Results 1 to 77 of 77
    Dropped Seat- How do you pedal?
    The other day, I dropped my seat to aid in decents and it ws great. The big problem that I have is pedalling. It burned my legs out so fast. So my question is how do you guys pedal with them slammed. Is it by just raising the seat agian when needed to climb, do you guys just stand up when pedalling, or do you guys just have extremley strong legs? How do you do it, please enlighten me. Thanks
    Reputation: shiggy's Avatar
    Dec 1998
    All of the above.
    mtbtires.com
    Your bike is incorrigible
    Reputation: Guyechka's Avatar
    simple
    I never drop my seat.
    I haven't dropped my seat in two years, and it hasn't affected me adversely. Takes some getting used to, but you can do it. Now, I can see where you might want to drop your seat if you were riding purely on a hyper technical downhill and not pedalling much at all. For 99% of trail riding, it's not necessary.
    Apr 2005
    Depends on how low you have your seat... I ride with my seat low, it's lower than my stem height, but it's not all the way down into the frame. I have maybe 4 inches of seatpost sticking out of the frame.
    It's definitely harder if your riding with clipless pedals than flats. But like anything new I got used to it. I really like having the seat down all the time due to my ability to throw the bike around and pump the terrain, it's very hard when you have a seat right up there. Climbing is no problem unless you want to break some speed records. Edit - for long steep climbs I will sit and spin, and out of the saddle for shorter climbs or mix up the two when necessary.
    Gravitydropper?
    These look like a good idea:
    http://www.gravitydropper.com/
    Can't say how well it works as I've never tried one. The folks using them seem to love them though.
    Dec 1998
    Quote Originally Posted by Boyd and fiends
    It's definitely harder if your riding with clipless pedals than flats...
    What? Explain, please.
    I find it easier to pedal with power with clipless pedals no matter what the saddle height or whether seated or standing
    mtbtires.com
    I have a Spec Stumpy so it can't go all the way down due to its interupted(sp?) seat post so I think its about the same hieght as yours. And I also do ride with flats.
    The GD is a good idea, but its just too expensive. The maverick speedball is $200-220 and I imagine the GD isn't too far off.
    Vaginatarian
    depends
    I drop my seat an inch for tight & twisty trails, pedaling is fairly normal but harder on the knees, I only drop my seat more than that for rough downhills not much pedaling required
    I have a gravity dropper seat post so it takes no time to raise or lower
    Apr 2005
    For shiggy - I first started riding with my seat down when I still used clipless pedals. Due to where the cleat is positioned on your shoe (further up the foot towards the toes, not under your arch) I found it felt strange. With flats I can position my foot whereever I want to when climbing, fooling around, etc. It's not limited to the one spot. I find I have more freedom with flats than clips. I definitely not saying that flats are the best, they just work for me.
    JMH
    JMH is offline
    Sugary Exoskeleton
    Reputation: JMH's Avatar
    Feb 2005
    Strange but True (IMO)
    Shig-
    Sounds crazy, but I found this to be true as well... When my seat is really low I find myself moving my feet forward on the pedals (mid-foot maybe) to open up my knee angle at the top of the pedal stroke a bit. It's not much, but it definitely feels more comfy.
    Quote Originally Posted by shiggy
    Ride on
    No perfect solution
    There is no perfect saddle position. Lowering your saddle makes it easier to keep your weight low and shift around while descending or riding on stunts. Conversely raising your saddle height makes it easier to pedal. I have ridden with buddies that prefer to adjust their saddle height before every major descent or climb, and those that prefer to find a compromise that allows for decent pedalling position without compromising downhill performance too much. Both styles have their advantages. Pick the one that works best for you.
    Dec 1998
    Whatever works for you.
    I find it very awkward to pedal/ride with the pedal under my arches.
    mtbtires.com
    Dec 2005
    I stopped dropping a year ago, and now run a weight weenie fixed clamp. I can still go down the same steep descents without dropping.
    bi-winning
    Reputation: rkj__'s Avatar
    I too never drop my seat. I can go down pretty steep stuff by just shifting behind my saddle. The main problem would be absorbing impacts from drops without hurting yourself. I don't get real big air though.
