Results 1 to 12 of 12
Thread: Enve DH Bar
    Enve DH Bar
    enve DH bar 800mm, how much can this be trimmed by?
    400mm/side would be about the most you could trim.
    Between dry wit and lack of CS from Enve looks like I'll plump for an Easton bar
    Reputation: brentos's Avatar
    The lines on the end of the bar are @ 10 mm each. 4 lines x 10 mm = 40mm per side.
    I don't see any reason why you couldn't trim it shorter...but like any bar, you'll run out of room for controls.
    Executive User - UK
    Nov 2008
    Quote Originally Posted by CharacterZero
    Quote Originally Posted by brentos
    Cheers
    meow meow
    Reputation: b-kul's Avatar
    hahahaha
    Member of The Yeti Tribe
    Reputation: swan3609's Avatar
    I have one on its way.. I will ride it at full length to start, but I will end up trimming it down to 30.5-ish
    Nov 2008
    Quote Originally Posted by swan3609
    where can I order an ENVE dh bar (800mm) carbon??!
    thanks!
    NWS
    NWS is offline
    Jun 2010
    Flawless victory.
    Reputation: V.P.'s Avatar
    : D
    Quote Originally Posted by rodus77
    thanks!
    LBS broskie..
