Results 1 to 10 of 10
Thread: Ksh Am1000
    T.W.O
    Reputation: pfox90's Avatar
    Aug 2010
    Ksh Am1000
    I'm buying a frame for 200 from our states mountain biking forum. Anyone have this? How is it? Looking forward to building it up
    Dec 2005
    Do you mean a KHS? If you do looks like a solid frameset at a great price.
    Reputation: nagatahawk's Avatar
    I have had the 2006 for several years. It is definetly strong. and can take the abuse.
    It is kinda heavy, my build came out a 33 lbs. w/xtr cranks, pike, fox dhx coil and 1800 gram wheel set. descends well, you can adjust the rear at 4, 5 and 6 inchs. It should corners on rails. 180 switch backs are a blast! I run wtb weirwolf 2.3s they're great on dry dusty, wet roots , granite. not good in sticky mud.
    have fun!
    T.W.O
    Aug 2010
    Planning on building it up with a Marz 55 RV fork and some hayes stroker aces. I already have a 1x9 sram x9 set up on it.
    Reputation: mullen119's Avatar
    I would skip the 55rv. You can get a 55 tst2 or micro for great deals and you will be much happier with the performance.
    After a closer look, a khs am1000 is designed to fit a 130-140mm fork. At 160mm, a 55 will be to tall for the frame and cause you some problems.
    T.W.O
    Aug 2010
    whats a good fork with 140mm travel, 20mm axle? around 300 to 400?
    A lot of forks could fit the bill. A Marzochhi 44tst2 and sometimes micro ti can be had in that price range. You should be able to find a rock shox sektor RL, You might be able to find a Manitou Minute 140 for under 400.(no quick release 20mm axle, but still a 20mm axle). It really depends on what brand you are looking for. All the brands make decent stuff in your price range. I'm partial to Manitou myself.
    T.W.O
    Aug 2010
    Yeah I was researching the sektor.