    Apr 2005
    JMH summed it up better...
    Thanks for all the interest in my bike riding techniques though! Its been a pleasure. Did I ever say this is the only way to do something??? No, I was just trying to explain something that I had discovered when riding with clips and flats with a low seat. For the most power I prefer to use my heels...
    Gravity Dropper will give you the best of both worlds.
    Perhaps expensive, but worth its weight in gold (or does it already cost more than that? :-) )
    Dec 1998
    And did I ever say you were doing it wrong?
    mtbtires.com
    Dec 2005
    classic shiggy
    That should be my new signature " ... and did I ever say you were doing it wrong?"
    Quote Originally Posted by rkj__
    I used to do that, but you end up in a terrible position on the bike, with the seat stuffed into your stomach. Get a gravity dropper, it's loads better on steep descents. Actually it's loads better on any descents since you can corner much faster too.
    Remember, there is no black magic or witchcraft, it's only a machine
    another bozo on the bus
    Reputation: washedup's Avatar
    when dropping my seat i like it to be at knee level when the cranks are parallel to the ground so i can lean on it with my knees or control the bike a bit with them in really rough stuff. usually i will just ride my seat about an inch below full-leg extension, but the again, it totally depends on the trail. an alternative to gravity dropper is the maverick speedball. pricey and my friend just blew his up after a couple months. gravity dropper looks pretty cool with the remote if you dont mind have your bars cluttered.
    Just another FOC'er
    Reputation: .Danno.'s Avatar
    Jun 2005
    Quote Originally Posted by JMH
    Shig-
    Yup, this works for me too. I also ride rough DH, and drops with my foot forward to take the impacts off my ankles.
    I drop my seat for every down to maximize the fun factor
    Shinobi-Wan Kenobi Moderator
    Reputation: kristian's Avatar
    Practice, practice, practice. The more time you spend with your seat down, the more the muscles in your legs will get used to riding that way. I ride 75% of the time with my seat in a "downhill" position and my legs don't burn out like they used to when I first started doing it. For quick bursts, I go out of the saddle and for short climbs I sit and spin. On long climbs (greater than 200 feet vertical) I will raise the seat but otherwise it's not worth screwing around with it. Most of the riding I do is short technical climbs followed by short descents so this style works well for the local terrain.
    I agree that it is easier to ride a low seat with flats than with clipless.
    Quote Originally Posted by tald
    Works for me. I just got one but it was great riding at Keystone last week on the green runs with my wife and some friends. Uphills were no effort; just raise the saddle and spin, then drop back down for the descents.
    Glenn D.
    Quote Originally Posted by kristian
    I agree, I drop my seat before every extended DH section...works great here in CO considering most trails are long ups with long downs. Do you have to lower your seat? No, but lowering your seat for descents puts you in the best position for riding DH (look at any DH racer's stance), just like raising your seat puts you in the best position for riding uphill. Once you get used to raising and lowering, it becomes second nature.
    It takes literally like 4 seconds to raise and lower a seat with a QR clamp...
    Quote Originally Posted by Jutt77
    It takes literally like 0 seconds to raise and lower a gravity dropper. I hate QR seatclamps too.
    Just another FOC'er
    Jun 2005
    The 4" drop of the GD is ok for most stuff, but when things get really steep that amount of drop just doesn't hack it for me. I need ~7" drop. That may just be a personal preference thing, but I really can't move around with just 4".
    For dirt jumping I like it even more than 7" down if possible. Any kind of jumping where you might miss the pedals and hit the seat with your a$$ though is probably going to snap the GD anyway. From what I've read it doesn't have the strength of a Thompson.
    Student
    Reputation: [CrazyRick_11]'s Avatar
    my seat is up when i all mountain or cross country ride then when i go out for the purpose of doing some drops or the skate park i lower my seat.
    The secret to mountain biking is pretty simple. The slower you go the more likely it is you'll crash. ~Julie Furtado
    respect the wildlife
    Reputation: BillyBob's Avatar
    $250 for that thing??
    Hi all, I don't post a lot but here's my 2 cents.
    Holy sh!t, I just saw the price on the gravity dropper. $250 can buy you a lot better bike parts than that. What a waste of money, seriously.
