    Jan 2011
    KS Supernatural will not return all the way
    The seat post has been great for the last 6 months, but just the other day it decided to start not returning all the way. I locks out about 1.5 inches below where it should. Other than that it functions normally... Any ideas?
    Reputation: 11053's Avatar
    Have you been maintaining/servicing the post?
    They need cleaned and lubed every once in a while.
    Also, check the cable tension.
    Unless something is wrong with the cartridge, cleaning/lubing post and adjusting/replacing cable fix most performance issues.
    You need to use a light grease, something like Slick Honey.
    Jan 2013
    Quote Originally Posted by banebane View Post
    Try applying some grease and see if that helps.
    I have the same problem on an i950. I just serviced it and no change. It raises slowly and stops a bit before full return. Acts like it needs higher air pressure.
    Ideas? I'll probably send it back to KS for an overhaul
  1. KS Supernatural Problem?
    By Eclipsed in forum All Mountain
    Last Post: 09-28-2014, 07:50 PM
  2. KS Dropzone or Supernatural
    By CarolinaPanthers in forum All Mountain
    Last Post: 01-16-2014, 07:52 AM
  3. GD Turbo LP vs KS Supernatural 27.2
    By cr500taco in forum All Mountain
    Last Post: 08-24-2013, 03:19 PM
  4. KS Supernatural or Reverb?
    By jdspins9 in forum All Mountain
    Last Post: 04-07-2012, 10:03 PM
  5. Red Bull Supernatural
    By shimyshalka in forum Downhill - Freeride
    Last Post: 01-16-2012, 01:12 AM
