Results 1 to 41 of 41
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Easton Carbon: Havoc vs. Haven
    Is there any difference other than length (which obviously has some effect on weight) and graphics?
    I don't exactly know which length I want my bars, and if I go with the Havoc I can start out long and trim down, but the Haven's are limited to 711.
    Price is the same . . . .
    Pretty much the same. Havocs are a part of Easton's "DH" line (thus are longer), where the Haven falls into their "AM" line.
    Reputation: Fix the Spade's Avatar
    Havocs are reassuringly meaty.
    Havens are a bit lighter.
    I happen to have a set of both (lucky me ), in terms of shape they're the same save Havocs being a little wider. Quality is typical Easton Carbon, as in excellent. Unless you're really tall (6ft 2+) I can't see the Havocs being terribly comfortable, the Haven makes a very nice general purpose bar.
    junkie
    Reputation: slorente's Avatar
    Anyone have any direct experience between these and the Enve bars?
    Reputation: 'size's Avatar
    Quote Originally Posted by Fix the Spade View Post
    bar width isn't determined by height. i'm just under 6' and run the havoc at full width and it feels great. i know riders 2" shorter than me on 30" bars without comfort issues. it's all personal preference.
    junkie
    Quote Originally Posted by 'size View Post
    Isn't it a comfort thing depending on arm length/shoulder width combined with riding type?
    Does it take some time to get used to wider bars. I just went from 680mm to 760mm and I'm not sure I like it.
    Quote Originally Posted by slorente View Post
    it can be, sure. stem length combined with bar width, bar sweep and rise all play into as well, but to say someone over or under a certain height will or won't be comfortable on any certain width of bar is just incorrect.
    like any change to your riding position it can take time to adjust and decide if that change is beneficial or not. you added over 3" to your bar setup which is a lot of change. i'm assuming you didn't go with a shorter stem as well? remember, as you add width to your bar you're putting more weight over the front end and slowing your steering down. this is why many people end up running a shorter stem as their bars get wider and wider.
    007 is offline
    b a n n e d
    Jun 2005
    See, I'm thinking that the Haven's might be a good fit for me, but when I lined them up to my current bars, I'm not sure if I want to be limited to 711mm. I currently have 680mm bars and only adding 15mm per side may not be enough to achieve the fit I'm looking for. The logic is that the Havoc's offer some degree of freedom in choosing the "perfect" size.
    I know enough that I want carbon bars, and I like the sweep/rise of the Easton bars so its basically between these two . . .
    Height is a major factor. Get the bars too wide and all you are doing is putting your weight all the way forward. To an extent a shorter stem or even frame can compensate, but little guy on big bars can only lead to stem humping.
    007 is offline
    b a n n e d
    Jun 2005
    I would have to agree, and one of the reasons I'm going wider is actually to pull my weight forward a bit . . . how far though I'm not yet sure. Hence, i think the trimmable havoc is the way to go . . . and if I end up at 711 mm . . . well, then oh well!
    Question though . . . and I think I know the answer but . . . . does trimming the bar decrease the integrity at all if done properly?
    junkie
    OO7: integrity is not lost if carbon bars are cut properly. Some bars like the Enve are intended to be cut to width if desired. I would go wider and cut to what is right for you.
    Anyone know if the weight difference is from anything more than additional material from width.
    junkie
    I did go with a shorter stem as well (110mm to 80mm). That said, I finally got used to it and love the wider bars now!!
    Nov 2007
    I was asking the same question.
    I assume the Havoc's have a thicker wall if you look at the math.
    The Havoc weighs 39% more than the Haven (235 vs 170) but is only 5.5% wider (750 vs 711). Considering that the center of the bar is fatter, and likely has the heaviest wall, I would think that it would skew even more.
    Based on this, I would suspect that if you took a Havoc and cut it down to 711mm, it would only lose 10 to 15 grams.
    Has anyone measured a cut down Havoc?
    Reputation: Pau11y's Avatar
    OO7,
    Tried Answer Protaper 720c yet?
    To cut: high spd Dremel cut-off wheel + dust mask works well. Tape the bar, mark, and cut. High spd tends to not splinter the carbon.
    Naysayers never apologize. Critics go to their grave thinking everyone else is wrong.
    ╭∩╮( º.º )╭∩╮
    What's the Warranty like on Easton's bars?
    If it's anything like the "3 Year No Questions Asked" warranty on the carbon Haven wheels I think I just found my next set of handlebars.
    007 is offline
    b a n n e d
    Jun 2005
    Quote Originally Posted by Pau11y View Post
    OO7,
    Nope, have not tried the Answer bars yet. Pretty happy with my Havoc's and have even left them at 750. I might trim them up just a touch, but like where they are. One thing is certain though, there is no weight savings with the Havoc for an AM rig. It is comparable to most AL bars (not AL DH bars though).
    Quote Originally Posted by jojoh2033 View Post
    Actually, I think their bars have a lifetime warranty.
    Quote Originally Posted by OO7 View Post
    Anyone have a link to easton's carbon bars warranty? Ive read several posts about the lifetime warranty, but only see warranty on wheels on their website. And I believe that links to caim instead of their terms and conditions. Thanks.
    Quote Originally Posted by mtngt View Post
    Straight from the box of my Havocs, which I got for free when my old, old CNT DH bars had an argument with a tree and them some rocks. Five years for Alloy, lifetime for Carbon and they do mean lifetime.
