Results 1 to 11 of 11
    Sep 2013
    Front tire handling
    I am 137 lbs and ride a 26"full supension specialized xc with a very beefy tire on the front. I have been riding for years and am confindent all except cornering with the front end. I ran 25 lbs the other day and still thought the front end felt scetchy.. I end up going way wide especially on faster turns to compensate from feeling the front washout. Any suggestions, maybe lower pressure or handling skills.
    I ride a Swarf
    Reputation: Stuart B's Avatar
    Mar 2005
    i'm a fair bit heavier than you and run about 20psi in my front tyre (either a muddy mary 2.35 vertstar or high roller super tacky 2.35).
    Also try moving your weight forward more to weight the wheel up.
    What exactly is a rigid hard tail?
    Reputation: nauc's Avatar
    what tire are you using
    Reputation: Technician's Avatar
    Oct 2013
    I'm 140-145 lbs. Ever since I got my new 26" Stumpy Comp in July I've been running the pressure in the tires just by feel. I assumed that they were at about 25-30 lbs. I recently got a new presta guage, and was shocked to find that I had been running them at about 20. Maybe try that. I'm also putting a Specialized Butcher Control on the front this week for the winter, and I think that will hold a corner better too (than the Purgatory).
    I call him free who is led solely by reason. (Baruch Spinoza)
    Reputation: CarolinaPanthers's Avatar
    Feb 2013
    Quote Originally Posted by nauc View Post
    if its an offering from maxxis, or any other tire with a naked transition zone, you may not be leaning the bike over enough for the side knobs to really do their thing - staying in that transition zone could account for some sketchiness.
    Unpredictable
    Reputation: Ridnparadise's Avatar
    +1 on the Maxis need for lean angle. I run a High Roller II on the front (as of 2 days ago when my old HRI was binned). I have a Purgatory on the back. I generally use 24-26lb both ends as the Purg is a beefier tire.
    You just have to commit to the High Roller and trust it. One suggestion is perhaps to put more body English into the turns - try to compress into the turn and rebound out of it to get more bite.
    Trail Gnome Moderator
    Reputation: griz's Avatar
    Jan 2011
    Quote Originally Posted by pearce9375 View Post
    How's your fork working? If tire pressure doesn't fix your problem, you may want to soften up the front end?
    Oct 2013
    Any response from the OP?
    Jan 2011
    Quote Originally Posted by Technician View Post
    I think he crashed
    think he took up golf
  1. Replies: 11
    Last Post: 09-19-2013, 07:27 AM
  2. Rear Tire suggestions that complements Weirwolf front tire
    By zgroove in forum General Discussion
    Last Post: 08-09-2013, 11:40 PM
  3. Front tire and rear tire size comparison question help?
    By Yellowr6 in forum General Discussion
    Last Post: 02-21-2012, 05:50 PM
  4. Front tire and rear tire size comparison question help?
    By Yellowr6 in forum Wheels and Tires
    Last Post: 01-26-2012, 12:54 AM
  5. Replies: 4
    Last Post: 01-03-2012, 09:38 PM
