Results 1 to 6 of 6
    mns
    mns is offline
    juicy & DOT 5.1 car brake fluid
    I have half a bottle DOT 5.1 brake fluid left from when I serviced my car.
    Can I use it in my juicy 7s?
    I guess it is the same as bike brake fluid but can anyone confirm it?
    Thanks in advance,
    Manos
    mns
    mns is offline
    a photo of the fluid
    Attached Thumbnails Attached Thumbnails juicy & DOT 5.1 car brake fluid-fluid.jpg
    Reputation: Neily03's Avatar
    Feb 2010
    There's no such thing as 'bike brake fluid'. As long as 5.1 is compatible with your brakes and the fluid that's already in there then yes.
    mtbr member extraordinair
    Reputation: Stupendous Man's Avatar
    Careful, I read that DOT 5.1 cannot be mixed with DOT 3/4.
    Something about one being silicon based and the other not.
    If I am not mistaken, bike brakes have the equivalent of DOT 3/4.
    Grit, spit, and a whole lot of duct tape!
    Rabid Lana fan
    If I'm not mistaken, I believe you're thinking of DOT 5 that is silicone based and not compatible with DOT 3/4.
    DOT 5.1 is not silicone based and therefore is compatible.
    rOCktoberfest 2015 pt I here
    rOCktoberfest 2015 pt II here
    Avid Disc Brake Bleed Kit:
    Let the air out of your Avid brakes with the Avid Disc Brake Bleed kit. Everything you need to bleed Avid brakes like a professional is included, from easy-to-follow instructions to specific tools.
    * Includes 2fl. oz. of DOT 5.1 brake fluid
    * Two syringes complete with fittings for caliper and lever
    * Torx wrench and flair nut tool for line bleeding and hose fittings
    * Extra hose barbs and compression fittings for adjusting line length
