Results 1 to 33 of 33
    56-year-old teenager
    Handlebars - how wide is too wide?
    My new bike (Chumba XCL) came with a really wide riser bar - 710 mm (roughly 28"). It's a huge change from the 22" wide flat bar on my old XC bike. The wide bar feels a little ponderous on the slower bits but it sure feels good going downhill. I'll still probably cut it down a couple of inches.
    How wide is your handlebar? Where does the width work well for you, where is it inconvenient?
    = dirt torpedo =
    i run 28" Diabolus bars on both my bikes..
    at first i thought they were too wide, but now i can't imagine going back to narrower bars.
    Sure, you have to be more careful in tight sections, and it's slightly tougher to maneuver at slow speed...
    trade-offs are worth it for me and for the type of riding i like to do.
    Go wide! Stay wide!
    squish is good
    Reputation: Clutchman83's Avatar
    I've got the RF evolve XC low rise handlebar and it came at around 25". Can't really say anything bad about it, never ridden wider though, have a tough time imagining going wider!
    Motion activated
    Reputation: Steve71's Avatar
    There was a thread about this in the AM forum just a few weeks ago, so you might want to check out the responses there.
    I just switched from a 26" bar to a 28" Diabolus. Much better. With some of the trails I ride I have to shift my weight around very quickly and the wider bar helps a lot. If you've ever done weights (bench press & rowing) you'll know that you can lift more if your hands are the right width apart. If fact it can even place an emphasis on a different muscle group. For example a close in grip uses your arms more, but a wider grip uses your back & chest more.
    Happiness is a warm 2 stroke.
    Purveyor of Trail Tales!
    Aug 2005
    Good job! 710mm Truvativ Holzfeller Riserbar with a 50mm rise!
    Quote Originally Posted by chucko58
    Hi chucko58,
    I use the 710mm Truvativ Holzfeller Riserbar with a 50mm rise. It dramatically enhances control and the only downside is fitting between the trees on the tightest runs on the Philís Trail System in Bend, OR. I have a pair of these handlebars on my Giant STP jump bike, my Santa Cruz VP Free freeride bike and my Specialized Enduro Pro SL all mountain bike. I tried leaving on the 660mm Specialized mid-rise bars that are stock on the Enduro Pro SL. They worked fine for flat or uphill grinding on smooth trails. However, when it came time to launch the front end of the bike they just didnít do the trick like the Truvativ Holzfeller Riserbar with a 50mm rise. So, as usual, the smart decision comes down to what you ride and where you ride. I hope you find something that works for you.
    Have fun, play safe!
    Michael
    If you can't keep the rubber side down......at least smile for the camera!
    Dec 2005
    Stem length and bar width is the key.
    What stem length are you using chucko58 ?~?
    I prefer 710 bars for a 70mm stem.
    I can get by with 680 bars for a 90mm stem.
    I use this as a rough guide on control (bar width / 2 + stem length) :
    710 bar + 70 stem = 425
    680 bar + 90 stem = 430
    660 bar + 100 stem = 430
    all about the same control...
    the resulting number gives the ''feeling of control" --> higher the better
    yup, I'm a common idiot !~!
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Some clown did a post about averaging weights, widths & carp similar to this.
    Formotion Products
    http://www.formot
    Reputation: munga's Avatar
    Whoa,
    so i've got more control on my xc bike (600mm bar and 110mm stem) than on my dh bike (680 and 50)!
    In case you couldn't guess, i like my bars a little narrower. I used to run my dh bars at 720, but then after i choped them it was way better. I feel that bar height has a lot to do with control too. I run my dh bike dumped (zero spacers) for maximum control of the front wheel. My xc bike has a single 5mm spacer under the stem. Both stems are zero rise.
    Cheers
    No More Signatures
    The bike came with a 100 mm 10 degree stem. It feels a bit stretched out to me.
    I'm debating whether I want to swap to a shorter stem, a bar with more back sweep (maybe a Mary bar), or something completely off the wall like drop bars.
    Dec 2005
    Try a 90mm stem (maybe with a 5 degree or 0 rise)
    or...
    If you have lock-on grips, you can move everything inwards about 10 to 15mm each side.
    This will give you the same affect as cutting your bars, and allow you to fine tune the length before you decide to cut !~!