    Maybe it's possible to ride downhill with a raised seat, but there is no way to do it well on anything hard or steep. Hit anything bigger than a lunchbox and you'll get bucked off the seat and probably right over the bars. There are simply too many situations where you need to have your ass back over the rear wheel to be balanced. On the other side of the coin, you CAN climb with a low seat, but it is ridiculously inefficient. For me personally, the only good way to climb a heavy bike is seated, post all the way up, spinning as smoothly as possible (and clipped in).
    Like others mentioned, and for all those reasons, I wouldn;t consider buying any AM bike without an uninterrupted seatpost.
    Quote Originally Posted by uktrailmonster
    Wow, 0 seconds?! Telepathic eh?! I guess I hate paying 250 bucks for a substitute of simply opening and closing a small lever...too each his own.
    May 2005
    GD the best investment into single component I did. (Frame doesn't count, right?)
    You can get it cheaper then 250, but not by much. 4" drop works best for me (5'10") and no shifting backward can substitute balanced position over lowered seat for the lower center of gravity.
    Landing chest on the seat after unlucky drop is not a paradise either.
    On the OP subject, like Shiggy said, all of above: seated for keeping pace on flat, standing or rised seat for the climbs.
    Yeah it is telepathic. You see a drop coming, flick a switch and down it goes. Works well where there's loads of short steep drops followed by equally short steep climbs i.e most of the UK riding. May not be so useful if your climbs are very long and then it's all downhill without any serious pedalling. I also find myself using it in situations where I'd never bother to drop my seat in the past, like sections of fast twisty singletrack. Again just flick it down as you ride, bank down low through those turns, flick it up again and pedal. Expensive yes, pretty no, but a lot more useful than most blingy bits you can easily blow $250 on eg. carbon bars, titanium springs, X0 rear mech, etc.
    But I guess you just don't get it.
    Just another FOC'er
    Jun 2005
    This is very true. Our terrain around here involves long climbs and long decents so it's not as if you've got to get off and adjust the seat every minute.
    In the past year there were two situations where I really wished I had a GD. The first was an XCish race that had some decently rocky DH that would have been way more fun to ride with the seat dropped. No getting off to do that during a race though!
    The second was when I was riding around the mesas in the Virgin Utah area. Up, down, up, down, etc. I ended up riding the mesas with my seat dropped a couple inches which was optimal for nothing.
    I like to spend money on things that improve my riding, most of the time like a $5 QR clamp that allows me to extend/contract my seat with a longer range of motion than a $250 gimmick does. So you're right on bro, I don't get it.
    Quote Originally Posted by BillyBob
    Name some better parts I haven't already got.
    Te mortuo heres tibi sim?
    250? i paid *much* less than that for my non-remote versions. works on the fly, super fast and easy, no stopping to mess with the clamp required. makes continuous flowy trail riding very nice. no muss, no fuss. always right back to where you set the thing. and i'll keep on riding while you are stopped to mess with the seat.
    do i need it? no. is it nice? yes. do i prefer it to the QR? yes. enough so that i've got one on both bikes now....
    drop it 1" for flowy stuff, or the full 4" for longer stuff, whenever you want to, no need to stop or mess with a lever, or even really slow down most of the time.
    just consider it one more refinement.
    May contain nuts
    Reputation: Haggis's Avatar
    I'm one of those riders that can't be bothered moving the seat except for the steepest sections, but then I find I can't control the bike with my thighs/knees because the seats too low... I'd like to try a GD just to get used to that feeling...
    yes, because if you run a GD post, you are henceforth forbidden *by law* to keep the QR clamp for super long or steep runs. or heaven forbid, loosen up the allen bolt clamp if you have one of those.
    there are a lot of front range and other trails i used to ride, and never lowered my seat other than for long sections. now, using the GD, i raise and lower it all the time. much nicer overall, and much more fun that way on the downhill sections of trails.
    i thought they were pretty stupid when i first saw them to, then tried one out for a bit. they are a great addition, especially if you ride stuff with flowy ups and downs. yes, we actually have those in colorado.
