Results 1 to 44 of 44
Thread: Fox 32 or 36
    Reputation: Saxon9598's Avatar
    Fox 32 or 36
    OK, I think I'm going to regret asking this but here it goes, I'm building up a Blur LT Carbon, I'm a heavy guy, I will be using this bike for AM and trail, my problem is....
    I keep hearing that the fox 150 Talas 32 15mm is a flexy bug, I hate fork flex I don't like the RS 351 u-turn on my XC bike for that reason.....on the other hand the fox 36 talas is 1lb heavier but stiffer (from what I understand, never ridden a fox fork for more than a few minutes)...adding to the problem is the fact that the fork has to be tapered 1.5/1 1/8. and yes I know I can use adapters but that ads expense and weight and flex, this is an odd head tube. so my question is, what would you do in my place, my riding friends are half and half, I cant decide because I have never ridden the forks.......I weigh 230 (not fat) and ride aggressive. my worries are I'm going to put the wrong fork and then hate the bike for the it....thanks....oh and if your going to comment, please have some actual physical experience with the forks or bike....Thanks Dave
    F88me самолюбивый член
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    I'm very happy with my Fox Talas 32 150.
    I put 3 days of black diamond whistler XC on it last week, and the fork took everything I could throw at it. FWIW I've ridden the same trails on my 6" bike with a Talas 36, and I didn't feel the 32 fork gave up anything in terms of stiffness or performance. I weigh 175lbs.
    The one thing I would say, the Talas 32 150 is a full inch shorter than the Talas 36 a60, despite having 1cm less travel. So, consider what length of fork will work best with your frame.
    Is that Bill rated?
    Reputation: Lord Humongous's Avatar
    Go 36
    You will hardly notice the extra .4% total system weight when climbing, it's not the same as putting an extra pound of wheels on your bike and you no doubt have the strength to cope. I have nothing against the 32 chassis, but at 230 pounds myself I find a myriad of reasons to prefer the larger stanchions and consider the minor weight increase well worth the extra steering performance. My situation is a little different, but I have one bike with a 4.5 pound Nixon featuring 32mm stanchions and a 20mm hex axle and another bike with an 8 pound Travis featuring 34mm stanchions and I almost always choose the larger fork when I go riding. I have run a 36 in the past and I have used several 32 series forks, both on my own ride and on loaners and I would definitely choose a 36 FLoat before getting any other Fox fork. Steering is key for my riding experience, I am not some kind of huckatron, I just find deflection puts me off my game.
    Well, it was a good try.
    Quote Originally Posted by FM
    Thanks, thats the kind of info I was hoping for
    MattSavage
    Reputation: mattsavage's Avatar
    Sep 2003
    I was considering getting one (carbon BLT) before I got my Remedy... i rode two, one with a 32 and another with a 36. I definately preffered the 36 on that frame. Much better geometry for higher speeds and steep techy stuff... The 32 would be a quick, tight pedal'y single track killer, but that doesn't really exist around here. You're a bigger guy too, so I'd go 36. On that note, I'd also go with the aluminum model instead of carbon. 230# and aggressive riding sounds risky on a carbon bike at this point. At the time I was 210 and was a little skeptical. Maybe for little 150# feller, but not a clyde!
    Another point, I'm not totally stoked on the TALAS fork either. It's either harsh with no brake dive or pedal bob, or it's super sensitve to small bumps, but then wallows all over the trail. I can't find a sweet spot on it, unless it's in the 140mm setting. If I hadn't swapped it for a Nixon 160, I would have gone with a 36 Van...
    "I wrote a hit play! What have you ever done?!"
    Have Ashtray, Will Travel....
    [QUOTE=FM]I'm very happy with my Fox Talas 32 150.
    http://www.santacruzmtb.com/blurlt_c....php?builder=1
    Reputation: chrissa's Avatar
    Hmm, are you sure the Blur LT Carbon is the right frame for your size and riding style if you're worried about whether you need a Fox 36 or not? I think the Fox 36 is a little overkill for a Blur LT. I see that fork on the front of a frame like a Nomad.
    I do own both a Fox 36 Float and a Fox F120. The 36 is like a mini DH fork and can rip it up very confidently on Whistler. My 36 is mated to a Foes FXR frame. I would think a smaller, lighter frame would upset the balance of the bike big time.
