AM Southern Hemisphere Style
* Frame Size & Color: Large '04 Yeti 575
* Fork: Manitou Nixon Platinum
* Brakes: Avid Juicy 7's 180/160 rotors
* Cranks: 180mm Race Face Atlas
* Front Derailleur: XT
* Rear Derailleur: XT
* Pedals: Crank Bros Eggs
* Stem: Thomson
* Handlebar: Azonic
* Seatpost: Thomson
* Saddle: Flite Transalp
* Bottom Bracket: Race Face
* Cassette: XT 11-32
* Headset: King
* Grips: ODI lock-on Yeti
* Front Tire: Kenda Kinetics UST
* Front Rim: Mavic X3.1
* Front Hub/Skewer: Hadley 20mm thru axle
* Rear Tire: Kenda Kinetics UST
* Rear Rim: Mavic X3.1
* Rear Hub/Skewer: Hadley/XTR
* Weight: No idea
El-Cheepo
Originally Posted by
SSINGA
This is where you can post your static couch or garage shots of your ride. Please list setup specs.
Here is a template for you to cut and paste:
* Frame Size & Color:17 black/Grey
* Fork:Marz FR3
* Brakes:Magura Louise FR
* Cranks:FSA carbon
* Front Derailleur:Sram Gen-X
* Rear Derailleur:Sram X-7
* Pedals:HaHaHa!Performance flats,first flats,went cheep to try them out,love'em
* Stem:FSA FR 220,60mm
* Handlebar:FSA K-Force 31.8
* Seatpost:Easton carbon
* Saddle:Titec Berserkr K/Ti
* Bottom Bracket:FSA Plat
* Cassette:Sram
* Headset:Pig
* Grips:Sram
* Front Tire:Azonic Vigilante
* Front Rim:Mavic 321
* Front Hub/Skewer:Marz 20mm
* Rear Tire:Arrow Racing Blitz 24"
* Rear Rim:Vuelta DH 24"
* Rear Hub/Skewer
* Weight
around 35#
Ended coasting a little more than I thought.Like 1500 or something.But I love it!It's a little slack.But you can do 30 on a skinny trail.Very stable.Real fun over rollers.Stops on a dime.Not to heavy to pedal up.And I'm gettin' up there.
Reason: photo
Meh.
Interlectchewal
On One Inbred 456
SSINGA
This is where you can post your static [faded]
couch or garage shots of your [imaginary] ride. Please list setup specs.
Here is a
I got the frame a week ago (Big thanks to Bikeroom ! ) and was planning to start building it up next week. I ended up getting a new singlespeed a couple of days ago, so the 456 build is going to have to wait a while. I'll probably pick up this kit to start.
Here is the proposed build. Where available, all parts will be silver or white. [SIZE=1]Specs subject to change due to poverty.[/SIZE]
* Frame Size & Color: On One Inbred 456 , 18", That Green
* Fork: Pike 426
* Brakes: Avid Juicy 7 , 185mm
* Cranks: RaceFace Atlas with e.13 Super Charger Bashguard
* Front Derailleur: SRAM X-Gen
* Rear Derailleur: SRAM X-9
* Pedals: Crank Bros Mallet C
* Stem: Thomson Elite X4 or Hope
* Handlebar: RaceFace Deus Low Riser , 31.8
* Seatpost: Thomson Elite , 27.2 x 410
* Saddle: WTB Pure V SLT
* Bottom Bracket: RaceFace X-Type
* Cassette: SRAM PG-990
* Headset: Hope or RaceFace or King
* Grips: Oury
* Front Tire: Kenda Nevegal Stick-E 2.3
* Front Rim: ??
* Front Hub/Skewer: Hope Pro II 20mm / RockShox Maxle
* Rear Tire: Kenda Nevegal Stick-E 2.3
* Rear Rim: ??
* Rear Hub/Skewer: Hope Pro II
* Weight: ??
