Page 270 of 376 FirstFirst ... 170 220 260 266 267 268 269 270 271 272 273 274 280 320 370 ... LastLast
Results 6,726 to 6,750 of 9394
  1. #6726
    My littleTransition Bandit with a few extras.
  2. #6727
    Mar 2012
    ^ Wouldn't have thought I'd enjoy a purely black and white theme so much but that is very very nice!
  3. #6728
    Reputation: Luigiugueto's Avatar
    Oct 2007
    Quote Originally Posted by svalgis View Post
    +!, VERY nice looking bandit. Now I wanna upgrade mine lol...
  4. #6729
    Mar 2012
    An event we had over this past weekend.
    Yew Tee Flat Out Challenge 2012
    Singapore
    18 Nov 2012
    A view of the lap from my friend's Helmet Cam.
    <iframe width="560" height="315" src="http://www.youtube.com/embed/VNo_wN0xLEU" frameborder="0" allowfullscreen></iframe>
  5. #6730
    Reputation: d.n.s's Avatar
    What's the bike?
    I'm from Ukraine, Kiev
    I'm graphics and web designer
    Follow me on Behance
  6. #6731
    Mar 2012
    Quote Originally Posted by d.n.s View Post
    What's the bike?
    INTENSE Uzzi 2012/13
  7. #6732
    Good job! Knolly Chilcotin Build
    * Frame Size & Color: Large Black
    * Rear Shock: Avalanche Woodie 500# Spring
    * Fork: Lyrik Two Step Air Taper with Avalanche Cartridge
    * Brakes: Magura MT6 with SL rotors 203mm (f)/180mm (r)
    * Shifter: SRAM X9 9 Speed
    * Cranks: Shimano Saint
    * Chainring: e*thirteen 35t
    * Chainguide: MRP mini-G SL
    * Rear Derailleur: SRAM X9 super short
    * Pedals: Canfield Bros. Ultimate
    * Stem: 40mm Truvativ (placeholder?)
    * Handlebar: Chromag Fubar OSX 760
    * Seatpost: Rockshox Reverb (getting refurb'd at the moment)
    * Saddle: Chromag Lynx DT
    * Cassette: Shimano XT 11-34
    * Headset: Cane Creek 40
    * Grips: Rogue
    * Front Tire: Specialized Butcher SX 2.3
    * Front Rim: Stans Flow ZTR
    * Front Hub: Hadley
    * Rear Tire: Fat Albert 2.4
    * Rear Rim: Stans Flow ZTR
    * Rear Hub: Hadley
  8. #6733
    ^ That's a mean rig. It looks like nothing can destroy it.
  9. #6734
    meh?
    Reputation: Map204's Avatar
    May 2012
    This bike looks great. 3 things I like: black on black "stealth" graphics on the frame, white Lyrik, green chainguide.
    Quote Originally Posted by CharacterZero View Post
    * Grips: Rogue
    * Front Hub: Hadley
    * Rear Hub: Hadley
    2013 Chromag Rootdown
    2010 SC Chameleon
    2001 Specalized Rockhopper FSR
  10. #6735
    Nov 2007
  11. #6736
    Reputation: crank1979's Avatar
    Feb 2006
    Quote Originally Posted by DocGold View Post
    Liteville 601
    What travel setting are you using? How does it ride compared to the 301?
  12. #6737
    Dec 2011
    I am loving the square looking tubing on the frame it looks so clean
    * Grips: Rogue
    * Front Hub: Hadley
    * Rear Hub: Hadley
  13. #6738
    * Grips: Rogue
    * Front Hub: Hadley
    * Rear Hub: Hadley
    can you tell us something about the Avalanche Cartridge on your fork, how does if feels?
  14. #6739
    Reputation: Opinions's Avatar
    Sep 2012
    That Knolly is so sexy.... I love the square tubing.
  15. #6740
    Nov 2012
    Those Knolly looks so YAMMI
  16. #6741
  17. #6742
    Reputation: sikkfreerider's Avatar
    Nov 2006
    heres my Tallboy LT! love this bike!
    it's not about how LONG your travel is... its's how well you use it!
  18. #6743
    Trek Remedy 9.9
    Frame: 2012 Trek Remedy OCLV Mountain
    Front Shock: Fox Float 32 FIT DRCV 150mm
    Rear Shock: Fox Float RP2 DRCV with Kashima
    Stem: Bontrager Rhythm Pro
    Bars: Bontrager Race X Lite Carbon Low Riser
    Brakes: SRAM XX
    Cranks: XX 39/26
    Pedals: Shimano XTR
    Front Shifter: SRAM XX
    Rear Shifter SRAM XX
    RD: SRAM XX
    FD: SRAM X0 (direct mount)
    Casette: SRAM XX 11-36
    Wheels: DT Swiss 1550 Tricon
    Tires: Bontrager XR4 Team
    Post: RockShox Reverb Stealth
    Saddle: Bontrager Evoke RXL
    Weight: 11.7kg
    Really enjoying the go anywhere do anything nature of this bike. It can really step up when you need it to... This bike is helping me take my riding further.
  19. #6744
    meh?
    May 2012
    Quote Originally Posted by sikkfreerider View Post
    Very nice
    2010 SC Chameleon
  20. #6745
    whoa. very, very nice indeed. good job!
  21. #6746
    My Nickel just go a little more AM.
    With a new 150mm RS Revolution RL Dual Air. And, a RS Monarch RT3, 200x 57mm to replace the crappy Fox RL 200 x 50 mm. It now weights just a tiny bit under 27 pounds. I took the first ride this morning with the new suspension and it rides really nice! The Monarch is 100% better then the Fox shock. I call it a Nickel LT. It no has 142 mm of travel in the rear instead of the stock 125 mm.
  22. #6747
    thanks
    Quote Originally Posted by Map204 View Post
    Thanks guys! The bars are Fubar OSX - green too.
    Quote Originally Posted by WarBoom View Post
    Yeah, the squuur makes it look as stiff as it rides.
    Quote Originally Posted by dhoby View Post
    So far, so good. Coming from a 66RC3Ti, but I do have much time on the Lyrik Coil, Lyrik RC2DH and Totem SoloAir with the modded mico damper. Any hangups with the current performance haven't been dialed out just yet, but I've played with settings very little. Trying to spend some time adjusting to the new bike/geometry before fiddling too much and spending a day doing bracketing runs, which will probably come this weekend.
    The only thing that I'm not sure I like (and to Craig@AVY's point) - air forks probably aren't for me. I don't like compromises and since I am 215lb, the air fork simply isn't optimal. Now, while the air fork is stiff and responsive in the slower stuff (and doesn't dive at all), it really shines once you get it over about 10mph.
    Disclaimer: This fork was purchased config'd for another rider that has a similar weight to mine. I think he had it enduro tuned, which is for stable climbing up and open bombing down, which makes sense. His conditions around Northern Cali probably aren't quite like Central Texas, so take my sentiments with a grain.
  23. #6748
    GAME ON!
    Quote Originally Posted by Mountain Cycle Shawn View Post
    schweet! i bet you get a lot of comments on your saddle. actually, i know you do as i have a spyder on 2 bikes and i get them all the time
    RIP Adam Yauch
    "M.C. for what I AM and do, the A is for Adam and the lyrics; true"
  24. #6749
    Quote Originally Posted by saturnine View Post
    It's the most comfortable saddle I have ever had. One time I forgot to put my padded shorts under my baggies and I didn't realize it till I got home.
  25. #6750
    You ass must have looked like a waffle.
