886
    meow meow
    Reputation: b-kul's Avatar
    looks pretty tooting saweet!
  12. #6887
    Levi Early
    Reputation: Levi707's Avatar
    Trek Scratch 8. Built this up with parts left over after selling off my ibis mojo hd
    Frame Size & Color: Large (virtual 17.5)
    * Fork: fox van 36 (would love to upgrade the guts of this fork or get a new one entirely to save weight)
    * Brakes: avid elixer cr
    * Cranks: sram x0
    * Front Derailleur: sram x0
    * Rear Derailleur: sram x9
    * Pedals:shimano xt trail
    * Stem: bontrager rxl
    * Handlebar: easton havoc
    * Seatpost: ibis or reverb. depending on time of year and riding area
    * Saddle: bontrager affinity rxl ti rail
    * Bottom Bracket: sram gxp
    * Cassette: shimano xt 11-36
    * Headset: fsa
    * Grips: bontrager
    * Front Tire: bontrager team issue fr4
    * Front Rim: stans flow ex
    * Front Hub/Skewer: ibis (novatec i believe)
    * Rear Tire:bontrager team issue fr4
    * Rear Rim:stans flow ex
    * Rear Hub/Skewer ibis
    * Weight 30lbs flat without reverb, 31 with reverb
  13. #6888
    I need tyres like the ones on that Remedy!!!!
  14. #6889
    Quote Originally Posted by Tomsson View Post
    Spank Spike pedals
    What rear shock is that?
  15. #6890
    Quote Originally Posted by prancisfena View Post
    Fox Vanilla R.
    Simple coil for the winter time.
  16. #6891
    Reputation: roxtar's Avatar
    Quote Originally Posted by socalMX View Post
    I don't know, call me old school but I just don't see removing the tires as a good way to save weight.
    Democracy is two wolves and a sheep voting on what's for dinner.
    Liberty is a well armed sheep, contesting the vote.
  17. #6892
    May 2012
    My Specialized Enduro
    This my 2010 XL Specialized Enduro Expert. I upgraded the front fork to a Solo Air DH damper Totem 180mm. I added a red azonic outlaw wheel set. Vector R rear coil 600lb spring. I also machined and welded custom braces on the rear shock links (not in photos) for added stiffness. Sram XO drivtrain and Avid elixir cr brakes. This is the freeride enduro build.
    Attached Thumbnails Attached Thumbnails Let's see those AM setups-2012-11-21-16.57.41.jpg
  18. #6893
    May 2012
    More pics
    A couple more pics of the bike and the fabricated pieces.
    Attached Thumbnails Attached Thumbnails Let's see those AM setups-2012-12-15-13.28.52.jpg
  19. #6894
    GAME ON!
    if that fork was black... oh, man.
    RIP Adam Yauch
    "M.C. for what I AM and do, the A is for Adam and the lyrics; true"
  20. #6895
    May 2012
    Quote Originally Posted by saturnine View Post
    I kind of like it in white. It makes those huge 40mm stanchions stand out. Did you catch the moustache on the front of the fork? There are some pretty unique stickers on that thing.
  21. #6896
    meow meow
    do those additions on the linkage really make the bike noticably stiffer?
  22. #6897
    May 2012
    Quote Originally Posted by b-kul View Post
    The bike would be unridable without them. The links for the air shock that originally went on this bike had some really beefy links. Then Specialized did what they do and messed up on the design of these evo links by not adding any beaming? strength. If you saw the links side by side you would know exactly what im talking about. So me being 6"4" 220Lbs without gear and a very aggressive rider puts a pretty big toll on my bikes. The evo links would bend on any jump and that bend would then force those bearings out of place. I tried reloctiting the bearings with the green bearing retainer, but that did not do the trick. So the only solution left was to beef up these links and by doing this it stopped all bend at that area. I was very hesitant on doing this though because i did not know if these pieces were cast aluminum. Because cast aluminum might warp when being welded due to the heat. But it all turned out fine and the bike is stronger than ever! It was funny, i took the bike into my LBS wanting ask there opinion. Apparently the guy i talked to had his common sense removed for a while now because i spent more time explaining what was wrong with my bike than him giving solutions (zero to be exact). The bike shop is good for BIKE only stuff. Like wheel trues and things like that. But as soon as there is something like an engineering flaw they give you that "deer in the headlights" look. Sorry about the rant, but to answer your question, yes they make the bike much stiffer.
  23. #6898
    Fox Vanilla R.
    OH. Kinda looked like one of those supermarket bike shocks... all because it didn't have the piggy back air/oil can that I'm used to seeing on coil shocks.
  24. #6899
    meow meow
    Quote Originally Posted by Gawdodirt View Post
    dude, thats pretty crazy. props on some ghetto backyard engineering.
  25. #6900
    2011 Marin Mount Vision XM9
    Fox Float Fit RLC 140mm / Float 140mm rear
    SRAM XX1
    Hope EVO II hubs, WTB Frequency i23 rims
    Conti Rubber Queen (Trail King?) 2.2 UST
    Formula The One 203/180mm discs
    CB Kronolog
    Pics of today, testing XX1 for the first time.....like, like, like
Follow MTBR on Facebook
