Page 138 of 191 FirstFirst ... 3888128134135136137138139140141142148188 ... LastLast
Results 6,851 to 6,900 of 9507
  1. #6851
    Quote Originally Posted by X-FXR View Post
    This pic is the same spot with my FXR.
    Yep, looking a little bit more to the north now. What a great view!
  2. #6852
    Oct 2011
    Quote Originally Posted by b-kul View Post
    ahaha brainfart! it was a large.
    hehe Thanx!
  3. #6853
    nomad carbon 2013
    Fresh build
    Attached Thumbnails Attached Thumbnails Let's see those AM setups-img_0262.jpg
  4. #6854
    meow meow
    Reputation: b-kul's Avatar
    dude, that is incredibly sick! where did you get the purple mallets?
  5. #6855
    That is the raddest Nomad I have seen!
  6. #6856
    Quote Originally Posted by longboarderj View Post
    Raddest: To be more radical then normally thought possible by non-rad people.
  7. #6857
    Dec 2010
    LOL...I find that there are too much green in there...
  8. #6858
    You must be Rad to use a word like Raddest or own this jersey:
  9. #6859
    Just picked this up.
    2011 Jamas Dakar XCT1
  10. #6860
    evolution
    a bit of progression over the past couple of years.
    these bikes gave up their lives in search of the 'mean green'
    for some reason it wont let me upload a jpeg of the alpine which was after the remedy.
    Attached Thumbnails Attached Thumbnails Let's see those AM setups-remedy1.jpg
  11. #6861
    GAME ON!
    your mojo was badass. not sure if this is an upgrade. bos and ccdb would likely be near the top of everyone's want list.
    RIP Adam Yauch
    "M.C. for what I AM and do, the A is for Adam and the lyrics; true"
  12. #6862
    true, ore of a sideways movement and i do miss the mojo hd. It was more lively and a better all day bike than the nomad but ive now sold my dh bikes and fancied a nomad to cover all bases. plus i just fancied a refresh.
    the nomad is in early stages at the mo, it may get a push link and coil soon.
  13. #6863
    RideDirt
    Reputation: aedubber's Avatar
    Yea ill have to second that i am in favor of the Mojo , looks stunning and great build
  14. #6864
    GAME ON!
    i just wonder if you could elaborate what the nomad does better/differently than the mojo? there seems to be quite a bit of overlap in their capabilities.
    RIP Adam Yauch
  15. #6865
    Reputation: socalMX's Avatar
    Quote Originally Posted by saturnine View Post
    I have owned both as well and to me the HD had a slight nod climbing but the Nomad (mine was carbon with Push link/Ti-RC4) just killed the HD everywhere else! Fast flowy singletrack, jumping, and DH! Im riding a Yeti ASR-7 now and surprisingly it is more fun to ride than both!!!
  16. #6866
    @ waldo1, im building a carbon Remedy for a lighter XC/AM bike (keeping the Yeti for the more FR/DH duties)...I have never been on a Remedy, this should be about 26lbs...How did you like yours?
  17. #6867
    The mojo has a shorter rear end and importantly, with dw link it sits higher in it's travel. The bos deville 170 were about 400gs lighter than the 55rc3 evo ti. I was also running 35mm stem with high rise renthals. All this made it very snappy,easy to lift the front, with quick direction changes.
    The vpp sits quite deep into the travel has a longer rear and about 35mm longer wb. I'm running a- 2deg zero stack headset too. This thing is soo stable at high speed, but surprisingly, was perfect around a VERY tight, twisty dh the other day. The mojo climbed better but not by a huge amount.
    The remedy was really good, bit fragile, but is still going strong in the hands of my mate and he has the finesse of an elephant. I bought a size too small for me so sold it.
    The mojo has a half inch longer seat tube than the nomad and with the dw sitting higher, I found the saddle was in the way a bit on the downs.
    Ultimately, I just fancied a change.
  18. #6868
    GAME ON!
    how's the deville compared to the 55?
    RIP Adam Yauch
  19. #6869
    Id like more time to let the 55 bed in, get used to it then form an opinion.
    So far the 55 is very controlled, smooths out everything and tracks brilliantly. It sits into it's travel nicely when climbing which helps keep the front down.
    The deville is an amazing fork with outstanding damping and control. Also it weighs less than nats pube and is very reliable.
    The annoying thing with the 55 is that the low and high speed compression are both adjusted by one dial with an air loaded cartridge. I've emptied this of air ATM...... so smooth.