    My F120 is no where near the 150mm you're looking at (and I'm 70 lbs lighter than you), but it is a very capable trail fork. I'm not jumping anything big at all with it, but it's fine.
    I would be very cautious about sticking a large tough fork like that on a smaller, lighter frame. It may upset the general balance, plus the fork will encourage you to write checks that the rest of the bike can't cash. Just my opinion. It is a tough call though.
    Chris.
    Quote Originally Posted by chrissa
    Chris.
    I hear yah, the thing is that the 160mm fork is a factory option so its on the table. afther reading some of the coments I'm leaning hard towards the 36
    squish is good
    Reputation: Clutchman83's Avatar
    The Blur was designed to accept a 36 just fine. I'd prefer a 36 myself for the geometry. I've never been one for steep head angles. I'm also fundamentally opposed to the 15mm axle personally, even if it feels fine it doesn't hold up to the 20mm under testing. Whether that matters for riding is debatable but I don't see any reason for the new axle size personally.
    Bike good, work bad.
    Dec 2005
    You will probably notice the geometry difference more than the weight difference.
    I just ordered the talas 36 thanks Dave
    Nov 2008
    good call--I just switched from a 32 vanilla to a 36 float on my heckler. I rode today on some rough, technical terrain, and the 36 was noticeably stiffer yet also more forgiving than the last time that I rode there on the 32 van. I couldn't be more pleased.
    Good move !Get ready to rail some corners.
    Reputation: Gman086's Avatar
    Yup, there's a hole in Fox's lineup between the two. IMHO the Pike fits the bill perfectly and has better damping than the 36.
    Have FUN!
    G MAN
    "There's two shuttles, one to the top and one to the hospital" I LOVE this place!!!
    Mar 2006
    I run a Magura Thor 20mm axel on my Blur the double arch and 20mm really stiffen the front.you can really feel the rock solid difference in high speed berms,no noticeable flex.this is by far the best overall five inch fork I've owned to date.
    it's....
    Reputation: Strafer's Avatar
    Quote Originally Posted by Gman086
    Have FUN!
    G MAN
    New 2010 Revelation 150 Blackbox seems like the optimal choice, AC between Fox 32 and 36.
    Fox36 Talas ,or Lyric I'm 220lb in my gear and the 36 over 32 is real apparent to me,
    people who are lighter don't know, the Lyric is slightly stiffer for me.
    Reputation: DJ Giggity's Avatar
    I recently swapped a Talas 150mm for a lyrik on my Tracer VP. At 170lbs the Talas is acceptably stiff. I noticed the geometry change much more than the weight change. The Talas is now for sale. At 230lbs I think it would be a no brainer.
    Only two infinite things exist: the universe and stupidity. And, I am unsure of the universe
    - Albert Einstein
    Im in the same boat, i weigh 200lbs and currently have a fox float 32 160mm on my bike and i can feel the flex, im looking at the van 36 rc2 here in a month or so if someone will buy my float haha, its a great fork, but not enough for my type of riding.
    Plus look how skinny it looks
    Still on training wheels
    Quote Originally Posted by jeffus
    Weird, I feel the opposite. Allthough the Lyrik rails in the rough it's not as stiff as I'd like in the back-and-forth motion. So when I hit a rather big obstacle at speed it "hangs" a little and then skip forward. Try braking hard while watching the fork using a 36 and a Lyrik to see if there's a difference.
    I'd also prefer a 36 for stiffness and geometry on the LT. The difference in chassis stiffness will be progressivly more evident the heavier the rider is. I personally find stiffness to be as important as damping quality and even prefer bolt on rear wheels on my AM bikes.
    Quote Originally Posted by readingracing
    Been eying the Thor lately. Would be interesting to hear what forks you have owned before you compare the Thor with.
    Cheers!
    mbtr member
    Reputation: scottzg's Avatar
    Quote Originally Posted by Intrepidity
    That hanging sensation is more of an indicator of funky compression damping set up or stiction, in my experience. shrug.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    FM
    FM is offline
    Apr 2003
    Quote Originally Posted by altezza2k2
    That there is a great example of a MTBR thread gone totally wrong
    Again, I own both these forks (Talas 32 150rlc and Talas 36 160rc2) on different bikes. I cannot think of any piece of trail where I wished I had one over the other. They really do feel nearly identical to me, in terms of suspension and stiffness. By far the biggest difference is the axle-to-crown length- an inch of difference! So go with the one that your frame was designed to work with.
