Results 1 to 13 of 13
    Reputation: Saar G7's Avatar
    Jan 2005
    Head tube angle change on a 1.1/8"
    X threading from the Turner forum, thought it might be of interest to those who would like to slacken their head tube angle ...
    5 spot with ~67 deg. HTA (or maybe a bit less)
    Attached Thumbnails Attached Thumbnails Head tube angle change on a 1.1/8"-has.jpg
    A different angle on bikes:
    www.ofanaim.net/has.html
    Reputation: V.P.'s Avatar
    awesome : )
    meow meow
    Reputation: b-kul's Avatar
    that is really really cool. you think someone will start comercially making these? id love to slack my xam out to 67 degrees.
    66 HTA, standard headset.
    I have red hair
    Reputation: RedGreen's Avatar
    "I don't believe in brakes, all they do is slow you down"
    Jan 2005
    redgreen i think your missing the point this is for 1 1/8. Im sure the op knows about the angelset.
    meow meow
    Quote Originally Posted by RedGreen
    there you go getting me all excited then i click the link and insta-let down.
    I have red hair
    oops, sorry about that, I been havin brain farts lately
    www.derbyrims.com
    Reputation: derby's Avatar
    The AngleSet is due to have a 1 1/8" version in a few months.
    These are different, each head tube size and length must be custom made, no adjustments.
    meow meow
    Quote Originally Posted by derby
    seriously? if i could slack my xam out to around 67 that would be so awesome! any additional info or link?
    Reputation: boomn's Avatar
    kinda. The current AngleSet is only available for headtubes that have a 1.5" bottom cup, whether its tapered or full 1.5". They are supposedly working on a version for headtubes with 44mm top and bottom cups, i.e. most 1+1/8" zerostack headtubes, but it won't be able to adjust as far as the current versions. There has been no word of an option for the more common and tradition 1+1/8" external headsets, and it likely isn't possible except for custom machining like in this thread
    Jan 2005
    Technicaly...
    Quote Originally Posted by boomn
    The next product that I would expect is the 44mm (zero-stack/semi integrated) version.
    The product will have to make one of the cups external, as there is not enough room to change the angle if the bearings remain within the headtube.
    I have been modeling different head tubes / steering tubes / headsets for a while and the main issue with 1.1/8" headtubes is that there is not enough room to insert an adjustable mechanism to allow angle changes. Same goes for 1.5" head tubes with 1.5" steering tubes.
    Thus, the only option I found after playing with the idea for almost a year now, is to make taylor made bearing cups aith an offset angle.
    I have just finished designing cups for 1.5" head tube with 1.5" steering tube.
    For a Banshee Rune this time, plenty of room if your design is accurate.
    Attached Thumbnails Attached Thumbnails Head tube angle change on a 1.1/8"-capture.jpg
    Reputation: jgusta's Avatar
    For a Banshee Rune this time, plenty of room if your design is accurate.[/QUOTE]
    Thanks Saar, I can't wait! Should be a nice and welcomed change to an already fairly versatile ride. Hope it everything turns out as expected, should make my ride just about right
    JG
    Ride On!
