Results 1 to 69 of 69
    Reputation: ColinL's Avatar
    Feb 2012
    Upset it's shocking how many forking people get these terms confused.
    Everyone, please. Forks and shocks are both pieces of suspension.
    A fork is always on the front of your bike because it is a suspension component connected with legs --or one leg, for a Lefty-- to a wheel. It looks like a fork, again except for a Lefty. The wheel is directly mounted to the fork.
    A shock is a device that connects the frame to a wheel via one or more linkages, and the linkages attach to the frame. This is true for the rear of a bicycle or for your car. The wheel is not directly mounted to a shock.
    Saying a rear shock or front fork is not only unnecessary, it's stupid. On a normal bicycle, there is one shock and one fork, and they are located in the rear and in the front of the bicycle, respectively.
    Calling a fork a shock, or a shock a fork, is also incorrect. Both forks and shocks contain springs, which may be of a variety of materials/types*, and usually but not always a damper. The spring carries the weight of the rider and bicycle. The damper, if present, absorbs energy from the spring so that its natural oscillation (movement up and down) is slowed, or damped. This is a very desirable feature for suspension but not technically required.
    *Springs may be elastomers, air, coiled metal, or leaf / arched metal.
    PLEASE use the correct terminology and encourage others to do so.
    Reputation: ride the biscuit's Avatar
    time to take a deep breath and step away from the internet
    Yes, yes, yes. You are gonna get flamed for this, as many people no longer see the need to explain things with proper terminology. Or take the time to learn a bit on their own. Those are usually the same people asking me to diagnose their broken bikes.
    In these situations I like to remind people that the purpose of language is communication. If you are not using the correct terminology, you will fail to effectively communicate your problem, question, complaint, or whatever. Please try to use the proper terminology and try not get defensive if someone corrects you. They are trying to help you.
    Feb 2012
    Quote Originally Posted by Scotth72 View Post
    shock and fork is pretty easy if people just take one moment to think, "which one of these looks like a (two-tined pickle) fork?"
    my favorite example of this, though, was when a friend was trying to reassemble something on his car that he shouldn't have attempted to fix in the first place. he was confused about "how this bolt attached through this thing into the other bolt."
    that's right, a bolt is a bolt, and a nut is also a bolt.
    Aug 2005
    This really bothers you this much?
    2016 Santa Cruz Hightower 29er
    2016 Chromag Surface 27.5+
    2013 Transition TransAM 29er
    2017 Motobecane Lurch FS 26 fat
    Feb 2012
    Quote Originally Posted by VTSession View Post
    I typed the first post in one shot, no edits, in 5 minutes. So, yes, it does bother me enough to spend 5 minutes. Obviously many people already know this, but I'm hoping that they will help others use the right terminology. It wasn't just a rant, I was foolishly hoping to see less talk of 'front shocks' and the like.
    Reputation: kubikeman's Avatar
    Jun 2010
    Okay Mr. Smarty Pants. Explain this one to me then...
    it's shocking how many forking people get these terms confused.-p4pb10115912.jpg
    The cake is a lie.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    A Lefty is not a fork, it's a strut.
    A shock consists of a spring and a damper. A fork is usually a shock, except for if it's only a spring. A rear shock is not a fork.
    Thank you for playing this week's edition of "technical correct".
    Reputation: reformed roadie's Avatar
    This reminds me of Shiggy getting his panties in a bunch from the miss-use of the terms "thru-axle" and "thru-bolt".
    Rabid Lana fan
    ^^ New Turner design??? ^^
    rOCktoberfest 2015 pt I here
    rOCktoberfest 2015 pt II here
    Your Best Friend
    Reputation: Silentfoe's Avatar
    Re: it's shocking how many forking people get these terms confused.
    This has been discussed before but the one that irks me is "fully rigid". Wtf is fully rigid? If it isn't rigid it is either a hard tail, soft tail or full suspension. No need to put "fully" in front of rigid.
