Page 275 of 357 FirstFirst ... 175 225 265 271 272 273 274 275 276 277 278 279 285 325 ... LastLast
Results 6,851 to 6,875 of 8903
  1. #6851
    Quote Originally Posted by X-FXR View Post
    This pic is the same spot with my FXR.
    Yep, looking a little bit more to the north now. What a great view!
  2. #6852
    Oct 2011
    Quote Originally Posted by b-kul View Post
    ahaha brainfart! it was a large.
    hehe Thanx!
  3. #6853
    nomad carbon 2013
    Fresh build
    Attached Thumbnails Attached Thumbnails Let's see those AM setups-img_0262.jpg
  4. #6854
    meow meow
    Reputation: b-kul's Avatar
    dude, that is incredibly sick! where did you get the purple mallets?
  5. #6855
    That is the raddest Nomad I have seen!
  6. #6856
    Quote Originally Posted by longboarderj View Post
    Raddest: To be more radical then normally thought possible by non-rad people.
  7. #6857
    Dec 2010
    LOL...I find that there are too much green in there...
  8. #6858
    You must be Rad to use a word like Raddest or own this jersey:
  9. #6859
    Just picked this up.
    2011 Jamas Dakar XCT1
  10. #6860
    evolution
    a bit of progression over the past couple of years.
    these bikes gave up their lives in search of the 'mean green'
    for some reason it wont let me upload a jpeg of the alpine which was after the remedy.
    Attached Thumbnails Attached Thumbnails Let's see those AM setups-remedy1.jpg
  11. #6861
    GAME ON!
    your mojo was badass. not sure if this is an upgrade. bos and ccdb would likely be near the top of everyone's want list.
    RIP Adam Yauch
    "M.C. for what I AM and do, the A is for Adam and the lyrics; true"
  12. #6862
    true, ore of a sideways movement and i do miss the mojo hd. It was more lively and a better all day bike than the nomad but ive now sold my dh bikes and fancied a nomad to cover all bases. plus i just fancied a refresh.
    the nomad is in early stages at the mo, it may get a push link and coil soon.
  13. #6863
    RideDirt
    Reputation: aedubber's Avatar
    Yea ill have to second that i am in favor of the Mojo , looks stunning and great build
  14. #6864
    GAME ON!
    i just wonder if you could elaborate what the nomad does better/differently than the mojo? there seems to be quite a bit of overlap in their capabilities.
    RIP Adam Yauch
  15. #6865
    Reputation: socalMX's Avatar
    Quote Originally Posted by saturnine View Post
    I have owned both as well and to me the HD had a slight nod climbing but the Nomad (mine was carbon with Push link/Ti-RC4) just killed the HD everywhere else! Fast flowy singletrack, jumping, and DH! Im riding a Yeti ASR-7 now and surprisingly it is more fun to ride than both!!!
  16. #6866
    @ waldo1, im building a carbon Remedy for a lighter XC/AM bike (keeping the Yeti for the more FR/DH duties)...I have never been on a Remedy, this should be about 26lbs...How did you like yours?
  17. #6867
    The mojo has a shorter rear end and importantly, with dw link it sits higher in it's travel. The bos deville 170 were about 400gs lighter than the 55rc3 evo ti. I was also running 35mm stem with high rise renthals. All this made it very snappy,easy to lift the front, with quick direction changes.
    The vpp sits quite deep into the travel has a longer rear and about 35mm longer wb. I'm running a- 2deg zero stack headset too. This thing is soo stable at high speed, but surprisingly, was perfect around a VERY tight, twisty dh the other day. The mojo climbed better but not by a huge amount.
    The remedy was really good, bit fragile, but is still going strong in the hands of my mate and he has the finesse of an elephant. I bought a size too small for me so sold it.
    The mojo has a half inch longer seat tube than the nomad and with the dw sitting higher, I found the saddle was in the way a bit on the downs.
    Ultimately, I just fancied a change.
  18. #6868
    GAME ON!
    how's the deville compared to the 55?
    RIP Adam Yauch
  19. #6869
    Id like more time to let the 55 bed in, get used to it then form an opinion.
    So far the 55 is very controlled, smooths out everything and tracks brilliantly. It sits into it's travel nicely when climbing which helps keep the front down.
    The deville is an amazing fork with outstanding damping and control. Also it weighs less than nats pube and is very reliable.
    The annoying thing with the 55 is that the low and high speed compression are both adjusted by one dial with an air loaded cartridge. I've emptied this of air ATM...... so smooth.
  20. #6870
    Dec 2010
    Updated with Truvativ HammerSchmidt AM Crank...
    More to come..
  21. #6871
    Nice Nomad. Lower wider bars & remove some spacers to lower the front end.
  22. #6872
    Dec 2010
    Quote Originally Posted by socalMX View Post
    In fact, I am changing to Renthal high rise and stem as I am keeping it high...trying some configuration...
    My bar is 740mm now and I think any wider I will have problems in the woods...
  23. #6873
    somehow still alive
    Reputation: Hollyw00d's Avatar
    Oct 2012
    Quote Originally Posted by Alex31 View Post
    I'm at 780mm.. It gets tight, but so far not too tight
    Not what you think.
    My videos
  24. #6874
  25. #6875
    Quote Originally Posted by Hollyw00d View Post
    I'm at 800 and more often than not clip trees. It's like dropping an anchor at mach 3.
    would like more rise though, but theres only one option with Easton 35.
    still keeping them though.
