Results 1 to 10 of 10
    Reputation: ebeer's Avatar
    Geometry comparisons (HD140,5-Spot,SB-66)
    I know the only way to get a true feel for a bike is to ride it. I've had a chance to ride the HD140, but have not yet found a demo for 5-Spot or SB-66.
    In comparing the three, it seems the HD140 and 5-Spot are bit more similar. Specifically I'm looking at two areas of geometry...virtual top tube and wheelbase. I'm interested in learning more about these because the numbers for the Yeti are so different, and without the opportunity to test ride, I'm trying understand what the differences mean.
    Are there advantages to a longer (or shorter) virtual top tube for a particular style of riding?
    Are there advantages to a longer (or shorter) wheelbase for a particular style of riding?
    Here are some numbers for comparison (Size L), as you can see the Yeti is longer all around. What would that translate to for real world handling characteristics?
    Virtual Top Tube:
    HD140: 23.7"
    5-Spot: 23.6"
    SB-66: 25.1" (seemingly big difference)
    Wheelbase:
    HD140: 44.4"
    5-Spot: (WB not listed on Turner site, but chainstay is less than .25" difference from HD140 so I'm guessing WB is at least similar b/t the two)
    SB-66: 46.3" (seemingly big difference)
    Quote Originally Posted by ebeer View Post
    Virtual Top Tube:
    HD140: 23.7"
    5-Spot: 23.6"
    Wheelbase:
    HD140: 44.4"
    checkout "stack & reach" before you make decisions based on the #'s for top tube alone. even wheelbase #'s will be effected by "S & R", but generally the longer wheel base bikes will be more stable @ higher speeds & slower to maneuver in tighter slower corners. not much info. here, so talk to manufacturers about S & B if it's not listed in the specs.
    breezy shade
    Reputation: el_chupo_'s Avatar
    Yeti's tend to run longer in the TT area than many other MFGs. Use the Med as your comparison for the SB-66, not the L.
    24.1 TT, 45.2 WB.(150mm fork)
    They dont list reach or stack.
    Quote Originally Posted by nhodge View Post
    I'll check out the R&S, however not all mfg's report these numbers making comparisons difficult. I'm certainly not looking to make a decision purely on TT or WB #'s. I just notice that for bikes seemingly in the same class, Yeti is very different than others in the same category. I understand the holistic approach and that all geometry must be considered, however with these two measurements being so different from other mfg's it makes me wonder why.
    Truth be told I don't care that much about geometry. I'd much rather just test ride and buy what feels right. But with limited availability of SB-66 I'm hoping to understand the differences until I can get some saddle time.
    www.derbyrims.com
    Reputation: derby's Avatar
    Look for KRob's recent 2011 ibike review of the SB-66, sounds like a great tail bike.
    The HD at 140mm is slacker, lighter, and stiffer than a 5 Spot.
    Quote Originally Posted by derby View Post
    Carbon's surely stiffer, but I wonder if the new 142x12 rear will help stiffen up the 2012 5-Spot. For slacker, the HD140 lists on their website almost a full degree steeper than the 5-Spot.
    Anyway, enough analysis paralysis...I just want to get a leg over the SB-66 and "feel" the difference instead of reading about it.
    Reputation: Gman086's Avatar
    Well you got the lighter and stiffer part right... I guess Turner did a lousy job getting word out on their new geometry.
    Have FUN!
    G MAN
    "There's two shuttles, one to the top and one to the hospital" I LOVE this place!!!
    wuss
    Reputation: dropadrop's Avatar
    I took a quick spin on a mojo hd 160 and it seemed to run small. The one I tried was xl and felt close in size to my size L uzzi. The owner mentioned always running size L with other brands before too...
    I would guess any recimmendations from the manufacturer regarding rider height would be different?
    www.derbyrims.com
    Quote Originally Posted by Gman086 View Post
    Have FUN!
    G MAN
    Hum... yes checked again, no change recently to ether's published. The HD140 Ibis combined head and seat angles are 0.7 degrees slacker than the 5 Spot. Not a minor detail. Is the Turner site out of date?
    Last edited by derby; 09-23-2011 at 11:46 PM. Reason: Mistaken.. said .4', in fact .7' slacker
    mbtr member
    Reputation: scottzg's Avatar
    The yeti is just a little bit slacker, a little bit lower, a bit longer wheelbase, has a little bit more travel, has a toptube that encourages a little longer stem... it's a more descending oriented bike, on paper.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
  1. Replies: 9
    Last Post: 03-23-2011, 09:34 AM
  2. Geometry comparisons
    By skiahh in forum 29er Bikes
    Last Post: 10-27-2010, 05:35 AM
  3. Replies: 12
    Last Post: 02-12-2009, 08:03 AM
  4. Spot geometry question
    By wojo14 in forum Turner
    Last Post: 11-05-2008, 06:33 AM
  5. Spot Geometry
    By Swampdonkey in forum Singlespeed
    Last Post: 01-27-2005, 01:59 PM
