Let's see those AM setups
Printable View
  • 09-14-2016
    welias
    First build finished.
  • 09-15-2016
    moefosho
    **Ibis Mojo HD3
    **Pike RCT3 160mm
    **Fox Float X2
    **KS Lev 150mm
    **DT Swiss XM1501 Wheelset dt 240 hubs
    **(tubeless) Hans Dampf 2.35
    **XT8000 Brakeset
    **Sram Carbon Crankset w/ Absolute black DM ring
    **XT 8000 11speed
    **Renthal Fatbar Carbon
    **Renthal Apex Stem 50mm
    **XTR pedals
    **Prologo Nago Evo X8 Nack carbon rails
    26.7lbs
    2012 Hungarian Vizsla
    **60lbs
    **Pure Muscle
    **loves trails
    Attachment 1094585
    Attachment 1094586
  • 09-18-2016
    mikkosan
    Just built up my Process 111. First time on wagon wheels and definitely loving the geo on this baby!
  • 09-25-2016
    GNU_BLIND
    New ride
    Nukeproof Mega 275
    Changed the handlebars out to 785/30 Funn
    Change the drivetrain to gx/xo
  • 09-26-2016
    aomanes99
    2005 Giant Reign 3
    Old but good. Its kinda geared towards XC while still being AM. I just bought it so still have to figure out what I'm doing with it and what the previous owner did. As you can tell i'm on a pretty tight budget.Attachment 1096349
    * Frame Size & Color: 2005 Giant reign 3 silver
    * Fork: Rockshox Psylo
    * Shock: Manitou Swinger
    * Brakes: Hayes Prime 203mm discs
    * Cranks: Shimano Deore Lx
    * Front Derailleur: Stock
    * Rear Derailleur: Shimano XTR
    * Pedals: DMR V8
    * Stem: giant ConnectAM 5
    * Handlebar: Raceface Turbine
    * Seatpost: Stock
    * Saddle: WTB Pure
    * Bottom Bracket: Stock
    * Cassette: Race Face Ride XC ISIS, 22/32/44 teeth
    * Headset: Aheadset
    * Grips: ODI Troy Lee Designs
    * Front Tire: Maxxis 2.35 DHF
    * Front Rim: Mavic X223 Disc
    * Front Hub/Skewer: Specialized Stout
    * Rear Tire: Maxxis 2.35 DHF
    * Rear Rim: Mavic X223 Disc
    * Rear Hub/Skewer: shimano FH-M525
    * Weight: 28-30
  • 09-26-2016
    bikeboardorblade
    I loved the Reign I had. A Command Post or Giant's dropper would add nicely to it. Both are good options that don't break the bank (for a dropper, at least).
  • 10-05-2016
    zbi701
    Replacing my Intense Carbine 26er after broke the rear triangle twice.
  • 10-07-2016
    tylerpier137
    Frame- Giant Trance XL
    Rear Shock- FOX Float CTD 200x51mm
    Fork- Marzocchi 350 CR 160mm
    Headset- FSA
    Handlebar- Race Face Atlas 780mm
    Stem- Thomson Elite X4 50mm
    Grips- Lizard Skins Logo Lock On Grips
    Brakes- Shimano Deore M615 F/203mm R/180mm
    Shifters- Shimano SLX 10 spd
    Rear Derailleur- Shimano SLX Shadow +
    Cranks- Shimano Slx
    Chainrings / Sprocket- Race Face Single Ring Narrow/Wide 32t
    Cassette / Rear Cog- OneUp Components 42T Shimano cassete
    Pedals- Race Face Chester
    Front Rim- Giant S-XC2
    Rear Rim- Giant S-XC2
    Hubs- Giant Tracker
    Front Tire- Maxxis Highroller II 3C 2.40
    Rear Tire- Maxxis Minion DHRII 2.4
    Saddle- Giant Contact
    Seatpost- Giant Contact SL Switch 100mm drop
  • 10-16-2016
    Quadro
    Patrol
    Patrol C medium.
    Shock PUSH ELEVENSIX
    Fork MANITOU MATTOC PRO 2
    Handlebar RENTHAL CARBON
    Stem RENTHAL APEX
    Headset HOPE
    Grips ESI CHUNKY
    Cassette SRAM X01
    Right Shifter SRAM X01
    Crankset SRAM X0 CARBON
    Rear Derailleur SRAM X01
    Chain SRAM XX1
    Pedals SHIMANO XT TRAIL
    Front Brake AVID X0 TRAIL
    Rear Brake AVID XO TRAIL
    Saddle ERGON SME3 PRO
    Seatpost RACE FACE TURBINE DROPPER
    Front Tire MAXXIS DHF 2.5 WITH HUCK NORRIS
    Rear Tire MAXXIS DHF 2.5 WITH HUCK NORRIS
    Wheels ACEBIKE CARBON RIMS SYNTACE HITORQUE MX HUBS
    Attachment 1100134
    Attachment 1100133
  • 10-16-2016
    Shredman69
    Nice ride. How much does it weigh?
  • 10-17-2016
    targnik
    Umm...
