Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 76 to 100 of 128
  1. #76
    meow meow
    Reputation: b-kul's Avatar
    i was quite opposed to this, mainly the lever, but it is growing on me. if reliability proves good i may give it a go.
  2. #77
    Reputation: Whason's Avatar
    Maybe you're right, but what other reason to drop the price other than its not selling as well as expected?
    Quote Originally Posted by peanutaxis View Post
    I completely disagree. There's plenty of competition out there - At least 4 brands making them. But the R&D put into something like this is insane. They're more complex even than suspension forks because everything has to fit into a tiny seat post!
    "Chancho. When you are a man sometimes you wear stretchy pants... Its for fun..."
  3. #78
    meow meow
    maybe the high price was to create hype? common marketing tactic. when it didn't take of like fox wanted they lowered the price.
  4. #79
    Quote Originally Posted by b-kul View Post
    Hehe, maybe fox knew that they are so notorious for useless seals that they went mechanical to avoid it.
    Quote Originally Posted by Whason View Post
    It's better to drop the price and make less profit than have none sell and make a loss.
  5. #80
    Dec 2010
    Friend has one and has been a maintenance disaster! seals and has a tendency to go down on it's own any given time.went back to a Reverb much more dependable and is a better product.I run a Reverb too works perfectly and use it daily!
  6. #81
    Reputation: ihaveagibsonsg's Avatar
    I looked at these. Couldn't figure out why it costs so much though? I'm confused why any adjustable seatpost costs over 200$. I bought the Giant contact switch and its been totally reliable and does the same thing all the other posts do but for half the price.
  7. #82
    taking a risk at putting one on my nomad. left it at my lbs yesterday as i'll be going out of town and will be back on monday. kinda anxious to see how it will go. and also, i asked my lbs to see if they can do something about the huge lever. x-fingers!
  8. #83
    Quote Originally Posted by DexTan View Post
    If you swap your front shifter to grip shift you can run the lever under the bar. It's much more comfortable.
  9. #84
    Nov 2006
    Has anyone tried this post with a different lever? Would like to try one but only if I can put a smaller lever on the bike.
  10. #85
    Sep 2012
    I wish Fox used this lever for the DOSS.
  11. #86
    Quote Originally Posted by sancycling View Post
    I tried an Epicon (suntour) fork remote but it's a no go. the throw on the suntour remote is too short and i can only go down to the TRAIL setting. would like to get my hands on remotes from KS and DNM to try em out.
  12. #87
    Feb 2013
    I am going to run the DOSS on my Yeti 575 build (it will fit in with the other Fox components I am putting on).
  13. #88
    Reputation: scotteric's Avatar
    Aug 2005
    I'm hoping someone who owns a DOSS can give me a measurement. What I'm looking for is typically called the "insertion length" (yeah ha-ha) measured from top or bottom of collar to bottom of (black) inserted end....I realize there is an air valve too but don't think this would be an issue. Also not sure if the 125mm and 100mm will have a different measurement but would likely get a 100mm version. Thanks
  14. #89
    Reputation: keepbalanced's Avatar
    Dec 2012
    these look like they have a lot of potential for problems but cool product. I would like to have one of these one day.
  15. #90
    DOSS post with a XTR Left shifter!!!
    I noticed Jared Graves had that setup recently at Punta Ala. `
  16. #91
    Mar 2011
    Is it possible to buy different diameter external tube to change 31.6 to 30.9?
  17. #92
    Mar 2013
    I'm thinking to get this fox doss or reverb 2013. So you have any problems if you use it in extreme weather conditions such as heavy rain or if its covered with mud, does it affect the reliability and durability?
    Also how long is the cable the comes with it and why did you use the jagwire instead of the stock wire that comes with this fox doss?
  18. #93
    Sep 2013
    I've had one for close to a year now. It saw a ton of mud use last winter with no ill effects. The cable that came with mine was plenty long enough for both my medium AM and DH bikes (I switch it between bikes).
  19. #94
    Mar 2013
    my Fox DOSS arrive this morning. It took me 1.5 hrs to install, because I had difficulties internally route the cable inside my frame, but the actual installation of remote, cable, seatpost took only 15 mins.
    This seatpost is superb I really like the quality and I guess the durability. The only problem the return is too fast even though I pump 10psi only. I might reduce further once I use it on the trail .
    This seatpost is better than Rock Shox reverb.