    I'm a mountain bike guide in southwest Utah
    The content of this thread is hereby rejected.
    Reputation: BaeckerX1's Avatar
    Oct 2007
    Fully rigid is a saying used by the people that ride them to make themselves sound cooler/more awesome/better/more manly than the rest of us mere mortals. Here it is in practice:
    "What, you need full suspension for that? I just rode the shit outta that rock garden on my fully rigid bike!"
    Just because I can, doesn't mean I want to.
    Now just to mess with Colin, I'm going to change out the oil on my front spring tonight.
    Gotta get up to get down.
    LMB
    Reputation: J.B. Weld's Avatar
    What about straight blade forks?
    Curved ridged forks may provide minimal suspension but for most people front suspension means a suspension fork (e.g. Rock Shox). Before mechanical suspension became common a frame had a rear triangle, a main triangle, and a fork. When suspension came along it became necessary to differentiate the two by referring to them as either a fork, or suspension fork, so to me saying a bike has a fork does not mean it has front suspension.
    Front suspension/ rear suspension makes more sense to me.
    Reputation: MSU Alum's Avatar
    I'm pretty sure there's a government agency involved in this nomenclature (from two different Latin names, both of which mean "name"...or, name name)...."Fully rigid", "front fork", "rear shock" are all generated by the folks at "The department of redundancy department".
    Reputation: Fix the Spade's Avatar
    Quote Originally Posted by kubikeman View Post
    Austrians, no further explanation is needed.
    Feb 2012
    I specifically said on a normal bike, fully expecting awesome pics like this one.
    Yes it is. But I think we're all ok calling a Lefty a fork.
    Quote Originally Posted by J.B. Weld View Post
    I am 100% fine with front / rear suspension. That works just fine and is technically correct.
    Quote Originally Posted by MSU Alum View Post
    No doubt.
    Quote Originally Posted by ColinL View Post
    Ok, now you will have to better define when technically incorrect terminology is ok, and when its not.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by reformed roadie View Post
    Just try to use that through bolt skewer in your through axle frame or fork.
    mtbtires.com
    Dec 1998
    But a fork can also be rigid. Irks me when somebody says "I want to put a fork on my bike" when they really want a suspension fork.
    Be clear. Without a fork--rigid or suspension--nothing connects the front wheel to the frame.
    mtbtires.com
    Feb 2012
    Quote Originally Posted by smilinsteve View Post
    Cannondale calls it a fork. That's good enough for me, how about you?
    Sorry, but rules are rules.
    Aug 2013
    If someone does not take the time to understand the terminology, they wont be able to understand what I'm telling them is wrong with their 'thing', and I wont explain it in laymen terms. If I have to explain a word into a definition, or a defining conversation, I'm going to charge more.
    Goodbye '95 ZJ. Just so you know, transfering box of left behind womens panties to next truck. Thank you ZJ!
    meow meow
    Reputation: b-kul's Avatar
    is a rock shox a good front shock?
    Way back in the 70's, when I was going through navy flight training, my marine flight instructor went ape-shit when I couldn't remember the name of the "castellated spindle nut" on the nose gear. (Of course, 40+ years later, I STILL know the name.) You're not that guy, are you?
    Rabid Lana fan
    When comparing the part of a bike [that connects the fornt wheel to the frame] to table utensils, a C-Dale Lefty is more of a knife than a fork.
    Quote Originally Posted by Silentfoe View Post
    Just meet me at 6:00 am in the morning for a sunrise ride before work, and it will all be good.
    Reputation: Vespasianus's Avatar
    I am staying out of this conversation but what the hell is that?
    On MTBR, the reputation is infamous.
    Feb 2012
    LOL. I'm 38, which isn't young, but I'm not that guy in either body or spirit. However, you might want to check with Shiggy...
    2 forks? Hmmm...
    Reputation: Maday's Avatar
    kidding alert!!! kidding alert!!!
