    MrR
    MrR is offline
    Kona Cadabra 2010 weight doubts
    Hi all,
    I was wondering if anyone of you ever weighed a Kona Cadabra 2010 (18"). I got my doubts about its weight, in the store I bought it, it weighed 13.6kg with some crappy flat pedals.
    In the meantime I upgraded the brakes to Avid Elixir 9s, which are considerably ligher than the stock Deore M575 brakes. I also replaced the rotors with HS1 180mm Avid rotors. Then I also put some light flat pedals on it, Nukeproof Electrons, which are lighter than the pedals they put on it in the store for me, so I could make a short testride.
    Then I borrowed my friend's weighing scale (a fish weighing scale, seems to be a pretty decent one), and when I weighed it, it showed me 14kg. So now I still don't know the weight. I know weight is just a number and a good physical condition is more important than a few grams less, yet I'd still would like to say below 14kg when I replace the seatpost by a dropper seatpost, which really should be on a Cadabra imo.
    My question, can anyone give me more clarity about the weight?
    Regards
    MrR
    MrR is offline
    I just read that 2010's Cadabra out of the box weight is 29.5lbs /13.38kg. I guess that's weighed without pedals. The nukeproof electrons are about 360gr/pair, which makes 13.74kg. That's still 260gr less than what my friend's scale showed me, and then I didn't even calculate the difference that the brake swap made.
    Any declarations for the difference?
    Aug 2013
    It could also be that your friend's scale is not as accurate as the store's. Or maybe the store's scale was off a bit.
    MrR
    MrR is offline
    That's true, although official specs from Kona come closer to what it weighed in the store. Not sure if companies specs are a bit on the lower side though. That's why I was hoping that another Cadabra owner weighed his/her bike (with an accurate scale).
  1. Kona Cadabra review
    By Tom Church in forum All Mountain
    Last Post: 07-21-2014, 08:43 AM
  2. Ellsworth Epiphany Vs. Kona Abra Cadabra
    By Casquete in forum Bike and Frame discussion
    Last Post: 10-19-2011, 10:39 AM
  3. Kona cadabra 2010 17" for 172cm rider
    By yesWiican in forum All Mountain
    Last Post: 10-04-2011, 01:42 AM
  4. Kona Abra Cadabra vs Ellsworth Epiphany
    Last Post: 09-19-2011, 10:06 PM
  5. Ellsworth Epiphany Vs. Kona Abra Cadabra
    Last Post: 09-12-2011, 10:16 PM