Had her about a month and lovin it! Not sold on the DHXair (not getting close to full travel) may go coil. But she feels oh so good
Frame: '06 Semi-custom El Saltamontes in a x-5 jig
Seat tube:19.5
Top tube: 23.8
Head tube: 5.25
El Cap Head tube gussets
Color: Gloss black
Options: 5/6" Rockers, quad bearings ( in 5" mode)
Shock: Fox DHX Air
Fork: '06 Fox 130 RLC Vanilla (Pushed)
Wheelset: Chris King ISO Black 32 Hole/Mavic F519/WS 14/15 DB Black spokes, Silver Brass Nipples
Skewers: Hope
Seatpost Clamp: Stock
Front Der: XT
Rear Der: XT
Shifters: LX (tuned, no indicators)
Chain: SRAM PC-991
Cassette: Shimano XTR 11-34
Brakes: Avid JuicyCarbon 7" front 6" Rear Rotors
Cranks/BB: XT 175mm 32/22 With Raceface bash ring
Pedals: Tioga sealed
Headset: Chris King NoThread Black
Handlebar: Easton Mid Riser
Seat Post: 27.2 Gravity Post (Frame has custom zip/boss for cable)
Stem: 90x 5 Thomson Elite Black
Saddle: WTB Pure Ti (older model but nice and broke in)
Grips: Oury Black
Front Tire: Kenda Negal 2.35 sticky
Rear Tire: Kenda Negal 2.35 DC
Accesories: Cat-Eye Mity 8, Lizard skin chainstay pad, few Ti bits
Weight: 30.5 lbs. using cheap bath scale
m-dub
Try swapping out the DHX-A air can with one from an RP3. About $38 from Fox. Maybe MK can repost his how to thread over here.
SSINGA
Thanks, I would like to hear more on that.
I already rode that
AM, XC all the same to me.
my 2004 weyless xp, small frame, Hayes 9XC (8 in front, 6 in rear), 2005 Marzocchi Z1 FR3, 5th element air, lock on grips, 32T chain ring, raceface bashguard, hydrid Heim/MRP chain guide with modified J-stop on top....over 3000 miles...bike thumps
http://s77.photobucket.com/albums/j5...ane/weylessxp/
"He can make even a global summit meeting seem like a kegger." M. Dowd, NY Times, 19 July 2006
try this again:
All Mountain Rider
Ah i know its cheep but i got it for free and upgreading what i brake, or bend. this is what its like now.
* Frame Size & Color: 20.5 in Mat navy blue white and red
* Fork: SR Suntour XC 60
* Brakes: Promax DSK 610J
* Cranks: TruVativ ISOFLOW, 22/32/42T
* Front Derailleur: Shimano Acera, 31.8mm top pull
* Rear Derailleur: Shimano Alivio
* Pedals: SINZ Pro platform
* Stem: Forged Aluminum w/ removable faceplate
* Handlebar: Aluminum Flatbar
* Seatpost: Aluminum micro-adjust, 350mm
* Saddle: WTB Speed V Spor
* Bottom Bracket: Sealed Cartridge, 113mm
* Cassette: Shimano HG 30-11T
* Headset: Ritchey Logic Zero Pro 30mm spacers
* Grips: Kraton dual density gel
* Front Tire: WTB Velociraptor, 26 x 2.1"
* Front Rim: Alex DP-17 Double Wall Al Disc
* Front Hub/Skewer: Sealed Bearing Disc, 32H
* Rear Tire: WTB Velociraptor, 26 x 2.1"
* Rear Rim: Alex DP-17 Double Wall Al Disc
* Rear Hub/Skewer Sealed Bearing Disc, 32H
* Weight 25.5 pounds
Some great bikes here!
My Heckler:
* Frame Size & Color: Medium, Ano Gold '03, with 2.25" stroke 5th coil (just rebuilt - pic has 2" stroke in it)
* Fork: '05 Z1 FR1
* Brakes: XT 4 pot, 8" rotors
* Cranks: Hone
* Front Derailleur: Deore
* Rear Derailleur: XTR rapid rise
* Pedals: Old school M636s
* Stem: Thomson 70mm, 0 deg rise
* Handlebar: Answer Protaper
* Seatpost: Thomson
* Saddle: SDG Bel Air (not shown)
* Bottom Bracket: Hone
* Cassette: XT
* Headset: Hope
* Grips: Yeti Lock-ons
* Tyres: 2.1" Tioga Factory DHs (old...)