    <img src="http://i84.photobucket.com/albums/k20/fix-the-spade/Bike/eastonsheet_zpsf1c57cd0.jpg" border="0" alt="Photobucket"/>
    Thanks Spade! Hopefully they haven't changed their warranty / policy recently. You'd think that they'd mention that lifetime warranty in their website. I'd think that'll be a deal-maker for most.
    meow meow
    Reputation: b-kul's Avatar
    id think the havoc, being a dh bar, would have a slightly meatier layup. at just 250g and probably stronger they would be my first choice.
    I have the Haven carbon bars on my Blur LTc and frankly they feel great. They are a step up from the 680mm Monkey bars on my old bike and those for 25.4mm. So better leverage and stiffness.
    2011 Santa Cruz Blur LTc
    2005 KHS DJ200
    2005 Rocky Mountain ETSX-70 (stolen)
    Quote Originally Posted by b-kul View Post
    I do prefer the havocs for those reason, plus I like the looks of the stem over the havens. It's going on a trail/am bike (GT Force) though so it might be a little overkill. And the current setup is a 620/90. Not sure if the 750/50 or 65 will be too much of a change. The nice thing about the 750 is maybe it can be cut narrower, if that doesn't void the warranty. Else, maybe a havoc stem and haven carbon is what I'll go with.
    007 is offline
    b a n n e d
    Jun 2005
    I went with Havoc's and am happy with them. I think the Haven't would have been too narrow.
    (note this thread is well over a year old now )
    Good to know that the havoc worked out for you. Yeah, I resurrected this thread from the dead. I was searching for the Easton carbon bars warranty and this was the closest where it was discussed. Was also (still am) deciding between the havoc and haven so I figured it was better than creating another thread.
    Reputation: Tarekith's Avatar
    Mar 2005
    My brother in law has the Haven's on his Slayer 70, and I was impressed at how strong they were after he took a spill. Front wheel caught a root and he went down, the Haven stem he had twisted from the fall, but the bars looked and worked like new still. Impressive seeing carbon win over aluminum.
    I don't know what the handlebar warrenty situation is like, but Easton refused to fully warranty the stem even though it was a really minor fall. Offered a slight discount on a replacement Haven, or he could upgrade to the Havoc (which he did). Was a huge hassle getting the Havoc stem though, the Easton rep had no clue what they were talking about in terms of sizing and the like.
    Maybe just a fluke experience, just passing it on though.
    Tarekith.com
    '12 RM Slayer70, i9 Torch, Flow EX, XT Brakes, 5050 s3.
    meow meow
    ^what actually broke on the stem?
    Mar 2005
    Nothing broke at all, the metal twisted along the length of the stem so that his left handlebar end was about 10 inches higher than the right one. Stem and bolts were still in one piece though. Gave me new appreciation for how strong carbon is.
    I was really surprised Easton would not warrenty it.
    Tarekith.com
    meow meow
    thats some serious torque! im surprised easton wouldn't warrenty that too.
    Mar 2005
    I'll see if he still has the pictures of it, it was impressive for such a small fall.
    Tarekith.com
    meow meow
    how long was the stem?
    Mar 2005
    70 I think.
    Tarekith.com
    727 is offline
    Dec 2012
    The best is the easton monkeybar lite 155gr in 660m , the easton haven the weight is 170gr
    Mar 2005
    Here's those pics of the bent stem:
    Tarekith.com
    It's carbon dontcha know.
    Reputation: 6thElement's Avatar
    Warrenty covers manufacturing defects, not someone stuffing the bike into the ground during a crash. That stem looks like it did its job, additionally by twisting like that it let him know it needed to be replaced, rather than failing more seriously later on.
    Rolling on 29", 650b, 8.3" and 23mm
    Helmetless Crasher
    Reputation: Stumpjumpy's Avatar
    Inadvertantly posted in wrong thread - sorry
    '95 M2 StumpJumper FS
    '11 Cannondale RZ 120-two
    Mar 2005
    Quote Originally Posted by 6thElement View Post
    For sure man, had it been one of those crashes that was "stuffing it into the ground" I'd be in complete agreement. No one expects manufacturers to eat the cost of a rider taking a bad spill. This was a minor fall though, seriously nothing you would have expected this kind of damage (or any) from.
    Easton did offer to upgrade him to the Havoc for a cheaper cost, so that was cool.
    I was just surprised that the whole process he had to go through seemed so poorly handled. We honestly though there was somethign wrong with the metal for it to bend that easily (I have the same stem and it's been through a LOT in the short time i've had it with no issues, including some way gnarlier crashes). Easton didn't even seem interested in looking at it though, just to be safe.
    It's just a different experience to warranty work I've had with other bike companies I guess.
    Tarekith.com
    Maybe CNC parts are not as strong as forged parts in some instances. I think the Easton stems are CNC machined out of a solid block of aluminum.
    Forging, Casting and CNC Machiningdp-forging.html
    meow meow
    Quote Originally Posted by Tarekith View Post
    holy cow, that is wild! never seen anything like it!
    007 is offline
    b a n n e d
    Jun 2005
    Wow. Would have never believed it without pics.
    And yes, that does speak to the strength of the Easton Carbon. Not so much for the stem.
    I wonder how other stems would have fared.
    Reputation: Rojo Grande's Avatar
    Oct 2012
    Seriously, you should ask your wife or girlfriend next time before you start claiming that is ten inches................lol.........sorry, back to topic
    My bad, double post...
    ╭∩╮( º.º )╭∩╮
  1. Replies: 0
    Last Post: 07-14-2011, 02:35 PM
  2. Easton Havoc vs Haven?
    By dfinn in forum Wheels and Tires
    Last Post: 05-01-2011, 02:45 AM
  3. Easton Haven Hub Engagement
    By thefriar in forum Wheels and Tires
    Last Post: 01-20-2010, 11:03 AM