  20. #6870
    Dec 2010
    Updated with Truvativ HammerSchmidt AM Crank...
    More to come..
  21. #6871
    Nice Nomad. Lower wider bars & remove some spacers to lower the front end.
  22. #6872
    Dec 2010
    Quote Originally Posted by socalMX View Post
    In fact, I am changing to Renthal high rise and stem as I am keeping it high...trying some configuration...
    My bar is 740mm now and I think any wider I will have problems in the woods...
  23. #6873
    somehow still alive
    Reputation: Hollyw00d's Avatar
    Oct 2012
    Quote Originally Posted by Alex31 View Post
    I'm at 780mm.. It gets tight, but so far not too tight
    Not what you think.
    My videos
  24. #6874
  25. #6875
    Quote Originally Posted by Hollyw00d View Post
    I'm at 800 and more often than not clip trees. It's like dropping an anchor at mach 3.
    would like more rise though, but theres only one option with Easton 35.
    still keeping them though.
  26. #6876
    May 2010
    * Frame Size & Color: Material Kona Scandium 69 Butted Aluminum 100 -160mm travel
    * Fork: FOX 32 Talas RL 150mm w/15mm Kashima
    * Brakes: Shimano SLX
    * Cranks: Shimano M552
    * Front Derailleur: Shimnao SLX
    * Rear Derailleur: Shimano Deore XT Shadow SGS
    * Pedals: Shimano M530 Clipless
    * Stem: Kona XC/Road 90mm
    * Handlebar: Kona XC/BC Riser 710mm
    * Seatpost: Kona Double Clamp w/offset 31.6, 375mm
    * Saddle: WTB Silverado
    * Bottom Bracket: Shimano
    * Cassette: Shimnao SLX
    * Headset: FSA No.57E
    * Grips: Kona Race Light LOG
    * Front Tire: Maxxis Ardent 26x2.25 Kevlar
    * Front Rim: Easton XC
    * Front Hub/Skewer: Easton XC, 15mm
    * Rear Tire: Maxxis Ardent 26x2.25 Kevlar
    * Rear Rim: Easton XC
    * Rear Hub/Skewer: Easton XC, 142mm
    * Weight: 13,8kg
  27. #6877
    Awesome pics!
  28. #6878
    Quote Originally Posted by general lee View Post
    Very sharp bike
    *2015 Knolly Warden,Custom Build*
    *2014 Knolly Endorphin,Custom Build*
    *2016 Ibis Mojo HD3,Custom Build*
  29. #6879
    Reputation: fujiblue1's Avatar
    My almost finish all-mountain setup...just need to dial in the drivetrain and take a test spin....
    Attached Thumbnails Attached Thumbnails Let's see those AM setups-5z6a3655.jpg
    2014 Specialized Enduro S-Works
    2012 Specialized SJ FSR Elite
    2012 DB Scapegoat
    2012 Canfield Yelli Screamy 25.8lbs
  30. #6880
    Gave my Nuke a little update
    XT Shadow+ derailleur
    Lyrik RC2DH solo-air
    Spank Spike pedals
    Yellowish cable hoses
    Coil Vanilla R for winter time
  31. #6881
    Reputation: Fix the Spade's Avatar
    I want that atomic banana!
  32. #6882
    Livestrong colors.
  33. #6883
    father, mountain biker
    Reputation: shredjunkie's Avatar
    May 2012
    Quote Originally Posted by Mountain Cycle Shawn View Post
    Livestrong colors.
    That bike has definitely been doping.
    "He seems quite arrogant and ignores quite some valid points." -Millfox
    "I don't like you" -ne_dan
  34. #6884
    LMAO! It's just plain dope!
  35. #6885
    My latest build, had several Nomads and still have my Yeti ASR-7! This custom painted carbon Remedy will be the lightest at 28.5lbs with a dropper post! Thought it would be funny to post this pic, almost done!!!
    Attached Thumbnails Attached Thumbnails Let's see those AM setups-remedy5.jpg
  36. #6886
    meow meow
    looks pretty tooting saweet!