    My shock is located in the area that some call the front triangle. So, isn't really a front shock? Or, a mid shock 'cause it near the middle of the bike?
    - Be Someone
    I prefer to be extra-precise. "shock" is misleading, since it would refer only to the damper, and not the spring.... so I use "air sprung, oil damped, linkage driven rear wheel suspension"
    Jun 2010
    Quote Originally Posted by Vespasianus View Post
    Photo caption..."here's another look at the Scurra Hard Enduro bike. A 29" front wheel, 27.5" rear wheel and a unique front linkage system makes for one bizarre looking bike. The bike gets seven inches of travel front and rear, and the designers are currently looking for distributors and funding to bring the bike into production."
    The cake is a lie.
    Nov 2012
    I think we need to be careful and get far more specific. A table fork generally has three prongs and so it is highly misleading to compare it to a suspension fork. If we are talking suspension forks we need to refer to olive forks.
    Also a Cannondale Lefty should be referred to as a single chopstick.
    Just taking the time to use the correct terminology should avoid confusion.
    Quote Originally Posted by Kiwi_GR_Biker View Post
    Bwahhhhaahahaomygodimpissinmypantsbwahhhahahahhhaa !!!!!!!!!!!!
    Trail Ninja
    Reputation: Varaxis's Avatar
    How about we just accept that some people like to use the generic terms in vague manners, for the sake of avoiding the trouble of learning all the various technically accurate terms, and just determine the implication through context.
    On that note, are the 142x12 TA and 15 QR actually true thru axles, or are they more oversized skewers being put through the hubs' actual axles?
    We're all on the same ship, and it's sinking.
    Reputation: lotusdriver's Avatar
    Sep 2013
    "Front fork" kind of rolls of the tongue, although strictly it is not necessary to say "front" of course.
    Also people who know nothing about bikes are more likely to understand what you are talking about if you say "front fork" or "rear shock" as they won't know that is the only way round it can be. Apart from that bike in the picture!
    Quote Originally Posted by shiggy View Post
    Except a strut, like a lefty or the newer one-sided headshock models.
    Evidently though, in Europe, when they sell forks, they only sell them two at a time, hence, "my pikes" (2), "I just got a pair of 888s" (4?), "a pair of boxxers" (4?) etc...What you do with the other fork, I'm not sure, but I guess having spare parts isn't bad...
    Interplanetary Poultry
    Reputation: scatterbrained's Avatar
    Technically it's not a shock, it's a "shock absorber". If you're gonna whine you should at least get it right.
    Editor In Chief, "Internet Tough Guy Magazine"
    "Home of Chuck Norris' Keyboard"
    Oaktown Honkey on Strava
    If my bike gets stuck on an electrical power line, will I get a shock from my fork?
    Reputation: F.N.G's Avatar
    I cannot wait for my new front fork and rear shock to come in. Stoked!!!!
    Reputation: charging_rhinos's Avatar
    This thread is about as useful as the 'Trail vs AM' threads.
    tangaroo: What electrolytes do chicken and turkey have again?
    rck18: All of them, because they're meat.
    Bandit 29 FTW!!!
    Reputation: In-Yo-Grill's Avatar
    Why don't you make like a shock and get the FORK outta here.
    Let's make like a Bike and get the Huck outta here...
    Funny. That's a good one. Is my front tire a shock absorber? Or a fork absorber?
    Hey ColinL, what do you think of post #31? That is really funny. I really want to ride that bike for a Minute
    Aug 2013
    Quote Originally Posted by aerius View Post
    2 forks? Hmmm...
    Wouldn't that actually be two rear shocks?
    What year was this bike built?
    Feb 2012
    Quote Originally Posted by hoolie View Post
    Looks like it has 2 forks to me... Since an elastomer is suspension (albeit crappy), I guess softtail MTBs are in the same vein as a rear fork.
    Yes, that's fonetic
    Reputation: whoda*huck's Avatar
    Feb 2005
    No mention of those that talk about the "forks" on their bike, as in "the Zokes on my bike are leaking" or "the forks on my bike need replacing"? This irks me at least as much as "front fork".
