Results 1 to 8 of 8
    Reputation: Turbocharged's Avatar
    Fox 32 Float 140 RLC or Revelation RLT for Transition Bandit?
    So now that I think that I've decided to get a 2012 Transition Bandit 2, I have to make the choice between the Fox 32 Float 140 FIT RLC and the Rockshox Revelation RLT 140 Dual Air.
    I'm a long time 20mm axle Marzocchi owner and this is my first time devling into either brand or into the trail bike/QR15 realm, so I'm just looking for opinions of each here. Thanks.
    2014 Canfield Jedi - 2015 Canfield Balance - 2012 Canfield DJ
    North Van/Whistler
    Try to get Revelation in 20mm; having said that I liked the OE Fox Float 140. It's a pretty close call.
    Locals' Guide to North Shore Rides http://mtbtrails.ca/
    Quote Originally Posted by LeeL View Post
    Revelation would have to be 15mm because it is part of Transition's build kit...
    http://www.transitionbikes.com/Bikes_Bandit.cfm?Token={ts_2012-06-24_13:44:12}-e651b7ff65be40af-3E136D3F-08DB-F3C4-33BF51CD83FBDBE6
    T.W.O
    Reputation: pfox90's Avatar
    Aug 2010
    Are you buying the build kit from them or...? Because you could always get a marz. Between the two I would rather get the Rev.
    ------__o
    ----_`\<,_
    ---(_)/ (_)
    The Revelation is awesome.
    Reputation: Luigiugueto's Avatar
    Oct 2007
    Im buying a Bandit 2 pretty soon as well. Having ridden Fox for over 5 years I dont think ill be changing to anything else I personally dont think theres anything better suspension-wise.
    Either way the axles gonna be the same (15mm) so itll all come down to preference I guess...
    When you say Bandit 2 im assuming youre buying Transition's build kit, where is the fork option?? I thought they only offered the Float. Never mind, found the small lettering where they give the option. Oh well, ill be keeping the fox anyway..
    North Van/Whistler
    I've only ridden the Revelation 140 with 20mm - so can't offer any insight.
    Reputation: JammerNinerBoxx's Avatar
    Fox 34 140mm.
