Results 1 to 7 of 7
    Reputation: JFoster's Avatar
    Apr 2005
    I Need a Rear Wheel - budget(ish)
    Looking for a deal on a 26" for standard QR rear. Currently running a Hope Flow up front, and was running an old Sun Mammoth rear. Out of adjustment shifter put my chain between the cassette and spokes. Damaged basically all the right side spokes, doubt it's worth fixing.
    Riding is probably mild for most, drops typically under 3'. But I'm ~240lbs so I'd prefer something sturdy.
    Thinking about a matching Flow rear, but would be pumped to find something decent for less than $290.
    Have you seen anything on clearance?
    Sep 2013
    Is the rim/hub still in good shape? If so your most budget option could be a rebuild of the wheel with just new spokes.
    you can get a flow laced to hope hub from the UK for under your budget. wiggle is the place.
    Reputation: CarolinaPanthers's Avatar
    Feb 2013
    check out cyclesport.co.uk for hope hoops. rear wheels are $240ish shipped across the pond. I got mine (flow ex) in like 4 business days
    Reputation: B-Mac's Avatar
    Azonic Outlaw.
    Very strong, cheap, but heavy.
    I'm a larger guy too, took me 5 years to kill an Outlaw rear wheel.
    Check out my You Tube Channel
    Apr 2005
    Quote Originally Posted by marco_g View Post
    The rim is fine, the hub is a junky old Shimano deore... good excuse for an upgrade.
    Quote Originally Posted by B-Mac View Post
    Azonic Outlaw.
    Yeah, I have outlaws on my Mongoose Ritual. Where are you seeing. A rear only?
    Thoughts on this Brand X hub - NS Rim
    Brand-X Hub On NS Fundamental Rim - Ex Display | Chain Reaction Cycles
    Strong? Can I run my 8spd cassette on that hub?
    Apr 2005
    No input on that wheel?
    What about should I stick with a matching flow rim for the rear or would the 721 be considerably stronger?
  1. Budget rear wheel build for Clyde
    By deejor in forum Clydesdales/Tall Riders
    Last Post: 08-26-2012, 08:26 PM
  2. Low budget disc compatible wheel set?
    By nicog92 in forum Wheels and Tires
    Last Post: 08-10-2012, 06:13 PM
  3. Budget Wheel Build
    By bank5 in forum Wheels and Tires
    Last Post: 04-27-2012, 11:32 AM
  4. Wheel set for a 1k budget
    By vinnyl26 in forum Wheels and Tires
    Last Post: 04-01-2012, 06:13 PM
  5. Need advice on new wheel build...$750-1000 budget
    By crimecrusher in forum Wheels and Tires
    Last Post: 07-09-2011, 01:45 PM
