Results 1 to 9 of 9
    GOD SPEED # 58 # 69 RIP
    Reputation: pvflyer's Avatar
    Dec 2004
    Hope head doctor
    Has anybody here tried hope head doctor instead a star nut?
    Hope Head Doctor | eBay
    "My GREATEST FEAR is that one day I will die and my wife will sell my watches for what I told her I paid for them."
    I tried to use one with a rigid Surly Instigator fork without success. It kept sliding up the steer tube, I could not get enough tension in to it to pre-load the headset. It will ultimately depend on the inside diameter of the steer tube.
    Mar 2005
    I have a few and they work great. I can only imagine that Saddle Up must have not installed his correctly if he had problems with it. If your fork fits a standard star nut it will fit a Head Doctor.
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Re: Hope head doctor
    What is the benefit over regular star nuts?
    krt
    krt is offline
    The benefit is that you don't have to use a regular star nut, which can be a pain to fit. Plus, when you switch forks, you just take the complete assembly out of the steerer and you put it in your new fork.
    Also, the cap and cap bolt can be used with a star nut. But you can't use the nut or cap separately, they have to be used together.
    I believe that you could use a regular bolt + cap on the head doctor steerer assembly.
    May 2005
    I use an Azonic Head Lock. Works awesome. These are designed for 1 1/8" forks so to use for a tapered fork I got a washer at the hardware store that fit perfectly over the bottom flange of the Headlock and fit the outer diameter of the bigger tapered steerer tube.
    2013 Banshee Spitfire V2 650b
    Reputation: splatworldwide's Avatar
    Aug 2005
    Expander plugs such as the Hope Head Doctor are useful if you have a carbon steerer, as you can't use a traditional star nut.
    I had a Azonic Head Lock on a bike for a long time. Worked great and I really liked it. Would buy again.
    Quote Originally Posted by myarmisonfire View Post
    Wrong, dude don't imagine anything about me okay! When I mentioned it to the distributor, he was not surprised, it's not that uncommon.