    You're not supposed to ask those sorts of questions in the AM forum ^^
    XC forum will be more your speed ;-P
    Sent from my kltedv using Tapatalk
  • 10-17-2016
    Quadro
    It's not the lightest build and I haven't measured it recently, but I reckon around 13.5 kg.
  • 10-17-2016
    syrous44
    Originally Posted by tylerpier137 View Post
    Frame-GiantTranceXL
    Rear Shock- FOXFloat CTD200x51mm
    Fork- Marzocchi350 CR160mm
    Headset-FSA
    Handlebar-Race FaceAtlas 780mm
    Stem-ThomsonElite X4 50mm
    Grips-Lizard SkinsLogo Lock On Grips
    Brakes-ShimanoDeore M615F/203mm R/180mm
    Shifters-ShimanoSLX 10 spd
    Rear Derailleur-ShimanoSLX Shadow +
    Cranks-ShimanoSlx
    Chainrings / Sprocket-Race FaceSingle Ring Narrow/Wide32t
    Cassette / Rear Cog-OneUp Components 42T Shimano cassete
    Pedals-Race FaceChester
    Front Rim-Giant S-XC2
    Rear Rim-Giant S-XC2
    Hubs- Giant Tracker
    Front Tire-MaxxisHighroller II 3C2.40
    Rear Tire-MaxxisMinion DHRII2.4
    Saddle-Giant Contact
    Seatpost-Giant Contact SL Switch100mm drop
    very nice Trance, I have the 2015 model.
    Sent from my LG-D852 using Tapatalk
  • 10-17-2016
    Shredman69
    Originally Posted by targnik View Post
    Umm...
    Only if it's a female bike.:skep:
  • 10-18-2016
    GNU_BLIND
    Just under 30lbs! My nukeproof mega 275 xl stock weight was about 34lbs...after new tires down to 33lbs...found a stoopid good deal on some SRAM rail 50's, hopefully that'll bring it down to 31lbs and change. Next upgrade will be replacing the nukeproof okla dropper that is 120g away from 2lbs itself. Then I might be able to actually ride my bike.
  • 10-18-2016
    passwordusername
    Patrol C medium.
    Stem RENTHAL APEX
    Headset HOPE
    Grips ESI CHUNKY
    Cassette SRAM X01
    Chain SRAM XX1
    Attachment 1100134
    Attachment 1100133
    I love how it looks with the Manitou fork and Push shock.
  • 11-29-2016
    matthelm1
    Norco Sight
  • 12-05-2016
    JPinReno
    2017 Diamondback Mission 1
    Noob to the forum, First Post.
    I've only had this bike for 3 weeks, dropper and fox float x remote rear shock in mail. I will probably upgrade the wheels next, or maybe a fox 36...
    Attachment 1108826
    FRAME: Mission All Mountain 27.5, 160mm 6061-T6 Weapons Grade Aluminum w/ Hydroformed Top Tube, Butted / Formed Down Tube / Seatstays, 1.5' Tapered Head Tube, Knuckle Box Technology, ISCG-05, 142x12mm E-Thru-axle Drop Out
    REAR SHOCK: Fox Float DPS, 3 Position Lever, 'LV' Eyelet, 8.5x2.5' Air, w/ Rebound Adjust
    FORK TYPE: Fox Performance 34 Float 27.5', 160mm Travel, Open Cartridge, 3 Position Lever w/ External Rebound Adjust, 1.5' Butted Alloy Tapered Steerer Tube, 34mm Easton Aluminum Stanchions, w/ 15mm Thru-axle
    HEADSET: FSA No-57E Taper 1.5 /1-1/8' Standard Cups, Sealed Cartridge
    CRANKS: Raceface Ride, 32T 'Narrow Wide' Single Ring
    SPROCKET:
    BOTTOM BRACKET: Raceface Outboard Bearing
    FRONT DERAILLEUR:
    REAR DERAILLEUR: SRAM NX X-Horizon, 11 Speed
    SHIFTER: SRAM NX 11 Speed X-Actuation Trigger
    COG SET: SRAM PG1130, 11 Speed, 11-42T
    CHAIN: KMC X11EL, 11 Speed
    FRONT HUB: 32h Alloy,15mm Thru-axle, Sealed Cartridge Bearing, w/ CNC Disc Mount
    REAR HUB: 32h Alloy, 142x12mm Thru-axle, 4 Sealed Cartridge Bearing, Cassette
    SPOKES: 14g Stainless Steel
    RIMS: Diamondback Blanchard 28R, Tubeless Compatible, 32h
    TIRES: WTB Vigilante Comp, 27.5x2.3'
    BRAKES: SRAM Level T Hydraulic Disc, w/ 180mm Front / 180mm Rear Centerline Rotors
    BRAKE LEVERS: SRAM Level Hydraulic Levers w/ Tooled Reach Adjust
    PEDALS: DB4L Alloy Platform w/ Replaceable Pins
    HANDLEBAR: DB35 Alloy, 780mm Wide, 15mm Rise, 35mm Bar Bore
    GRIPS: DB4L 'Lock on' 135mm Kraton
    STEM: DB35 Alloy, 50mm Reach, 35mm Bar Bore
    SEAT: WTB Volt Comp
    SEATPOST: DB Alloy Micro Adjust, 30.9mm
