Results 1 to 11 of 11
    hows the trail king 2.4 in loose cover hardpack.
    had my lbs order one for the front. wanted to try the large casing for plowing ruff sections. but most of my trails is so cal hardpack loose desert conditions. the tk had a lot of loyal users so I figured I couldn't loose. anyone impressed with it for my conditions. my thought is to run it with an ardent 2.25 on the rear. thanks so much any responders.
    Reputation: Fuglio's Avatar
    Thats what their for... it will work great
    I'm in Utah. And I've had TK 2.2 UST on the rear paired with a Hans Dampf up front. Was a really good pairing, maybe lacking slightly in rear braking traction (compared to say a High Roller).
    Currently on TK 2.4 Protections front and rear. Braking traction is improved, but it is definitely heavier and slower than the previous setup. Better for downhill stuff, not quite so much fun for going uphill.
    CoolArrow
    Reputation: jhazard's Avatar
    Rolls faster and grips a little better than my Nevegal (set up on the rear). Tire compound seems soft, reminds of the old Vert Pros as far as wear is concerned (okay, they don't wear THAT bad, but...).
    Cool BandolArrow
    Jerry Hazard website
    Mar 2006
    Anybody know where to get the new 2.4 protection models mentioned earlier?
    Not interested in UST or the Apex sidewalls.
    DBY
    DBY is offline
    Quote Originally Posted by half_man_half_scab View Post
    2.4's aren't shipping yet from what I've read. Although, Universal has the 2.2 TK Protections right now. BTW, the Protection versions have the Apex sidewalls.
    sweet looking forward to trying it.
    heres a review of what I have tried for any curious:
    so far for the front I have tryed the older weirwolf up front which has been solid. probably got the most miles on as a front.
    also ran the newer wolf and not sure why I liked the older better. I think it gets into the side knob better making if feel less slippery.
    like the newer in the rear of many I tried though.
    also have the 2.35 and 2.5 minion, the 2.5 is a solid beast for the front. the 2.35 was good too but I think I got used to how the wolf lays over. and like the size of the 2.5 dhf better.
    the prowler on my xc bike seemed consistant up front also. supple and tacky and consistant.
    currently im coming off the cedric ac 2.35 which im not sure about. looking down at its tread inspires confidence but its has a release point im just not used to. I might need to learn it as I did the wolves.
    also tried the ardent 2.25 up front which felt pretty consistant which surprised me. I thought it would be slightly looser with a bigger transitional gap from what I read from some.
    but all in all I am really looking forward to the massive tk casing and black chili compound. eventually I will probably try a damf to try all the front favorites.
    I am also in search of and arsenal for the rear. I do like the wolf back there with any of the above fronts. It climbs brakes release and corners realy well. the cedric xc is fast but looser. I have a high roller but don't have enough saddle time too give a real feel review. im looking forward to maybe trying a wolverine or geax aka. I think either would be fast and sold for a rear combined with any of the above high performing fronts.
    I am still in search of an arsenal for the rear
    Reputation: ATXZJ's Avatar
    Quote Originally Posted by akiracornell View Post
    Did something similar.
    I found a 29er trail king 2.4 for $35.00 shipped so i pulled the trigger. It replaced a 2.2 MKII BC protection on the front while the other MKII BC remained on the rear. I was riding soft over hard on the typical southwest trails found in NM.
    Good:It rolls surprisingly well considering the weight and size, and has huge braking grip. As a bonus the large case volume just bashes over everything. I'm running them on WTB 23mm tubeless wheels and have yet to burp or lose a bead. It also used less stans than my MK to seal properly.
    Bad. It has a bit of vagueness like the ardent when cornering. You have to learn to lean it a bit more to get the most out of the tire. I did find that lower tire pressures helped this quite a bit, but makes it roll slower.
    It probably would be perfect if it were a BC compound.
    16 Process 111DL
    15 Process 134DL
    16 Process 153DL
    16 Honzo DL
    16 Private Jake
    17 Hei Hei DLc
    Quote Originally Posted by ATXZJ View Post
    I found a 29er trail king 2.4 for $35.00 shipped so i pulled the trigger...
    Heads up on those 29 TK 2.4 folding... there's not a sufficient amount of rubber to seal the casing threads around the bead. I had two of these tires puke stans goo out the casing just above the bead after 6 months of them being mounted...stranding me out in the middle of BFE once. The sidewall didn't rip, just stans all over the place.
    BTW, has anyone seen the UST version of this tire available anywhere yet? I'd like to pair this tire w/ a 2.5 Minion DHF...DHR/TK, frt/rr. The DHR2 is a good match to the DHF, but I want more meat to hit chunder w/ more speed.
    Quote Originally Posted by Pau11y View Post
    Thanks for the heads up, I'll keep an eye on it. So far it has been more reliable than my protection MKIIs by far. I wish I would have picked up a rubber queen while they were still available in larger sizes.
    Funny you mentioned the minion. I've been thinking of moving the TK to the rear and getting a 2.5 DHF minion. I ran a 2.5 DHF super tacky compound on my 26" AM rig and the traction was god-like. Then again so was the weight
    16 Process 111DL
    15 Process 134DL
    16 Process 153DL
    16 Honzo DL
    16 Private Jake
    17 Hei Hei DLc
    I'm with stupid
    Reputation: hitechredneck's Avatar
    Mine work quite well. Im a big time tire whore and this tire keeps getting put back on the AM bike.
  1. Good tires for loose over hardpack?
    By deadbeat son in forum Wheels and Tires
    Last Post: 06-19-2013, 09:07 PM
  2. front tire for stumpy fsr for hardpack/loose over hardpack
    By weekendthrasher in forum Specialized
    Last Post: 05-29-2013, 08:16 PM
  3. front tire for stumpy fsr for hardpack/loose over hardpack
    By weekendthrasher in forum Wheels and Tires
    Last Post: 05-22-2013, 11:39 AM
  4. Loose over hardpack
    By Millfox in forum Beginner's Corner
    Last Post: 09-05-2012, 10:54 AM
  5. Loose rock chips over hardpack?
    By XJaredX in forum Wheels and Tires
    Last Post: 04-23-2011, 06:22 PM
