Results 1 to 8 of 8
    Sep 2017
    Finally going tubless
    So I've ordered my tubeless kit from uberbikes. Has any0ne used this tubeless system before.
    The guy in Evans told me not to buy what they stock (stans)
    Dec 2014
    I have used Stan's sealant and it dries up pretty quick and you end up with an urchin-like ball of dried up rubber rolling around in your tire.
    I have had better luck using Orange Seal Cycling. It is thicker, has glitter in it to help close up the holes, and when it dries up it leaves a rubber film within the tire walls.
    Everything is better on 2 wheels!
    Giant Anthem X 29er, Trance 27.5
    Diamondback Clutch 27.5+
    mountainbikingtexas.blogspot.com
    May 2017
    You won't regret going tubeless. Besides the (5 minute) learning curve, it's fairly fast to setup.
    I use Stans with fine results. My front tire holds like champ. My rear takes a couple ounces every 2-3 months.
    Sent from my ONEPLUS A5000 using Tapatalk
    Reputation: taprackbang's Avatar
    Jun 2014
    Are your wheels tubeless ready?
    Sep 2017
    Yes and so far so good although with 2.6 wide tyres I used 500ml of liquid... not sure if this is normal
    Jun 2017
    Holy smokes, 16oz to do two tires?
    I run about 4oz per tire for 27.5x2.4. Been trying out the Orange Seal endurance stuff. So far, no issues
    His: 2017 Commencal Meta AM V4.2 Ride. With Zee brakes
    Hers: 2018 Commencal Meta TR V4.2. Zee, too!
    Feb 2014
    You used at least 2x as much sealant as was needed. I use 3oz/tire on 27.5x2.5".
    Reputation: 619er's Avatar
    I went tubeless for the first time as well... when they say your bike becomes more “nimble”, “playful”, or better handling - it’s actually true. Can’t believe I had tubes in my tires all this time. Another bonus- the weight- I’m not a weight weenie but I ride a 27.5+.... huge difference...
    A father is only as happy as his saddest child...
  1. Replies: 4
    Last Post: 08-11-2016, 08:19 PM
  2. Tubless w/ non tubless tires?
    By centershot in forum 29er Bikes
    Last Post: 01-17-2014, 09:45 AM
  3. First time out after going tubless and SS
    By Danielrg_usa in forum Beginner's Corner
    Last Post: 01-14-2013, 09:08 PM
  4. Going tubless whats the difference?
    By 5foldtravel in forum 29er Components
    Last Post: 06-17-2012, 11:18 AM
  5. Replies: 2
    Last Post: 08-03-2011, 07:29 AM