* Rims: Mavic F219
* Front Hub: AC
* Rear Hubr: Ringle
* Weight: 15kg (lbs??? bah!)
ride hard take risks
Frame Size & Color: Versus Blitz, med, stealth black
* Fork: Manitou FireFly '05
* Brakes: Hayes HFX-Mag
* Cranks: Race Face
* Pedals: Easton flats
* Stem: Race Face Diabolus
* Handlebar: Answer ProTapper
* Seatpost: Race Face Diabolus
* Saddle: WTB DH Ti rails
* Cassette: Sram
* Headset: Aheadset
* Grips: Lizzard Skinz Moab clamp on
* Front Tire: WTB Timberwolf
* Front Rim: WTB Lazer Disc DH
* Front Hub/Skewer: WTB Lazer Lite/20mm through axle
* Rear Tire: Maxxis HighRoller 2.35
* Rear Rim: WTB Lazer Disc DH
* Rear Hub/Skewer WTB Lazer Lite/XT
* Weight 39.65
Whyte46
Frame Size & Colour: Medium/silver (polished look)
* Fork: Maverick DUC32
* Brakes: Hope M4's 200/180 floating rotors
* Brake lines: Goodridge
* Cranks: 06 XT
* Front Derailleur: 06 XT
* Rear Derailleur: 06 XT
* Pedals: Eggbeaters
* Stem: Maverick intergrated adjustable length,100mm/110mm
* Handlebar: Easton monkeylite carbon O/S
* Seatpost: Whyte (going to change to Easton EC70 carbon) retained by Whyte's Getta-Grip system
* Saddle: SDG Ti railed
* Bottom Bracket: 06 XT intergrated
* Cassette: 06 XT
* Headset: Canecreek S2
* Grips: Whyte lockon's
* Front Tire: Continental vapor kevlar bead 2.3 though I'm using 2.1
* Front Rim: Mavic X717 Disc
* Front Hub/Skewer: Maverick with 24mm axle
* Rear Tire: Continental vapor kevlar bead 2.3 though I'm using 2.1
* Rear Rim: Mavic X717 Disc
* Rear Hub/Skewer: Hope Pro with Ti freehub,Whyte biggripper axle system
* Weight: 28lbs
* Travel front: 6" adjustable to 4" on the fly
* Travel rear: 6" adjustable to 4" on the fly
* Rear shock: Custom Fox RP3
* R/suspension type: Whyte Quad link,intelligent wheel path system http://www.whytebikes.com/whyte/index.html
* Frame Size & Color: L/XL, silver
* Fork: '05 Pike Race x-firm spring
* Brakes: Hayes HFX-9 HD, 8" front, 6" rear rotors
* Cranks: XT Hollowtech II
* Front Derailleur: N-gear Jumpstop
* Rear Derailleur: X-7
* Pedals: Specialized Lo Pro Mag
* Stem: 60mm commençal
* Handlebar: FSA FR330, 680mm
* Seatpost: Commençal
* Saddle: SDG Slim Jim
* Bottom Bracket: XT
* Cassette: XT 11-34
* Headset: Chris King
* Grips: Commençal
* Front Tire: Continental Diesel Protection 2.5/Tioga White Tiger 2.5
* Front Rim: Sun Singletrack
* Front Hub/Skewer: Commençal, maxle
* Rear Tire: Maxxis High Roller 2.35 60a
* Rear Rim: Sun Singletrack
* Rear Hub/Skewer: Commençal, Salsa Flipoff
* Weight: 37lbs
Main ride
* Frame Size & Colour: Large SC Heckler, custom green
* Fork: Fox Talas 36RC2
* Brakes: Magura Louise FR (210mm/190mm)
* Cranks: RaceFace Northshore
* Pedals: Shimano PD647
* Stem: Thomson X4 70mm
* Handlebar: Easton EA70 Lo-Rise
* Seatpost: Thomson
* Saddle:Flite
* Cassette:XT 11-32
* Grips: Intense Lock-on
* Front Tyre: Intense CC2.25
* Front Rim: Mavic D321 (old style)
* Front Hub/Skewer: Bolt through
* Rear Tyre: Intense CC2.25
* Rear Rim: Mavic D321 (old style)
* Rear Hub/Skewer: XTR
* Weight: 33lbs (+/-)
Second Ride
Slightly more XC biased this one, but it's a tough old frame
* Frame Size & Colour: Large Dialled Bikes Prince Albert (MK1) Red
