Results 1 to 14 of 14
    Dec 2011
    Flat pedals + carbon cranks + crank booties?
    Having trouble running race face atlas pedals in conjunction with the crank booties I'd really like to have installed.
    Anyone have any tips to get these things to play nice together? Or am I just going to have to cut the booties up?
    You can see the pedals are pretty much a flush fit with the crank arm (using the spacers) - so the booty adds just that much too much rubber between the pedal and crank arm so the pedals won't spin.
    Race Face
    Reputation: 006_007's Avatar
    I just trimmed my booties with a sharp knife to make it all play nice.
    Reputation: bigflamingtaco's Avatar
    Oct 2013
    Optionally, put a set of pedal extenders on, they have a thinner shaft, but not as thin as the typical pedal.
    I will suffer no butt-hurt fools!
    May 2015
    Sorry to thread jack but you just blew my mind with these bootie things
    So if you have carbon cranks do you have to run crank booties?
    I never thought about the downsides of a carbon crank but are they pretty easy to mess up because normally I wear through some of the paint on my cranks with just shoe rub, would that eventually kill carbon cranks?
    Reputation: Kiwiplague's Avatar
    You don't have to buy the booties, but they do stop the bottom of your pretty carbon cranks from looking quite manky when they inevitably get hit.
    I don't crash, I just have slightly uncontrolled dismounts!
    Sedona, Az USA
    Reputation: M1_joel's Avatar
    I specifically would not buy pedals that were not compatible with these crank arm boots. These boots are a must have for me. the wellgo Ti's have been great so far. 292g
    can you add washers/spacers to give enough clearance?
    I'm also using the Wellgo MG-1s which fit nicely on X01 with SRAM boots.
    App-a-LATCH-un
    Reputation: Appalachian's Avatar
    I had the same issue with Spank Oozy pedals. I just cut the boot to clear. It seems someone would just make bigger boots, but race face told me they were going to mod the axle on the atlas to clear. Seems like an overkill solution on their part.
    Fifty-two, I mean fifty-four bicycles on the wall
    Ready to ride, ready to ride until the last of them falls
    Dec 2011
    You could add washers, but that would push the pedal out and multiply loads arguably.
    Amazing they're going to mod the pedal to solve - though all they have to do is take one more pass with the CNC machine to shave 1mm off the pedal body, but still...
    Bought a dremel this weekend, going to shave the boots down this evening Thanks all!
    App-a-LATCH-un
    My boot finally tore off because the hole I trimmed compromised the amount of material left above the pedal. I had a brain fart and decided to flip another boot around and cut it out on the meatier side of the boot. Seems like this should hold up just fine.
    Very crude solution, I had to cut some rubber on mine, then they didnt stay snugged on. So i super glued the crap out of them and they havent budged in 3 years and are still going strong.
    Feb 2012
    where are you guys acquiring these crank booties?
    mbtr member
    Reputation: scottzg's Avatar
    Quote Originally Posted by Rival View Post
    Here.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    Dusting Trails
    Reputation: matuchi's Avatar
    I bought a pair of boots and tried to get them to work with my Sram S-2200 crank arms and my Spank Spike pedals and after cutting the crap out of the booties I gave up. I've been riding about a year now and haven't had a pedal-strike that has done any damage to my cranks. You can get by without them - but you may get a few scratches on the end of your crank arms.
  1. clydes on flat pedals / ethirtenn lg1 pedals
    By DABIGSEAT in forum Clydesdales/Tall Riders
    Last Post: 07-09-2015, 02:11 AM
  2. Flat Pedals
    By Mr bond in forum Beginner's Corner
    Last Post: 09-26-2012, 07:41 PM
  3. Flat pedals?
    By Skrapmetal in forum Clydesdales/Tall Riders
    Last Post: 06-03-2012, 12:45 AM
  4. SPAM - New Race Face NEXT cranks, Time ATAC carbon pedals, RF Turbine Chrings, MORE
    By Green Giant in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-12-2012, 02:02 PM
  5. FYI for those looking for crank arm protection for X0 carbon cranks
    By DFYFZX in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-06-2012, 03:17 PM
Members who have read this thread: 9
