Results 1 to 6 of 6
    Reputation: toot334455's Avatar
    Apr 2013
    Fox Terralogic Or iCD with electronic lockout?
    What would you rather have long term and would be better for maximal performance?
    Afric Pepperbird
    Reputation: dirt farmer's Avatar
    Mar 2005
    Why, anything non-electronic, of course!
    Electronics on a mountain bike??!! Absurd!
    Apr 2013
    yea lol, seems silly.
    The same setup is done with the CTD and cable shifters.
    But then again the CTD with remote or terralogic where you can just relax and let the fork do all the work lol....
    Apr 2013
    Quote Originally Posted by toot334455 View Post
    Dont knock it till you try it. iCD is the best remote lockout system available. Cable-actuated lockouts are clunky and slooooow by comparison, and you're always second guessing whether you pushed the lever far enough or which position it's in.
    I'm running iCD front and rear and love it! It lets you squeeze every last bit of power out of your bike and legs and, IMHO, is a much better performance invest than lighter wheels. It doesn't matter if you have less rotational inertia if your squishy suspension soaks up all your power bc you can't effectively control the lockout while navigating technical terrain.
    With iCD, you never take your hands off the bars. So you can use it to do things like lockout travel to pump sections of the trail, lock it out on the exit of corners to maximize your drive, lock it for sprints and climbs, especially steep sections intermixed with rocky and smooth areas that require bursts of power.
    A HUGE benefit of iCD is that it lets you run your sag much much more plush since you can firm it up in a split second.
    Apr 2013
    Double post...
    Reputation: JPBakerIII's Avatar
    Mar 2012
    I have terralogic forks. They work great once you get them dialed in, but I pretty much never do a total lockout on them. If you need total lockout, go with the iCD.
    The terralogic can be set to stay stiff on most climbs and flats but that just takes most of the bob out, and does not entirely eliminate the bob as if they are locked out. If you plan to stay on flats or blacktop, you could set the terralogic so they are essentially locked out but then they are locked out until you stop the bike and reset them.
    Hope that helps.
    1990 Schwinn Sierra MOS
    2011 Santa Cruz Chameleon
    2012 Cannondale Claymore 2
  1. Replies: 32
    Last Post: 12-18-2012, 08:51 AM
  2. Fox Fork w Adjustable Lockout - Stay in Lockout?
    By davidbeinct in forum Shocks and Suspension
    Last Post: 08-08-2012, 01:35 PM
  3. Fox Testing New Electronic Lockout?
    By Cyclingdirt in forum XC Racing and Training
    Last Post: 03-07-2012, 09:33 AM
  4. Lockout on RS Recon Silver TK Air 29er: solid lockout? Like Rigid?
    By connolm in forum Shocks and Suspension
    Last Post: 11-25-2011, 03:04 PM
  5. DT M210 remote lockout, lockout doesn't work
    By Danne in forum Shocks and Suspension
    Last Post: 10-03-2011, 12:43 AM
