Results 1 to 2 of 2
    Fuji Thrill LT 2.0(2009) Good or Bad?
    Hello everyone,
    im looking at buying a new Fuji Thrill LT 2.0 for $900(retail $1800). here are the numbers...let me know what you think please.
    MAIN FRAME: Fuji Altair 2 aluminum, custom butted, integrated head tube, top tube/seat tube gusset, down tube gusset, water bottle mount
    REAR TRIANGLE: Fuji Altair 2 aluminum, custom butted and shaped with Four Bar linkage system (150mm travel), Cold forged dropout with CNC'D disc mount and replaceable hanger, Sealed bearing pivots
    FORK: SR Suntour Duro FR20 w/Rebound & Compression Adjust, 150mm Tavel
    REAR SHOCK: SR Suntour Epicon LOD with lockout, compression and rebound adjust.
    CRANKSET: TruVativ Blaze 3.1, 22/32/44T Chainring
    BOTTOM BRACKET: TruVativ Howitzer M15 Cartridge Bearing
    PEDALS: Nil
    FRONT DERAILLEUR: SRAM X.7, 34.9mm dual pull
    REAR DERAILLEUR: SRAM X.9
    SHIFTERS: SRAM X.7 Trigger 27-speed
    CASSETTE: Sunrace CSM969-AVOS, 11-34T 9-speed
    CHAIN: KMC HG-73
    FRONT HUB: Formula DC-91 Sealed Bearing Disc 20mm TA, 32H
    REAR HUB: Formula DC-22 Disc, 32H
    SPOKES: 14G Stainless Steel
    RIMS: Alex SX-44 Double Wall Disc Rim
    TIRES: Continental Mountain King 26 X 2.4"
    TUBES: CST Presta
    BRAKE SET: Tektro Auriga Comp Hydraulic Disc brake, 203mm Rotor
    BRAKE LEVERS: Tektro Auriga Comp
    HEADSET: VP A-42E 1 1/8" Press Fit Integrated, 30mm spacers
    HANDLEBAR: Fuji Pro Low Rise 31.8mm, Double Butted Al
    STEM: Fuji Forged Al 1 1/8"
    TAPE/GRIP: Fuji Lock-On Kraton rubber
    SADDLE: WTB Pure V Race Comp
    SEAT POST: Fuji Pro Zero Offset AL, 350mm
    SEAT CLAMP: Fuji Superlite Alloy, 34.9mm Laser Etched
    WEIGHT,LB./KG.: 34.59/15.69
    Feb 2013
    did you buy it and if you did, please post review, thinking of bying the same for my son
