Results 1 to 15 of 15
    Oct 2012
    Help choosing a new fork.
    My current fork is a 44 and it's a great fork but it lacks complex adjustments and is slightly flexxy. I'm looking for a new fork that has 34mm> stanchions and a straight 1 1/8 steer tube and 150ish mm, frame is 120-160mm. 55cr and vengeance are the forks I'm aware of now so opinions in them would be great as well as other suggestions. Thanks.
    Reputation: Fuglio's Avatar
    Are you willing to buy used??
    Oct 2012
    Quote Originally Posted by Fuglio View Post
    Maybe. Depends on how old and what model. Also you might be interested to know it's going on a surge.
    Dec 2010
    Just put a 2012 Magura Thor on my Mojo SL. Ridden is twice and its great. Still dialing it in but I am really happy with it. If you look around you should be able to find it for around $600.
    I am interested to know that
    I have a surge and im really happy with it the frame can be built up lots of different ways. I have a fox 32 140r and a fox 36 160rcl
    honestly i wouldn't pay to much attention to all the extra knobs you can get most forks to act the way you want them to... the secret is knowing what you want
    Oct 2012
    Given those two choices go with the 55. I run away from travel adjust forks. Then again the magura is cheaper... but the 55 is coil so if you want a long lasting durable fork you can beat to shit get the zoke
    Oct 2012
    How well do Surges rode with 160mm forks?
    I think 140 is the sweet spot if your doing XC. But im keeping the 160 on cause the 140 get overwhelmed by highspeed tech. So im giving up climbing low speed balance and aceleration...
    heres the 140 version
    <a href="http://s34.photobucket.com/user/mrpea9999/media/0706131347a.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/0706131347a.jpg" border="0" alt=" photo 0706131347a.jpg"/></a>
    <a href="http://s34.photobucket.com/user/mrpea9999/media/Fug_notch-1.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/Fug_notch-1.jpg" border="0" alt=" photo Fug_notch-1.jpg"/></a>
    <a href="http://s34.photobucket.com/user/mrpea9999/media/logride.png.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/logride.png" border="0" alt=" photo logride.png"/></a>
    <iframe width="560" height="315" src="//www.youtube.com/embed/osRpTCdfXJg?list=UUKtJssbgfYezdG5CEVSpHtQ" frameborder="0" allowfullscreen></iframe>
    <iframe width="560" height="315" src="//www.youtube.com/embed/V6h1PBP0xW0?list=UUKtJssbgfYezdG5CEVSpHtQ" frameborder="0" allowfullscreen></iframe>
    And 160mm version
    <a href="http://s34.photobucket.com/user/mrpea9999/media/IMG_20130905_153005-1.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/IMG_20130905_153005-1.jpg" border="0" alt=" photo IMG_20130905_153005-1.jpg"/></a>
    <a href="http://s34.photobucket.com/user/mrpea9999/media/9684592270_62a6d9aa4d_c.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/9684592270_62a6d9aa4d_c.jpg" border="0" alt=" photo 9684592270_62a6d9aa4d_c.jpg"/></a>
    photo by jhazard
    <iframe width="560" height="315" src="//www.youtube.com/embed/59xY9jhZVjg?list=UUKtJssbgfYezdG5CEVSpHtQ" frameborder="0" allowfullscreen></iframe>
    and doing DH at angel fire new mexico
    <iframe width="560" height="315" src="//www.youtube.com/embed/ci8y3rrlkho?list=UUKtJssbgfYezdG5CEVSpHtQ" frameborder="0" allowfullscreen></iframe>
    So it all depends on what you want out of the bike and how you ride... i would probably leave it set up with the 140mm but the wheel set wouldnt last so since im so hard on bikes ill just take my medicine and ride a heavy bike rather then buy wheels every year
    Oct 2012
    I don't do that much XC trails and the ones that I normally do are fairly tame so I think I will keep it at 160 for the most part.
    Reputation: Fix the Spade's Avatar
    Quote Originally Posted by Electrin View Post
    Aside from the Vengeance HLR none of the current forks have complex adjustment, at best you are tightening a spring to preload the damper, at worst you have a three positions all wrong set up like CTD or RCT3. If you send it to PUSH the 34 can have hi-lo speed compression adjustment, but that's preload too. Adjusters are over rated.
    It's expensive (about $500 for cartridge/fitting of, shipping extra), but you can send your 44 to Avalanche and get the Avy cartridge installed, that will give you a fork to match anything up to and including a BOS. If you're set on buying new you'll be making a side-grade rather than an upgrade over the 44.
    If you must have a new fork, BOS Deville, 34mm stanchions, comes in 1 1/8th and best damper this side of the Avy set up.
    Reputation: honns's Avatar
    Spade has it right. If you want a new fork with all the bells and whistles, look at the Vengeance (36mm stanchion) or Deville (34mm stanchion). The other forks mentioned above don't have much better adjustment than your current setup.
    Avalanche is a good second option if you like the fork, but want more adjustment out of the damper.
    Oct 2012
    After some thinking I'm probably going to get the 55 r off pink bike as it's cheep and he has the extra parts needed for an avy cart and then get the upgrade in the near future.
    "Paid" shameless spam/plug but I have a Lyrik 2 Step, 160mm to 115mm, 20mm axle that's been lightly ridden and is in fantastic condition up for sale on the classifieds here on mtbr. Has a 1 1/8 steer at 8 inches and includes a 2-step rebuild kit. The fork has maybe 150 miles on it and is currently paired with an El Guapo frame but willing to separate it. PM me if interested. Have a look at the ad, super clean fork with no marks on lowers or uppers.
  1. Need help choosing a fork
    By FireSpitter in forum Shocks and Suspension
    Last Post: 07-16-2012, 06:40 PM
  2. Need advise for choosing a suspension fork
    By Chris's Klein in forum Shocks and Suspension
    Last Post: 05-22-2012, 07:10 AM
  3. Help Choosing An XC Fork
    By Subaru_Nation555 in forum Shocks and Suspension
    Last Post: 05-18-2012, 11:39 AM
  4. choosing fork for mah new covert ;)
    By adi518 in forum Transition Bikes
    Last Post: 08-05-2011, 09:12 AM
  5. Advice on choosing my new AM fork?
    By socalMX in forum All Mountain
    Last Post: 07-02-2011, 04:21 PM