    Preferences
    <canvas class="button_canvas" width="32" height="32">§</canvas>
    <canvas class="button_canvas" width="32" height="32">1</canvas>
    <canvas class="button_canvas" width="32" height="32">2</canvas>
    <canvas class="button_canvas" width="32" height="32">3</canvas>
    <canvas class="button_canvas" width="32" height="32">4</canvas>
    <canvas class="button_canvas" width="32" height="32">5</canvas>
    <canvas class="button_canvas" width="32" height="32">6</canvas>
    <canvas class="button_canvas" width="32" height="32">7</canvas>
    <canvas class="button_canvas" width="32" height="32">8</canvas>
    <canvas class="button_canvas" width="32" height="32">9</canvas>
    <canvas class="button_canvas" width="32" height="32">0</canvas>
    <canvas class="button_canvas" width="32" height="32">-</canvas>
    <canvas class="button_canvas" width="32" height="32">=</canvas>
    <canvas class="system_button_canvas" width="100" height="32">Backspace</canvas>
    <canvas class="system_button_canvas" width="32" height="32">Tab</canvas>
    <canvas class="button_canvas" width="32" height="32">q</canvas>
    <canvas class="button_canvas" width="32" height="32">w</canvas>
    <canvas class="button_canvas" width="32" height="32">e</canvas>
    <canvas class="button_canvas" width="32" height="32">r</canvas>
    <canvas class="button_canvas" width="32" height="32">t</canvas>
    <canvas class="button_canvas" width="32" height="32">y</canvas>
    <canvas class="button_canvas" width="32" height="32">u</canvas>
    <canvas class="button_canvas" width="32" height="32">i</canvas>
    <canvas class="button_canvas" width="32" height="32">o</canvas>
    <canvas class="button_canvas" width="32" height="32">p</canvas>
    <canvas class="button_canvas" width="32" height="32">[</canvas>
    <canvas class="button_canvas" width="32" height="32">]</canvas>
    <canvas class="system_button_canvas" width="100" height="50">Return</canvas>
    <canvas class="system_button_canvas" width="32" height="32">capslock</canvas>
    <canvas class="button_canvas" width="32" height="32">a</canvas>
    <canvas class="button_canvas" width="32" height="32">s</canvas>
    <canvas class="button_canvas" width="32" height="32">d</canvas>
    <canvas class="button_canvas" width="32" height="32">f</canvas>
    <canvas class="button_canvas" width="32" height="32">g</canvas>
    <canvas class="button_canvas" width="32" height="32">h</canvas>
    <canvas class="button_canvas" width="32" height="32">j</canvas>
    <canvas class="button_canvas" width="32" height="32">k</canvas>
    <canvas class="button_canvas" width="32" height="32">l</canvas>
    <canvas class="button_canvas" width="32" height="32">;</canvas>
    <canvas class="button_canvas" width="32" height="32">'</canvas>
    <canvas class="button_canvas" width="32" height="32">\</canvas>
    <canvas class="system_button_canvas" width="32" height="32">shift</canvas>
    <canvas class="button_canvas" width="32" height="32">`</canvas>
    <canvas class="button_canvas" width="32" height="32">z</canvas>
    <canvas class="button_canvas" width="32" height="32">x</canvas>
    <canvas class="button_canvas" width="32" height="32">c</canvas>
    <canvas class="button_canvas" width="32" height="32">v</canvas>
    <canvas class="button_canvas" width="32" height="32">b</canvas>
    <canvas class="button_canvas" width="32" height="32">n</canvas>
    <canvas class="button_canvas" width="32" height="32">m</canvas>
    <canvas class="button_canvas" width="32" height="32">,</canvas>
    <canvas class="button_canvas" width="32" height="32">.</canvas>
    <canvas class="button_canvas" width="32" height="32">/</canvas>
    English
    Deutsch
    Español
    Français
    Italiano
    Português
    Русский
    <canvas class="button_canvas" width="32" height="32">alt</canvas>
    <canvas class="button_canvas" width="32" height="32"> </canvas>
    Preferences
  20. #95
    Anybody know about maintaining these. I have two of them, and with the weather change I had to add air to them to get them to rise all the way up. Not a problem, but when I let a little air out a bunch of dirty liquid came out too.
    Is this oil? Does it need to be changed? I don't use water to clean my bike, so I'm not sure what it is. BTW, Six months on each and love them, best seatpost I have had.
  21. #96
    Yr or 2 down the road how are everyones DOSS posts holding up?
    Anyone manage to open one/service theirs at home DIY?
  22. #97
    Sep 2013
    Still running perfect. When it got really cold last winter I needed to add a little air to compensate but that's it. Haven't needed to open it. I'd think you'd need a LOT of cycles before you need to service.
  23. #98
    Its really weird, this post seems to be flying well under the radar, doesn't appear to be very popular for whatever reason, not many people discussing it apart from when it was launched. I can't find any people having major issues with them and apart from the odd DOA the very opposite seems to be true, they are rock solid and need very little maintenance. A good few DOSS people seem to be coming from hydraulic KS or Reverbs and having had many failures there try the DOSS and sail on hassle free. Major website reviews all seem to give the post flying colours.
    The major nag seems to be the huge ungainly lever and the lack of infinite travel, both which after using people enjoy, just not the levers looks but the 2 stop functionality seems to be a win. The 2 stop design is also what makes the post so rugged.
  24. #99
    Sep 2013
    The lever position sucks if you run a front trigger shifter. If you run 1x or use a grip shift for the front derailleur it's awesome (this is what I do, gripshift for the front derailleur, trigger for the rear).
  25. #100
    With the weather change I noticed my post is not popping up like it used to. How much air pressure should I put in the canister?