* Fork: Fox Talas RLC
* Brakes: Hayes Mag + GRC Levers (160mm/160mm)
* Cranks: XT
* Pedals: Shimano PD646
* Stem: Thomson Elite 90mm
* Handlebar: Easton EA70 Mid-Rise
* Seatpost: Thomson
* Saddle:Flite
* Cassette:XT 11-28 (8spd)
* Front Rim: Mavic F519
* Front Hub/Skewer: XT
* Rear Rim: Mavic F519
* Weight: 27.5lbs
Turner 5 spot
* Frame Size & Color: Large orange
* Fork: 05 pike team
* Brakes: formula oro
* Cranks: race face x-type
* Front Derailleur: xtr
* Rear Derailleur: sram xo
* Pedals: time atac
* Stem: thompson
* Handlebar: fsa dh carbon
* Seatpost: thompson
* Saddle: flite
* Bottom Bracket: x-type
* Cassette: xt
* Headset: king
* Grips: odi
* Front Tire: fat albert 2.35
* Front Rim: 819
* Front Hub/Skewer: king/20mm
* Rear Tire: fat albert 2.35
* Rear Rim: 819
* Rear Hub/Skewer:king/xt
*weighing in at 30.2
Alpine Rider (Italy)
* Frame Size & Color: Mde Damper Light , Medium ,anodized red http://www.mdebikes.com/home/MDEBIKES.htm
* Fork: Vanilla 130rlc
* Brakes: Xsiv 8 180mm (grimeca 8 relabed)
* Cranks: lx
* Shifters: x7
* Rear Derailleur: x7
* Pedals: sh540
* Stem: icon 9cm
* Handlebar: 3ttt wave
* Seatpost: fsa fr200
* Saddle: selle iralia slr gel fow
* Bottom Bracket: lx
* Cassette: x7
* Headset: thecno
* Grips: race face
* Front Tire: schwalbe albert front only
* Front Rim: ritchey girder sc
* Front Hub/Skewer: ritchey scraxle
* Rear Tire: continental vertical pro
* Rear Rim: mavic xm321
* Rear Hub/Skewer shimano xt
* Weight 30.9
Yet Another 575
Frame: Black 04 Yeti 575
Fork: Marzocchi AM SL 130-150
Bottom Bracket: Truvativ ISIS SL
Crankset:Truvativ Stylo SL w/ Race Face Bashguard X 32 X 22
Front Der: Shimano XT
Rear Der: Shimano XT
Shifters: Shimano LX
Cassette: Shimano XT 11-34
Headset: Cane Creek S2
Chain: Sram PG950
Hubs F/R: Arc Yeti/Shimano 525
Rims: Mavic 223
Skewers: Front Nashbar Bolt-on, Rear OEM
Tires: F- IRC Trailbear 2.25, R- Panaracer Cinder 2.25
Brakes/Lever: Hayes HFX-9 XC 6"
Handlebar: 05 Easton Monkeylite XC Carbon bar.
Stem:Truvativ Team 100mm 5 degree rise
Grips: Oury Odi Lock on
Saddle: Terry Zero
Seatpost: Thomson Elite 330m
Pedals: Eggbeater SL's
Seatpost Clamp: OEM
Weight: TBD
Florida Rider
derby
Added the Uzzi SL link and Nixon Elite wound down to 4.5 inch matching travel. Superb.
- ray
those fenders are fugly
Black Lion
* Frame Size & Color Iron Horse MKIII Team 19"
* Fork: 05 Pike Coil
* Brakes: Hayes 9 w/carbon levers
* Cranks: shimano XT w/ E13 32 bash
* Front Derailleur: Hone
* Rear Derailleur: Sram X9
* Pedals: Time
* Stem: Race Face Evolve 31.8
* Handlebar: Kona DH Primo 31.8
* Bottom Bracket: Shimano XT
* Cassette: Sram 12-34
* Headset: FSA internal
* Grips: Oury loc ons
* Front Tire: WTB Weirwolf 2.5 (varies per ride)
* Front Rim: Mavic DeeTracks
* Front Hub/Skewer: Mavic/ Maxle
* Rear Tire: Maxxis Hansventure 2.3
* Rear Rim: Mavic DeeTracks
* Rear Hub/Skewer Mavic/ 12mm bolt on
Might be a good idea to trim that rear derailleur cable... that looks sorta dangerous the way you have it. Nice ride... always liked the Hecklers.
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
Forum Rules