    Jan 2005
    Quote Originally Posted by All Mountain
    Being the quiet silent type ayy
    Formotion Products
    http://www.formot
    mbtr member
    Reputation: scottzg's Avatar
    of the folks i ride with, the shorter ones seem to like the narrower bars, taller folk like the wide things.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    Reputation: frisky_zissou's Avatar
    It's all prefernce. Skinny bars makes it kind of twitchy. Your hands move less for the same ammount of turn. Wider bars are the opposite. Your hands have to move more to turn the same ammount. The reason I cut my bars was I had a particulary bad crash because my bar clipped a tree on a really fast narrow trail.
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    as others have said it is a matter of preference... I have been moving to wider bars and shorter stems progressively... I am now running 710mm Syncros bars and 80mm Syncros stems on both my rides.... the only problem I have is when space gets tight between trees... other than that I love the wide bars
    (I will cut the steerer when I settle on the stem position )
    <a href="http://www.flickr.com/photos/cmadrigal/575678353/" title="Photo Sharing"><img src="http://farm2.static.flickr.com/1377/575678353_22bbeff1c0.jpg" width="500" height="375" alt="testing 80mm stem on the 575" /></a>
    Reputation: drewactual's Avatar
    ... and if we just ...
    wider gives more leverage and control.......maximum bar width is determined by the narrowest space between trees on the trail you ride most often..... I run El Norte's 31.8, 2" risers at full length w/ a 45mm Azonic stem........I may change the bars and stem at some point, but this configuration I like....so if it changes it will be similar if not exact..... I've only endo'd a few times because I slapped a grip on a tree.....
    Just roll it......
    Reputation: ebxtreme's Avatar
    Running 28" diabolus bars on the dh bike and FSA (same width) on my xc and AM bike.
    Not going back.
    EB
    Reputation: noosa2's Avatar
    the difference one inch can make
    Quote Originally Posted by crisillo
    Glad I came across this thread. I have been using 660mm on my AM bike for about 4 years and thought it was great. Last week I put 680mm bars on my SS and today when I rode my AM bike I thought the bars were skinny and the handling was not as stable as it should be. Looks like I might be switching to 680mm bar on the AM bike too.
    This evening I chopped an inch off each side of my bars - down to 26" wide - and swapped the brake and trigger shifters. We'll see how it rides on Saturday.
    Reputation: Kevin G's Avatar
    Feb 2007
    What about thickness? Y'all rollin' 31.8s? The ladies do say thicker is better...
    31.8 all the time. I was on a 27" bar and am back to a 26" bar. I can't stand the narrow grip anymore and am thinking of going back to a 27" or even 28" bar. However, you have to be careful when flying through tight trees or rocks sticking out at bar height- very careful.
    I have long arms and can even breathe better with wider bars.
    Knomer
    Reputation: Dusty Bottoms's Avatar
    I'm comfortable with a 26" bar on both my bikes. A 28" bar makes handling dull through extreme tech sections where actual bike handling is neccessary. Tight turns and switchbacks also become more of a hassle with a wide bar, since your hands have to travel around a bigger circle to make the same turn.
    28" bars are for DH racing, this is the AM board, therefore 26" is the correct answer.
    Feb 2007
    Or 27". Which is what I roll. Somewhere in between DH racing and AM; that sweeeeet spot.
    Quote Originally Posted by Dusty Bottoms
    unless your shoulders/back are wide enough to use 28" very comfortably...then what..
    o
    Si vales, valeo.
    Reputation: Warshade's Avatar
    710mm Bontrager Big Earl handlebar and 70mm Bontrager stem.
    "An inconvenience is an adventure wrongly considered." G.K. Chesterton
    Dec 2005
    28" bars
    Time flies...
    Reputation: xjbebop's Avatar
    There is something to be said for actual shoulder width. wider shoulders + wider bar = better ergonomics...????
    Also riding style. I've got wider bars/shorter stem on my 'big' bike vs. narrower bars/longer stem on my XC bike...works for me.
    In the end it comes down to what feels right for you. You have to experiment and push the limits each way in order to come back to that 'sweeeeet' spot...
    ...every day sends future to past...
