• 09-07-2012
    m0ngy
    Easton Haven carbon bar *help*
    Hi, I've recently bought some Haven carbon bars and aluminium stem. I've put them on my bike, but I don't have a torque wrench, so I've tightened the face plate by hand. I haven't applied much pressure, just enough to make sure the bars are secure. Subsequently, I've noticed something that looks like it could be a crack underneath the resin, but I'm really not sure.
    Can someone who knows about these things have a look and give me some feedback? Thanks
  • 09-07-2012
    redmr2_man
    just looks like unidirectional carbon layup to me
  • 09-07-2012
    m0ngy
    OK, so the carbon is laid vertically and horizontally? I'm a bit concerned because it's near the stem, and there seems to be a lot of problems in regard to carbon bars and over tightening face plate bolts. These are my first carbon bars.
  • 09-07-2012
    The Beater
    you are good as was said before it is the carbon lay up. mine look the same as do my havoc carbons,
    I have had easton carbon bars on my last 4 bikes and none have failed or had any problems. Make sure you get some carbon paste which will allow you to use less torque to stop the bar from slipping. FSA makes some good stuff.
    I also just tighten the bar enough to stop it from spinning when pushing down on the suspension as hard as I can. With the paste that seems to be good for the trails also.
  • 09-07-2012
    ziscwg
    A lot of Easton bars have that somewhere. Of the 3 I have had, all had it. None have broken even after multilple falls.
    You don't need a torque wrench, just make sure to tighten 1/4 turn at a time in the X pattern. I think Easton has a vid of it on their website.
  • 09-08-2012
    m0ngy
    Do you guys all use carbon paste? Do you really need it? I find I can get them quite firm withou having to tighten too much, however they will spin if I put downward force on them, like push down hard on the forks.
  • 09-08-2012
    myarmisonfire
    That is much too loose! Just imagine if that happened when you landed from a jump... Follow the direction from Easton on how to tighten the bar. If you want them torqued take your bike to the LBS and have them torque it for you. If you bought the bar from them I am sure they will do it for free.
  • 09-08-2012
    Murchman
    That is normal I have them like the others on all my carbon bars with no failures and I am big guy that has been running Easton carbon bars since 2005. They are not anywhere near as delicate as you are treating them.
    I run no paste on anyone of mine and just torque them to spec or by feel these days with no issues.
  • 09-08-2012
    m0ngy
    LOL, I have't ridden with them like that, I'm still building the bike, an old VP-Free. Thanks for your advice.
  • 12-29-2012
    GnarBrahWyo
    So, just got my Havens in today. I do have the exact same marking in the middle of the bar as the OP. Almost identical. However, just for sh&ts I shinned a flashlight through to the bar see what it looked like inside. The line I have circled in these photos extend the whole length of the bar.
    Is that part of the unidirectional carbon fiber manufacturing process or is this already compromised in some way? Have you guys observed this as well?Am I being paranoid? Maybe, but CF isn't cheap! :thumbsup:
    You guys are experts, check out these pics and lemme know what you think!
  • 12-30-2012
    saturnine
    looks about right
  • 12-30-2012
    khskenny
    Looks normal. All my ud carbon easton bars have similar patterns in them.
  • 12-30-2012
    m0ngy
    I've had my bars on my bike for a couple of months now, and they're fine. I was just trippin, never had carbon bars before.
  • 12-30-2012
    GnarBrahWyo
    Even with that line going through the inside? That line goes across the whole bar on the outside and inside.
  • 12-30-2012
    h2ored
    My havocs have the same thing. As others mentioned, it's just uni-directional layup... nothing super exact ;)
    The suggestion of tightening faceplate in an X pattern is bad advice - I've cracked one like this - you're essentially forcing the faceplate to twist unnaturally. It's unlike a car wheel where it's cylindrically symmetrical. The newer easton stems are very specific about tightening the top bolts first and then the bottom. I also think you should use a torque wrench - they're very inexpensive these days and I don't know how you'd feel confident in 'guessing' the torque.
  • 12-30-2012
    GnarBrahWyo
    Well, good to know that is normal. I just figured on the inside of the bar it should be seamless for some reason.
  • 12-30-2012
    Fix the Spade
    Probably yes and definitely yes. It makes a big difference in the amount of clamping force needed on carbon bars, also, one tube is enough to see you through for years and years, so it's worth getting anyway.
  • 12-30-2012
    GnarBrahWyo
    So what does that little line have to do with UD carbon layup? Shouldn't it be seamless on the inside?
  • 12-30-2012
    khskenny
    The line is probably a crease from the bladder used during manufacturing.
  • 12-30-2012
    GnarBrahWyo
    Still don't know why it would be visible on the outside. I had similar markings on my old Specialized Camber carbon.
  • 12-30-2012
    GnarBrahWyo
    ...but I am gonna stop worrying about it. Seems like all of yours have the same thing going on with it. Thanks for the input!
  • 12-30-2012
    khskenny
    The crease on the inside is resin that gets caught in the bladder crease. The line on the outside is just the end of the carbon sheet. It has to stop somewhere :) . You don't see a raised crease on the outside because it is pressed against a smooth mold and or smoothed afterwards.
  • 04-08-2013
    Reign2Rider
    I just got new havens too and they also have these marks. Spoils the look of them just a little but seems it is normal.
  • 04-11-2013
    LCW
    Perfectly normal. That area of the bar (referring to the OP's pic) gets most likely hidden by the stem cap. Stop worrying - it's the best bar out there! :D
  • 04-11-2013
    Cary
    To put it bluntly, you can afford a $140 bar but can't spring $40 for a torque wrench to make sure not only your bars are properly torqued, but other components also are?
  • 04-11-2013
    GnarBrahWyo
    Yeah, best to torque it to spec. If you don't have a torque wrench, go to your LBS and they will probably torque it for free for ya. Peace of mind is a good thing. Better than missing teeth actually.
