Results 1 to 5 of 5
    Jul 2013
    Headtube Angle HT vs FS
    Hello fellow mtbrs.
    Currently I am riding a yelli screamy with a 120mm fork which gives it a 68* headtube angle.
    I recently ordered a tallboy LT and this will be my first full suspension bike. I have been enjoying the slacker headtube angle on the yelli vs my old xc bike.
    The tallboy headtube angle is 69.5* however in my head I'm thinking since it's full suspension it's not going to steepen as the fork compresses like the hardtail does; therefore, will not feel unstable like a xc bike does on the dh.
    Should i worry about getting an angleset for the TB or am I being or paranoid and just ride and have fun? I fully plan on getting some rides in on the TB before changing anything for sure either way.
    beater
    Reputation: evasive's Avatar
    Feb 2005
    Quote Originally Posted by sti2.5ldohc View Post
    I think you answered your own question. There's a lot more to how a bike rides than the HTA. I owned a Yelli, and have demoed a LTc. I thought the latter was a well-balanced ride, and recommend taking the time to feel it out before changing too much.
    Reputation: nauc's Avatar
    i wouldnt even worry. i road a Tallboy a couple weeks ago in Tahoe. its a great bike, and its very comfortable too
    and x2 what evasive said. ride it for sometime before you change anything
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Re: Headtube Angle HT vs FS
    OK so you're saying:
    1) On your HT your head angle steepens during compression, which you think makes it feel less stable
    And
    2) On an FS, since the back drops at the same rate as the front, this won't happen as much, therefore you don't think you'll notice the net change of +1.5 degree steeper
    Did I understand correctly?
    OK. First I don't don't think #1 is a real factor in stability at speed, especially with a 120mm fork. The fork is only at full compression for very short periods and spends most of its time between zero and 50% compression, with the head angle thus momentarily oscillating between +. 5 / -. 5 or less. If you look at a bike in slow motion, it will look more like the bike is traveling level and the wheel is moving up and down under it. The head angle, relative to the surface that the front wheel is on, might momentarily change at the peak of some rock, but it will spend equal amounts of time in a slightly slacker position, nulling out the total effect. The static head angle is the main factor.
    Secondly, on an fs bike I don't think that effect #1, . . . if it exists at all, will be lessened by the fact that the rear is suspended as well. Most often, the front will compress under an obstacle, then the back.
    So, overall, I'm saying I think you will notice the steeper head angle on the tall boy, there's no way around it, but you'll get used to it.
    mbtr member
    Reputation: scottzg's Avatar
    50% of 120mm =60mm = ~2.5° change to head AND seat angle, also lowering the bars and raising the saddle. It's absolutely significant, it's weird to even wonder. Subaru is talking about the effects of sag.
    Subaru, don't rush to get an angleset, mine was always creaking or clunking, requiring adjustment, and head angle is surprisingly subtle thing when you can change it by itself. The bike is more than just it's head angle anyway; trust in the designer's ability to make it work as a whole... or get a model that you think better fits your expectations.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
  1. who makes adjustable headtube angle headset?
    By 2clue in forum Shocks and Suspension
    Last Post: 02-14-2012, 07:53 AM
  2. Tallboy headtube angle change
    By no nancies in forum Santa Cruz
    Last Post: 02-06-2012, 06:36 PM
  3. Opinion on headtube angle vs rear travel
    By cantin03 in forum Downhill - Freeride
    Last Post: 12-06-2011, 11:28 AM
  4. anyone racing a stumpy?? headtube angle??
    By roch485 in forum Specialized
    Last Post: 12-04-2011, 07:22 AM
  5. Headtube angle affect my fork?
    By seano26 in forum General Discussion
    Last Post: 07-31-2011, 05:52 PM
