    Issues with new steel bike frame. I'd like other users input.
    Just bought a new steel AM hardtail frame from a direct selling manufacturer that is known to build cool frames. There is at least one and maybe more loose flakes of metal in the seattube support that won't come out (I can see the debris in a drain hole, but can't get it out. The company suggested gorilla glue. Not sure if that will be a permanent fix. And it is REALLY noisy as it shakes in the frame.
    There also seems to be a lot of rust on the inside of the top tube. Not sure if that is normal for a brand new frame. I worry that the loose metal is flaked rust and it may get worse.
    Posting pics to get others thoughts as to if this is normal with a new steel frame.
    First pic is the loose metal sitting by the drain tube. Second is a close up through the head tube into the top tube to show the rust.
    Thanks.Issues with new steel bike frame.  I'd like other users input.-20180429_141904.jpg
    Issues with new steel bike frame.  I'd like other users input.-20180430_064605.jpg
    Reputation: Raleighguy29's Avatar
    Jan 2014
    If thatís the frame I think it is make sure you treat it with frame saver. Since itís chrome it didnít come already treated. I have the same frame built over the winter been riding the shit out of it. No issues. If all else hit it with a blow gun and see if the stuff thatís loose will come out. But I donít see you having anything to worry about.
    Reputation: thasingletrackmastah's Avatar
    Valvoline ML spray works as framesaver and glues these fragments of steel to the inside of the tube.
    Belgian beer and Scotch whisky.
    mbtr member
    Reputation: scottzg's Avatar
    Quote Originally Posted by mountainbikenaked View Post
    Blob of grease.
    None of that stuff is a problem, and is very common. It's distressing if you don't expect it, fosho. Post up some pics of your new frame!
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
  1. Replies: 10
    Last Post: 07-09-2015, 01:36 AM
  2. input on new steel frame
    By uhland in forum 29er Bikes
    Last Post: 09-19-2014, 12:34 PM
  3. Sram X1 issue (XX1 and XO1 users input welcome)
    By GVSS in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-06-2014, 10:45 PM
  4. Rattlesnake...the other-other-OTHER white meat.
    By In-Yo-Grill in forum General Discussion
    Last Post: 04-01-2014, 05:30 PM
  5. Frame Spreading (cold setting a steel frame). Input please.
    By tangaroo in forum Bike and Frame discussion
    Last Post: 09-24-2012, 05:56 PM
Members who have read this thread: 93
