Results 1 to 5 of 5
    How should clipless shoes fit for AM riding?
    Just bought a new pair of clipless shoes for some of my longer, climb intensive rides. The shoes have about 2mm vertical slack on the toe box and about 2mm horizontal distance between the toes and the front of the shoe. The foot moves around slightly when im hitting rooty sections fast.
    When I land jumps on a fast downhill my foot slides forward into the toebox but not to the point where it throws me off or anything.
    I tried one size down and it was too tight, so this is my size. Trying other brands is out of the question as I already bought this one (Northwave Rebel) and i like the shoe, except for the above issue.
    Should I get thicker insoles? Should I try to shrink these bad boys by soaking them in water? Should I just leave them as is and get used to them?
    How do your clipless shoes fit and what do you recommend i do?
    Thanks a ton in advance!
    Reputation: aaabronco's Avatar
    Mar 2011
    I suggest you grow your feet a little more
    Reputation: Shalom's Avatar
    Nov 2008
    Northwaves are wider than most other shoes out there. Which might be why your foot is moving around a bit.
    My advice - try thicker socks and get used to it (if you cannot tighten the straps at the front a bit more).
    Reputation: Dgage's Avatar
    if you go the thicker socks route then you will probably end up with blisters. try a different insole
    Friends don't let friends cheer for the TML
    Huffy Rider
    Reputation: motochick's Avatar
    Jun 2010
    ^^^Insoles, I have tiny feet and new "real" insoles solved the problem. I still wear the same thin cycling socks.
  1. clipless shoes
    By Twiitch in forum All Mountain
    Last Post: 04-10-2011, 07:36 PM
  2. Good shoes (NOT clipless) for riding?
    By Natedogz in forum Apparel and Protection
    Last Post: 05-18-2008, 03:59 PM
  3. which clipless pedals and shoes for clipless newb?
    By jeepinmike in forum Apparel and Protection
    Last Post: 06-27-2007, 01:47 PM
  4. What clipless shoes for DH?
    By jamip_dh in forum Apparel and Protection
    Last Post: 01-28-2007, 06:18 PM
  5. Shoes for clipless riding
    By steeltoe in forum Apparel and Protection
    Last Post: 09-16-2005, 08:23 AM