    Quote Originally Posted by pdxmark View Post
    I think that was like 94, maybe 1994. I rode one of those. Very flexy with absolutely no rebound dampening at all. Quite shocking really.
    Reputation: brentos's Avatar
    Technically, all suspension forks are struts that also happen to be shock absorbers and springs.
    Axe
    Axe is online now
    Custom User Title
    Reputation: Axe's Avatar
    I thought I should contribute something to this enlightening conversation, but then I could not get arsed.
    Trail Ninja
    Not as bad as the seat vs saddle thread at least. That one devolved into the possibility of renaming seatposts to "saddle posts", and also renaming clipless pedals and handlebars (as it's not a bar, but a tube)...
    Self Appointed Judge&Jury
    Oct 2000
    I think the OP is either talking about this other thread or he will be happy to see I corrected the OP of this other thread a week ago.
    Here does front shock need to break in period?
    Feb 2012
    big on that one. but sadly, there are countless threads in All-Mountain, 29er and Suspension that use the wrong terminology.
    Friggin hilarious!
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    That's definitely a Shork. Or a Fock. It depends on the, uh, pivot arm . . . joint . . . bushing. Yeah. definitely a Fock. Ask any certified engineer.
    Feb 2012
    This sweet piece of machinery reminded me of this thread.
    I can't decide what I like about it best, whether it be the non-functional rear suspension if you're out of the saddle, or if it's thinking about how a Float X shock performs compared to any decent fork.
    Reputation: iamtylerdurden's Avatar
    why is this in the all mountain forum? Technically speaking it should be in the shocks & suspension section?
    Reputation: White7's Avatar
    Feb 2015
    Quote Originally Posted by iamtylerdurden View Post
    why is this in the all mountain forum? Technically speaking it should be in the rear shock & front fork section?
    Fixed it for you
    Reputation: David R's Avatar
    Maybe it's a New Zealand thing, but some how amongst the non-cycling population the word "shocks" has become synonymous with suspension forks, and that irks me. But even more irksome is when some little kids (who, for the non-NZers, usually talk like this) see my bike and say "whooa, your bikes got back shocks! Meeaaaan!"
    Mar 2015
    Forkin hell those bikes are shockingly ugly.
    I'll take my semi-fully rigid front forked bike any day over those.
    Reputation: KevinGT's Avatar
    Dec 2012
    it's shocking how many forking people get these terms confused.-dilbert1.jpg
    Dec 2014
    Hey KevinGT, did you read that the 29er experiment proved that 26" wheels were just fine and that 650b wheels are unnecessary?
    Dec 2012
    Quote Originally Posted by jim c View Post
    Nah, I proved it myself.
  67. #67
    Can anyone really not figure it out if someone says "front shock"?
    I work on high end german cars for a living. People not having any idea what they're talking about is part of the job. If you know whatsup, you can get the job done.
    Ill have friends call me up and say their bike wheel went flat. I think we all know they've got a flat tire.
  68. #68
    Thinking about riding.
    Dec 2014
    The mechanics at my shop really love the technical term 'blew up.' As in 'my wheel blew up.'
  69. #69
    Reputation: aliikane's Avatar
    Good one. This is a genius question for the OP. Haha.
  1. Shocking Wife
    By Bdabike in forum 29er Bikes
    Last Post: 05-23-2013, 05:15 PM
  2. Forking Around
    By mvwmvw in forum Singlespeed
    Last Post: 03-05-2013, 11:50 AM
  3. shocking prophet
    By broomhandle in forum Cannondale
    Last Post: 10-24-2012, 12:52 AM
  4. Shocking Service..
    By EFMax in forum Shocks and Suspension
    Last Post: 09-26-2012, 11:54 PM
  5. forking around
    By clipt in forum Beginner's Corner
    Last Post: 08-16-2012, 07:14 PM
