Results 1 to 18 of 18
    Dec 2010
    Gears skipping on descent?
    All,
    I am having problems with my gears skipping while I am descending.
    Here is the background:
    I ride an Ibis Mojo SL with a 140mm X-fusion shock, 1x10 set-up, MRP chainguide and tensioner, SRAM XO med cage derailleur, SRAM 10spd chain and shifter.
    I live in Arizona and the terrain is super chunky. I find that when I descend at speed (25mph+) and go to pedal for more speed, my gears skip. Any ideas?
    Reputation: nauc's Avatar
    skip, like broken freehub? or changes gears
    2010 GT Avalanche Expert
    Dec 2010
    Changes gears. Its kind of exciting but not the good kind of exciting.
    It's possible that you have a small amount of play in your hub or pivot bearings and under the right forces the angle of the hub/cassette changes just enough to cause the chain to slip to the next ring.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Cable routing/cable too short. Those are often the culprits for ghost-shifting.
    Let the good times roll.
    Reputation: miniwisejosh's Avatar
    Exactly which gears are skipping? Is the chain dropping from the 2nd smallest gear to the smallest gear when you hit bumps?
    Dec 2010
    Its funny you mention this, I have been hearing some squeaking recently from the near the pivots. I am going to tear my bike apart on Wed. I let you know what I find.
    Dec 2010
    Yes, jumping between the smallest and second smallest. Truth be told, I am guessing at this one as I am looking forward at that speed vs. at the gears. However, I am in the smallest gear when it happens. I dont think it is the cabling/ routing as I have a little extra slack in the line but I will check that as well.
    I recommend double checking the limit screw and chain length. I think a too-loose chain or too-tight limit screw would cause what you are describing.
    Quote Originally Posted by btablak View Post
    Do the highest gears shift ok on the work stand?
    Reputation: Snfoilhat's Avatar
    May 2010
    The guide (upper) pulley is pretty far away from the smallest cogs in a wide (like 11-36T) cassette, and so little problems might be exaggerated. It shifts perfectly under load on a smooth road sprint, same speed, same gears?
    A medium-cage derailleur doesn't offer quite the tension a short cage would, but of course a lot of 1xs are made out of the stock 2x parts cause giving up a $$$$ RD and buying a new one is impractical.
    1) slightly bent derailleur hanger + imperfect high limit (these often go together)
    2) pedaling hard into chunk over 25 mph. Slow down?
    Reputation: felimen's Avatar
    Jun 2010
    I say hanger is bent . It don't take much. Put the bike in stand drop the chain into smallest gear stand in back of the bike and pedal while looking between the chain/gear and hanger , shine a light from under if needed and see if the gap stays the same . If it looks fine , try turning your adjuster barrel. Good luck
    Reputation: wilsonblur's Avatar
    Check everything the other posters mention and take a look at your chain wear and cassette wear as well. I had a worn cassette that would jump from the second smallest to the smallest under power when going down hill. The chain would slip out of the teeth on the second smallest gear and the tension of the derailleur would pull it down to the first. It would also slip in the smallest cog too. The smallest cogs don't have as many teeth in the chain as the bigger ones do and will be one of the first places that lets you know your cassette is worn. Hope its something easier and less expensive than this.
    Narrow is the path to life, few are those who find it.
    Check your b screw on the rear derailleur. It could be too far away from the cassette.
    squish, squish in da fish
    Reputation: fishwrinkle's Avatar
    ^^^ i bet ya thats it.
    Dec 2010
    Quick Update - I checked the hanger and it was not bent. Good news. I also checked the chain, cog, and chain ring for wear and they all looked good. Again, Good news. I checked the rear triangle - and it was loose. Not too bad but enough. I tightened it up and have *less* skipping. I am working on the bike this weekend and will check the b-screw. Thank you all for the ideas!
    Reputation: Gman086's Avatar
    3rd on the b-tension being to tight as that won't wrap as much chain around the smaller cogs and chain can skip to the smallest cog!
    Have FUN!
    G MAN
    "There's two shuttles, one to the top and one to the hospital" I LOVE this place!!!
    Reputation: Fuglio's Avatar
    its a shitty tune job on a bike that loves to throw chains
  1. Skipping gears one way, perfect the other, going crazy.. (VIDEO ADDED)
    By ja001son in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-18-2013, 12:58 AM
  2. Skipping chain on high gears
    By tsjwdf in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-28-2013, 06:00 AM
  3. Trance x4 skipping gears
    By kevingp in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-25-2012, 09:09 AM
  4. Gears skipping
    By LSmith4285 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-24-2011, 05:57 AM
  5. 2x9 setup, chain rubbing on tyre, skipping gears
    By nuclear_powered in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-13-2011, 03:34 PM