  37. #6887
    Levi Early
    Reputation: Levi707's Avatar
    Trek Scratch 8. Built this up with parts left over after selling off my ibis mojo hd
    Frame Size & Color: Large (virtual 17.5)
    * Fork: fox van 36 (would love to upgrade the guts of this fork or get a new one entirely to save weight)
    * Brakes: avid elixer cr
    * Cranks: sram x0
    * Front Derailleur: sram x0
    * Rear Derailleur: sram x9
    * Pedals:shimano xt trail
    * Stem: bontrager rxl
    * Handlebar: easton havoc
    * Seatpost: ibis or reverb. depending on time of year and riding area
    * Saddle: bontrager affinity rxl ti rail
    * Bottom Bracket: sram gxp
    * Cassette: shimano xt 11-36
    * Headset: fsa
    * Grips: bontrager
    * Front Tire: bontrager team issue fr4
    * Front Rim: stans flow ex
    * Front Hub/Skewer: ibis (novatec i believe)
    * Rear Tire:bontrager team issue fr4
    * Rear Rim:stans flow ex
    * Rear Hub/Skewer ibis
    * Weight 30lbs flat without reverb, 31 with reverb
  38. #6888
    I need tyres like the ones on that Remedy!!!!
  39. #6889
    Quote Originally Posted by Tomsson View Post
    Spank Spike pedals
    What rear shock is that?
  40. #6890
    Quote Originally Posted by prancisfena View Post
    Fox Vanilla R.
    Simple coil for the winter time.
  41. #6891
    Reputation: roxtar's Avatar
    I don't know, call me old school but I just don't see removing the tires as a good way to save weight.
    Democracy is two wolves and a sheep voting on what's for dinner.
    Liberty is a well armed sheep, contesting the vote.
  42. #6892
    May 2012
    My Specialized Enduro
    This my 2010 XL Specialized Enduro Expert. I upgraded the front fork to a Solo Air DH damper Totem 180mm. I added a red azonic outlaw wheel set. Vector R rear coil 600lb spring. I also machined and welded custom braces on the rear shock links (not in photos) for added stiffness. Sram XO drivtrain and Avid elixir cr brakes. This is the freeride enduro build.
    Attached Thumbnails Attached Thumbnails Let's see those AM setups-2012-11-21-16.57.41.jpg
  43. #6893
    May 2012
    More pics
    A couple more pics of the bike and the fabricated pieces.
    Attached Thumbnails Attached Thumbnails Let's see those AM setups-2012-12-15-13.28.52.jpg
  44. #6894
    GAME ON!
    if that fork was black... oh, man.
    RIP Adam Yauch
  45. #6895
    May 2012
    I kind of like it in white. It makes those huge 40mm stanchions stand out. Did you catch the moustache on the front of the fork? There are some pretty unique stickers on that thing.
  46. #6896
    meow meow
    do those additions on the linkage really make the bike noticably stiffer?
  47. #6897
    May 2012
    The bike would be unridable without them. The links for the air shock that originally went on this bike had some really beefy links. Then Specialized did what they do and messed up on the design of these evo links by not adding any beaming? strength. If you saw the links side by side you would know exactly what im talking about. So me being 6"4" 220Lbs without gear and a very aggressive rider puts a pretty big toll on my bikes. The evo links would bend on any jump and that bend would then force those bearings out of place. I tried reloctiting the bearings with the green bearing retainer, but that did not do the trick. So the only solution left was to beef up these links and by doing this it stopped all bend at that area. I was very hesitant on doing this though because i did not know if these pieces were cast aluminum. Because cast aluminum might warp when being welded due to the heat. But it all turned out fine and the bike is stronger than ever! It was funny, i took the bike into my LBS wanting ask there opinion. Apparently the guy i talked to had his common sense removed for a while now because i spent more time explaining what was wrong with my bike than him giving solutions (zero to be exact). The bike shop is good for BIKE only stuff. Like wheel trues and things like that. But as soon as there is something like an engineering flaw they give you that "deer in the headlights" look. Sorry about the rant, but to answer your question, yes they make the bike much stiffer.
  48. #6898
    Fox Vanilla R.
    OH. Kinda looked like one of those supermarket bike shocks... all because it didn't have the piggy back air/oil can that I'm used to seeing on coil shocks.
  49. #6899
    meow meow
    Quote Originally Posted by Gawdodirt View Post
    dude, thats pretty crazy. props on some ghetto backyard engineering.
  50. #6900
    2011 Marin Mount Vision XM9
    Fox Float Fit RLC 140mm / Float 140mm rear
    SRAM XX1
    Hope EVO II hubs, WTB Frequency i23 rims
    Conti Rubber Queen (Trail King?) 2.2 UST
    Formula The One 203/180mm discs
    CB Kronolog
    Pics of today, testing XX1 for the first time.....like, like, like
