Results 1 to 3 of 3
    Inset headset for 1.5 headtube/steerer combo
    I have a frame with a full 1.5" headtube. I have a fork with a straight 1.5" steerer tube. Is there such a thing as an inset headset that will work for this combo? If so, who's the maker and which model is it?
    If i understand you correctly, you are looking for a headset for 1.5 forks. Not the headshock forks from cannondale, lefty and fatty....
    There are many manufacturers like Fsa, acros and cane creek.
    I would go for the cane creek if i had not the Fsa big fat big 1.5....heavy but will last forever.
    Some frames need headsets with a bigger lower stack height. ..+10mm to let the fork rotate 360 degrees...
    Fsa Orbit xtreme pro 1.5....lighter, better sealed but more expensive
