Results 1 to 18 of 18
Thread: Fork Poll
    Reputation: RMB-PM's Avatar
    Fork Poll
    1. Would you rather have a Rockshox Lyric RC (rebound and compression) or a Fox 36 Float R (rebound) if the price is identical, but there is a 160g weight penalty for the RS?
    2. Would you take a Lyric R (rebound) over a Fox 36 Float R (rebound) if there was a $150 savings? (but still a 160g penalty)
    Director of Product - MTB
    Rocky Mountain Bicycles
    Definately the more controls the better. Unless you're very weight conscious, now that's a different story. But then 160g can easily be achieved by using a lighter wheel set and/or tires with the money saved as well...
    160 grams = 0.352739619 pounds
    Agree with Kaizer, I don't think 0.352739619 pounds should be an issue on a bike that can handle a 160mm fork.
    Sorry to say, I can't offer any other feedback on those two models.
    meow meow
    Reputation: b-kul's Avatar
    id take the lyrik rc over the 36 r but the 36 r over the lyrik r. overall i would get the lyrik rc.
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    A couple things to consider.
    RS has a two year warranty, Fox a 1 year.
    RS forks are very, very simple to service.
    Overall I vote Lyrik RC. The additional weight should not be a deciding factor imo. If the RC is the same price as the Fox R then I think it's a no-brainer. But then again, I own a Lyrik so you can take all my biased input and toss it out the window if you'd like
    Reputation: Jason B's Avatar
    Quote Originally Posted by eatdrinkride
    A couple more things to consider.
    Fox sells parts to the end user.
    RockShox makes you go through a middle man (LBS).
    Transition Bank
    Transition ToP
    Transition Covert
    El Gato Malo
    Quote Originally Posted by Jason B.
    Fox for me
    wuss
    Reputation: dropadrop's Avatar
    What damping is in the Lyrik? Mission Control? With DH? Motion Control?
    Let the good times roll.
    Reputation: miniwisejosh's Avatar
    1. The Lyrik RC has adjustable low speed compression damping. That's better than the 36R with no compression adjustments at all (short of pulling the damper out and physically modifying it).
    2. The Fox 36 doesn't have anything to make it worth $5 more than the Lyrik, much less $150. I'd get the Lyrik R and consider changing the damper in the future. Or just save the money. It should cost under $200 to upgrade from the Mission Control IS damper (that's the Lyrik RC) to the top-end Mission Control DH damper. The upgrade just needs the DH rebound damper, the DH compression damper, fresh oil, and a couple hours to follow the directions in SRAM's tech docs for overhauling Lyriks. Maybe a few new tools if you don't have a well stocked tool box.
    Don't pay attention to the weight. That's a minor issue compared to suspension performance.
    About getting parts from Rockshox, a lot of that can be bought from mail order stores for a decent price. Even some dampers and other internal bits. I'm planning to upgrade my Mission Control damper to the DH version soon, and I'll most likely order it online unless a local shop offers me a really nice deal.
    meow meow
    Quote Originally Posted by miniwisejosh
    it has a fancy sticker that says FOX with a fox tail under it. thus the price hike. fancy stickers aint free yanno?
    Dec 2009
    X-Fusion Vengeance HLR
    Quote Originally Posted by b-kul
    lol. And the Lyrik has stickers under clearcoat so they don't fall off
    wuss
    1. The Lyrik RC has low speed compression damping. That's better than no compression damping at all.
    Lacking compression adjustment does not mean there is no compression damping.
    Quote Originally Posted by dropadrop
    You're right. I used a bad choice of words in my post. Thanks for pointing that out. Fixed...
    Reputation: Fix the Spade's Avatar
    Quote Originally Posted by RMB-PM
    Lyrik RC definately, but with the following proviso: Get someone (or yourself) to strip it down and make sure the fork has the right amounts of oil and a little blob of good quality grease on the wiper seals. RS are infamously bad at this last bit of making a fork...
    Reputation: jimarin's Avatar
    Mar 2005
    I'd throw the 55 rc3 ti in the mix. Chainlove has been putting the 2010 up occasionally for $500. 5.3 lbs, butter smooth coil. I love this fork. It blows away the 2 36 talas's that ive had prior. Best AM fork ive ever ridden.
    Quote Originally Posted by jimarin
    Can you pick up a heavier spring easily for these for us full grown riders ie:235 or is stock heavy enough?
