Page 1 of 2 12 LastLast
Results 1 to 25 of 38
    727 is offline
    Dec 2012
    fox 32 150mm or fox 34 160mm for a trek remedy 9 2013??
    My question is which put, the fox float 32 150mm the weight is 1.75kg, and the fox float 34 160mm is 1.95kg ¿is it worth it??is 1 centimeter more but 200 grams more.the trek slash takes the fox 34 160 mm,but maybe with the 150 mm 32 fox trek remedy for this good.thanks
    Reputation: KRob's Avatar
    Quote Originally Posted by 727 View Post
    I've never been too impressed with the stiffness of the Fox 32 forks (damping was never that great either). I wouldn't go with anything less than the 34mm 160 on the Remedy and would probably opt for the 36mm 160 if it were me. Depends on your riding style and what type of terrain you normally ride.
    "If it didn't hurt when you screw up, it wouldn't be half as exciting when you dont." cdburch
    Reputation: X-FXR's Avatar
    I have the Fox 36 160mm front fork on my all mt bike but ride it aggressively. If you want to ride the Remedy more as a xc bike the 32's are fine but with the minimal weight difference it isn't worth it. ymmv
    I have a newer 32 on my xcountry bike and love the float but if you plan to fully put the am bike through its paces a 36 would be my recommendation.
    Quote Originally Posted by k1creeker View Post
    "yeah, she's fat, but you'd take her for a ride." :D
    Reputation: ihaveagibsonsg's Avatar
    The 32 is weak for AM riding. Feels like the front wheel is gonna fall off. I'm disappointed about the slash and enduro coming with 34's. Too flexible for a real AM ride. 36 all the way.
    727 is offline
    Dec 2012
    Quote Originally Posted by KRob View Post
    ok thank you for you answer,¿does then not I worry the weight?¿stay geometry modified with fox float 34 160mm ?
    727 is offline
    Dec 2012
    Quote Originally Posted by X-FXR View Post
    OK thanks, the
    term average perhaps fox 34,This year, the trek slash or santa cruz nomad mounted the fork fox 34 160 mm fox 36 not
    727 is offline
    Dec 2012
    Quote Originally Posted by ihaveagibsonsg View Post
    Hello!! but fox 36 are 2.1 kg, 34 fox is flexible??that mess,before the trek remedy rode fox 36, now fox 32!
    because?
    If you're concerned about weight, go on a diet. The 34 is only 20% stiffer than the 32 and in my book, that's not stiff enough.
    727 is offline
    Dec 2012
    What is go on a diet??what you mean to me or to the bike
    I wouldn't worry about the weight unless you do a ton of smooth climbing or XC racing....( in which case you have the wrong bike). The 36mm Float forks are pretty light for how stiff they are.
    If you're worried about messing up the geometry you can have the 36 lowered to 150mm travel I believe, but I wouldn't do that. I think the Remedy could use the extra slackness the taller fork will create.
    727 is offline
    Dec 2012
    If but I only adjust in the talas in the flow do not,I want to buy float not talas,as I heard the forks talas dan more problems than the float
    Reputation: mark747's Avatar
    I just got a Float 36 160 RC2 for my ’12 Remedy 9.8 and it works awesome! Plenty stiff, plush, adjustable way better than the 32 DRCV that comes on the bike.
    727 is offline
    Dec 2012
    Quote Originally Posted by mark747 View Post
    Hello,but they say that the fox 36 does not give 160 mm travel, on the other hand the fox 32 drcv if it gives them 150 mm, is this true?
    Yes, my new Float 36 160 RC2 has 160mm of travel. 10mm more than the 32 150 DRCV that came on the bike.
    Sent from my iPhone using Tapatalk.
    I've had Fox 36 Talas on my Remedy since new and love it. It's not a race bike but I enjoyed riding it in the Test of Metal in 2009 and 2010. You'll never notice the difference in weight but you'll aways notice the difference in performance.
    Reputation: intuit86's Avatar
    Dec 2012
    Go for the 36. The gain in stiffness is more significant by far than the weight difference.
    7.5.3
    May 2012
    I have an 08 Remedy and it came with a 36 fox 160mm fork stock. And i love that bike.
    727 is offline
    Dec 2012
    the drcv system uses 100% of 150 mm of travel but fox 36 160 mm does not use 100% travel,This is what they say
    727 is offline
    Dec 2012
    Quote Originally Posted by Roy Miller View Post
    OK look put fox float 34 160 mm
    This year, bottles of 36 with axis 20 mm single carrying the slash 7 with rock shock lyrick, slash 8 and 9 mounted fox 34,even santa cruz nomad which is more for enduro-freeride used botlles 34,less weight identic travel, and perhaps somewhat less rigid.
    727 is offline
    Dec 2012
    All I know is that when I landed a hi speed drop a little heavy in the front wheel it used all the travel. Coming from the non adjustability of the DRCV I didn't want the 34 because it had the CTD and I wanted the adjustability of the RC2. I'll sacrifice some weight to be able to adjust the fork the way I want lt.
    727 is offline
    Dec 2012
    CTD is very simple to use, rc2 can adjust better if you know,If you use the entire route of the drcv, maybe don't carry the pressure of air on your weight, or maybe need fork 180 mm
    727 is offline
    Dec 2012
    the frame of the Trek slash only available for United States, in Europe you have to buy the whole bike,I would like to be able to buy only the frame.
    Reputation: Herzalot's Avatar
    32 is for lightweight, easy riding only. It has no business being on a Remedy. 34 is a better match.
    YER - I LIKE PIES!
    Reputation: deanopatoni's Avatar
    Quote Originally Posted by Herzalot View Post
    +1 for what ^^^ said.
    --- deanopatoni ---
    "Apples, pears, oranges and bananas - it's not just about fruit. Eat what you want. Ride what you like."
Hot Deals
Contests
Latest Mountain Bike Articles
