    Fox F-series 100mm Vs. Rock Shox Sid Team
    Both these forks are in the same price range, having trouble deciding. I can get the better deal on the rock shox sid team, but i see the least of these around, fox f-series on everything.
    Is there a reason for this? Input needed
    some know me as mongo
    well its the wrong forum but i will say that i have a New style sid on my xc bike and i'm loving it. stiff as it should be for a light fork and the fluidity on the travel is also great. and that is coming from a 260 lbs rider.
    Reputation: boomn's Avatar
    The RockShox Reba is more comparable to the Fox F100 in terms of weight, stiffness, and intended use. The SID is a no-apologies XC race fork, while the Reba and F100 are both meant to be great all-around performers
    EDIT: upon further research it looks like the new F100 is actually closer in weight to the Sid. Regardless, I would personally choose the Reba Race because I would rather have the extra $200 than the 0.2lb weight difference. But, again, that is your decision to make.
    Reputation: Broccoli's Avatar
    If you are in the right forum you would have been asking about Reba with 20mm Maxle vs Fox with 15mm (and there will be a rush of zealots blabbing about how 15mm is a unneeded standard).
    Given the original question, while I have no problems with a new 32mm SID (old one was a noodle), its intended purpose will give me a pause on anything but a lightweight XC ride. But it performs seemingly identical to a Fox 100 I used to have. Given the two I would pick Magura Durin Race.