    Not to beat a dead horse but.... duh, of course the 36 is stiffer! It's also an inch taller and a pound heavier. That doesn't make it a better fork- just a better match for bikes designed around a 545mm axle-to-crown length fork. The Talas 32 150 is 521mm a2c, a better match for shorter travel bikes. According to Santa Cruz's website, the Blur LT-C is designed around a 515mm fork.... so, if you go with the 36, you'll be slackening the angles out by 1.5 degrees and also raising the BB 1/2" or so. Also, I do not see the Fox 36 listed on the bike builder page. I think for that frame, the Talas 32 150 is a perfect fit. If you think you need more fork, maybe go with a burlier frame too.
    didn't think there was a real choice of fork travel.If you chopper a bike with a longer fork than it's really designed for,you might gain a little bit of cushion in a straight line,but don't you lose some of the tracking precision that you have with a short(proper) fork because less of your weight is on the front tire.
    I have two forks i can use on my azonic saber,a classic z150 and an "all mountain 165", the bike is much more stunt worthy with the z 150 and feels a lot less stabile with the "all mountain" on it. I'm currently using the 165 because it's just so much lighter.They are not even 15mm different because the z150 is very long for a 150mm travel fork, but the front end just feels like it tracks so much better with the z 150. When i first engage the rebound lockout on the All Mountain it feels alot better,but if i forget to disengage that feature, the travel vanishes,and it of course the bike gets very squirrely.
    mbtr member
    In principle you have a really, really good point, but i disagree. I'm the same size as the OP, and i would no-way-in-hell run a talas 32 150. That thing is sketch-flexy, and while it worked great for the xc bike on stilts i demo-ed it on, i wouldn't put one on my own bike. I'd rather use the talas knob constantly (36 @ 130 =~32 @150), or get a float and spacer it down.
    Although it might be a good move on a carbon bike, keep you comfortable but not pushing the envelope and crashing the thing. Maybe that's my anti-carbon bias talking. 100% of the carbon mtbs i've seen crash have lead very short lives.
    i fall in the 'eww, too light' camp in general, even for XC/trail bikes. When you're 230lbs, i think you have to.
    Mikhail Kalashnikov
    Oct 2007
    carbon takes impacts better than aluminum. a crash that would damage carbon would absolutely destroy aluminum beyond use. theres plenty of videos of people taking hammers to carbon frames on youtube.
    that said, im not a fan of carbon, nor do i ride carbon.. but it is plenty strong..
    mbtr member
    Quote Originally Posted by tomsmoto
    That's not what i've observed firsthand.
    Mikhail Kalashnikov
    Oct 2007
    they make fighter jets out of the stuff man, its strong
    the problem is process. its easy as hell to make an aluminum tube.. it takes an amount of experience to make a strong carbon tube.. but if its made properly, its plenty strong. a poor carbon tube is very weak. i just dont think any marginal advantages are worth the huge price jump.. but if someone else has the cash, hey go for it.
    FM
    FM is offline
    Apr 2003
    Quote Originally Posted by scottzg
    I think that does just come down to size & weight.
    I've hit some decent drops on my talas 32, and ridden a bunch of whistler black diamonds, was very impressed with the fork so far. You guys have 50lbs on me so your experience may be different- but I still think it's best to pick a frame/fork combo that was designed to work together. Otherwise- regardless of head angle- the steep angle gets slack and BB gets tall, then the bike handles funky.
    Not a bad idea about running a float or talas with the travel reduced- just keep in mind that the Talas 36 at 130mm has roughly the same length as the Talas 32 at 150mm. So, you are trading down in travel to get additional stiffness.
    In reality, I think the short a2c length is partially behind the "flex" people notice with the Talas 32 15mm fork- it steepens up the head angle, creating more "nervous" feeling handling.
    What is the biggest sized brake rotor that will fit on a 36?