    Perpetual n00b
    Reputation: dgw2jr's Avatar
    New question here.
    Quote Originally Posted by All Mountain View Post
    I know this thread is going on 6 years old but I thought this particular post was very interesting. I use a 660mm bar on 100mm stem so my effective lever length (that's what I'm calling it for now until someone gives me an official name for it) is 430mm. Of course, stem rise can shorten the effective stem length, and I think handlebar sweep MIGHT reduce the effective bar length but I'm not sure how to calculate effective bar length from sweep and length if it even makes sense to do so.
    I have used 710mm/75mm, 680mm/90mm bar and stem combinations and noticed the steering speed is roughly the same. Looking at how others setup their cockpits I have noticed that a lot of people prefer ~430mm ELL. For example, a 760mm bar coupled with 50mm stem has an ELL of 430mm. That is a pretty typical AM/DH/FR cockpit configuration I have seen throughout the web. Not everyone will be comfortable with the same ELL no doubt, but anyone preferring an ELL of ~500 seems unlikely as that would just be WAY too slow steering for any type of MTBing I can fathom. Maybe on the road at very high speeds does ELL that high make sense but you are still talking about a very large turning circle.
    So if a rider, like myself, determines their ELL for a particular type of bike geometry and riding style then perhaps they can apply that ELL to other types of bike geometry and riding style. I mainly ride XC on a bike with a 71 degree HTA, 660mm bar and 100mm stem. So if I were to configure a bike for AM with a 68 degree head angle then I should get roughly the same "feeling of control" with a 740mm bar and 60mm stem, more or less depending on how much the HTA changes my "feeling of control".
    Ergonomically there are trade offs since our bodies have a limited range of motion. I can't turn an AM bike in the same circle as an XC bike, just like I can't ride an XC bike down a steep, gnarly downhill with the stability of an AM bike. The cliche bar width determinant is to get into your natural push-up position. In this position, the body is quite stable and difficult to topple. At the same time, maneuverability has decreased. If you imagine turning a handlebar 90 degrees in your push-up position, you might need to bring your outer shoulder to your ear and inner elbow to your hip, and you may need to arch your back to the side. If you were on tight, twisty single track then this could tire you out very quickly as you need to use a very large range of motion to negotiate the corners in the trail. I realized this as I tried many different lengths of handlebars since I started riding almost 2 years ago. If the trail is fairly wide and flowy then I can take the widest line through a corner and use a smaller range of motion with a wide bar and short stem. As the trail gets tighter, I want to get the most turn per amount of body movement, so I would opt for a narrower bar on a longer stem to keep my range of motion within comfortable limits. In either case I keep ELL the same.
    My questions: How much does 1 degree of HTA resolve to in stem length or bar width? How much does 1 degree affect the "feeling of control" when the bar and stem stay the same? As when a suspension fork gets swapped out for one with more or less travel? Does anything I mentioned above make any sense at all? lol
    Maybe I should have started a new thread...
    The leg bone's connected to the Cash Bone!
    Reputation: bigfruits's Avatar
    Mar 2011
    edit: didnt see date of post.
    Reputation: Fuglio's Avatar
    the best sized bars are the ones in my parts bin that im selling to you
    Jan 2013
    680mm crank brothers
    Reputation: Kiwiplague's Avatar
    Another good article here about bar width -Trail Tech: Are Wider Bars Better Bars? - BikeRadar
    I don't crash, I just have slightly uncontrolled dismounts!
    Reputation: nostayhome's Avatar
    Feb 2013
    Thanks for the great article. My specialized came with a 720mm bar which was just to wide for me and where I ride. I took about 3/4'' off of each side and it feels much better.
    No Stranger to danger....
    Reputation: Tone's's Avatar
    Im on 760 or 30'' Deity dirty 30s, on a 50mm stem, im only 5'8 but am fairly wide in the shoulders.
    I started at 680 and have used 3 bars to get to 30's, i use every mm of the length and theres no way i could ever go back to anything shorter, heck i recon i could go to 32''inch and still use them all..
    680-710 was just too narrow, the amount of control and comfort i have now from 30s is fantastic, even better when im standing up..
    So its 30s all the way and i strongly recommend the deity bars, cheers
    Dont ever let the truth get in the way of a funny story....
