Results 1 to 3 of 3
    Dec 2004
    Dual position PIKE permanently lowered?
    Hi
    Im thinking a lot about the PIKE forks as they seem to be the most celebrated at the time
    My current frame and the one Im considering are suited for 120 and 130 mm fork length
    And that is what the options are on the lower settings on the PIKE dual position (150 mm and 160 mm respectively)
    Do anybody know if the performance of the lower setting is on par with full travel?
    Will it act with the same progression through the travel as full length, or will it act according to the progression to the last 120 or 130 mm of the travel?
    Rasmus
    Butts Up Fast!
    Reputation: Stonebreaker's Avatar
    A dirt jump version of the Pike just came out that comes in 100mm or 140mm if that helps
    lamer
    Reputation: llamma's Avatar
    Re: Dual position PIKE permanently lowered?
    RS Dual Position forks are not made to be run in the lower setting for extended periods of time. Why not run a Revelation if you're looking for mid length travel?
  1. Pike SO vs Dual Position?
    By myitch in forum All Mountain
    Last Post: 05-23-2015, 12:31 PM
  2. Can a Pike 29 dual position change from 120 to 140?
    By trhoppe in forum Shocks and Suspension
    Last Post: 03-04-2015, 05:07 AM
  3. Pike Solo Air vs: Dual Position
    By myitch in forum SRAM
    Last Post: 01-18-2015, 10:47 AM
  4. Pike Dual Position Air - Can it be lowered internally?
    By Shaun C. in forum Shocks and Suspension
    Last Post: 05-21-2014, 01:38 PM
  5. New Pike RCT3 Dual Position Air
    By HeatmiserSoCal in forum Shocks and Suspension
    Last Post: 08-12-2013, 02:56 PM