    Quote Originally Posted by ferozoso
    203mm probably.. that's what I am running at least.
    Yep, I know it sounds like it and I expected that reply. But no, it's not the compression damping that is to blame. No stiction either..
    That is my plan. the light riders sometimes just don't understand how bad we can flex the frame fork and even the wheels, it just takes the fun right out.
    I plan on using this bike for "light" AM/Trail. dare I say XC, the furthest I have ever pedaled was 16 miles on some insane steep terrain, and you know what...I loved it. I will be using this bike on 6-12 mile rides once maybe twice a month.
    I have a 100mm DJ, 34lbs 6" AM and and a 42lbs 7" FR big hit bike, and they all get the love, so crossing this bike over to extreme duty was never my intent, I just want a lightest strongest bike that wont feel like its folding in half when I stand and power through a section or hit a root or some thing, its really annoying. I'm a big dude that likes to pedal.....there is not a lot of high performance choices for guys like me. we go light and snap or heavy and puff huff puff... and its just so hard to be accurate in description of riding stile, because what I call AM might be FR for some and XC for others.....all these damn labels suck and confuse the hell out of me..its like spicy...it might be mild to you, but unbearable to me...hope that cleared up a bit, thanks for all the replies guys. they were very informative and solid, especially the ones on AtoC numbers. I hope I got this right or my AM just got a new fork
    Quote Originally Posted by Saxon9598
    (...).its like spicy...it might be mild to you, but unbearable to me...hope that cleared up a bit, thanks for all the replies guys. they were very informative and solid, especially the ones on AtoC numbers. I hope I got this right or my AM just got a new fork
    Speaking of spicy, the bike Lapierre Spicy might would probably have been anything but unbearable considering what kind of qualites you are looking for :-)
    http://www.bikeradar.com/gear/catego...y-516-09-32457
    Quote: "Very light for its travel, extremely stiff despite a climb-friendly length and with suspension thatís totally controlled, the Spicy is a truly outstanding trail bike thatís ready for anything you are."
    The Crow
    Reputation: Iwan's Avatar
    Had a 32 Float, 32 Talas (150mm 15mm) and 36 Talas on my Ibis Mojo and the 36 was by FAR my favourite. Being slightly heavier is it's only downside. Other than that...36 is the better option.
    Maybe for somebody else who doesn't ride as hard it won't matter that much then a 32 will do. Ibis was build quite heavy so 36 was perfect.
    I currently own a Morewood Mbuzi with a Float 36. Freaking brilliant fork.
    There's a feeling I get
    When I look to the West
    And my spirit is crying for leaving
    FM
    FM is offline
    Apr 2003
    Quote Originally Posted by Iwan
    I totally agree.
    Just look at the pros... it's obvious 32mm stanchion forks aren't up for riding hard!
    Ben Boyko's 32mm fork & him riding it:
    squish is good
    Dude, it's not the stanchions. It's the axle...
    Oct 2007
    i do like how he posted up a marzocchi fork when talking about the fox 32
    FM
    FM is offline
    Apr 2003
    Oops, my bad.
    Dan Atherton chooses the 32 over the 36 for his slalom bike. Looks flexy to me!
    Oops, my bad.
    my wife decided she was going to settle it, she ordered me a 32 talas, if I like it I can put the 36 on her AM, if I don't I put the 32 on her XC bike I love this girl
    this is her by the way, on a 32mm fork on her Jamis
    My other friend, Vish from the Vish Files does 360s and back flips on his fox 32....so weak it is not, I know that for fact. its the flexing while hitting flowing switchbacks and g outs, I was worried about.....hope clears it up. for everyone. now stop arguing or I'm going to virtually flatten all your guys tires and put the "mysterious squeaky noise" curse on your bikes
    dirt Jump forks are tough - After two years after this thread finished to further test the question, is the consensus that I should run a 36 160 or 32 150 on my Trek Remedy?
    Aug 2010
    Quote Originally Posted by wantriot
    I've seen several guys lately around where I live on brand-new Remedys and they're running32s which I'm assuming are stock (I don't ride Trek so I don't know). Are you looking to step up to rougher stuff? If so, I'd say the 36 160mm might be worth a look - as I said on the other thread, mine rocks after a 1/2 year of heavy use.