    Don't skid
    Reputation: KONA_in_SB's Avatar
    I used to slam my seat down on all decents thinking I needed it completely out of the way. Slowly though I have raised my 'lowered' position to so I can still pedal efficiently on flats and short uphills. As someone already said once your legs get used to this position they won't burn out as fast. And definiatley standing up helps.
    I aslo find pedaling cliped in with my seat down awkward. Its something about repositioning the feet on the pedals with a lowered seat that makes platforms better.
    As for the gravity dropper I think that would be a good investment. On the fly adjustment is the best option, and as i said I don't slam the seat down anymore so maybe 4" would be enogh for most situations. QR is nice if your trails are up and then down but on fast rolling, flowy trails I don't want to get off my bike and raise or lower the seat at every hill. But then again there are a few other parts I could buy for $250 that i "need" on my bike at the moment.
    The Revolution will not be motorized...especially at $5 per gallon.
    Quote Originally Posted by KONA_in_SB
    A gravity dropper is certainly a "luxury" item and I wouldn't buy one before getting a decent frame, fork or wheelset. But for me it's the next most useful upgrade. I'm fairly tall with long legs, so my optimum pedalling seat height is crap for descending. The GD solves this problem MUCH better than a QR seatpost clamp ever did.
    Quote Originally Posted by scrublover
    Ahh, I didn't realize that you can adjust it in combination with a seat clamp. Don't get me wrong defenders of the GD, I like the concept of the thing but the price seems ridiculous, how much does the version that you have cost scrub?
    The price put me off for a long time, but I don't regret biting the bullet after using it for a year. There's a slightly cheaper version without the remote switch, but it kind of defeats the whole point because you have to stop to use it. Your $5 QR starts looking better at that point! You'd become a very wealthy guy if you could produce one of these at a price close to a regular fixed seatpost, without sacrificing quality. That's were previous attempts at this kind of thing have gone wrong.
    Sorry, I didn't really you were so fabulously outfitted. OK, I'll bite. Here's one:
    http://www.jensonusa.com/store/produ...k+Release.aspx
    ROFL. Ahem, sorry about that.
    Assuming I'm supposed to discern all the parts you have from the list of your X5 build under your profile: It looks like a great ride, nice work. I could recommend a few upgrades though. You could upgrade one of those Mavic hubs for under $250. I don't see a headset listed, but you could get a King and have enough left over for a nice dinner. You could get the new XTR crankset for under $300, or the Saint for $175, depending if you consider strength or weight as the better upgrade. Hell, there's a lot of things, and it's your bike to do with whatever you want.
    The humble quick release is a simple, elegant piece of engineering. But some people prefer complex stuff that makes things very slightly easier, and will probably break sooner or later. Myself, I tend to go for the simpler solution whenever possible. I guess I could see the point of this contraption for racing, but besides that I'm going to have to call BS on the whole thing. GD's web site is shite, by the way.
    [QUOTE=BillyBob]Sorry, I didn't really you were so fabulously outfitted. OK, I'll bite. Here's one:
    for me, a GD would help my performance alot more that some exotic headset. i dont get off several times per ride to adjust my headset and dont lose any sleep over having headset that doesnt match the color scheme of my bike.
    I ran into this exact situation myself about a month ago...or part of it at least. Technically for XC your seat your be at the max extension for the perfect leg extension equation blah blah. Fact is, cornering goes to hell when your all jacked in the air like that. So to solve this I played around a bit......i ended up arriving at putting the top of the seat approximately at the bottom of the handlebar ( on my flat bars), so for you riser bar people it would be right about where the bottom of your grips are.....I gained an amazing ammount of control...and only lost a tiny bit ot pedaling torque...in fact after two rides my legs got used to pedaling in a slightly lower position. If your talking about jacking it way goofy like a downhiller does.....no way no how....they dont climb hills...they get a ride or take a lift.
    So all in all id say seat height should be equal to handlebar height...MAYBE a tiny bit lower...but not too low.
    8 is great
    Quote Originally Posted by washedup
    This is a robotic seatpost adjuster. Fairly exotic itself.
    I'm not serious about this, just ribbing the people who like these things. It's a crazy little gadget, you'll probably get a few wisecracks if you buy one. I certainly would expect to. And if it works out well for you, who cares, right?
    Takw/agranofsalt
    Jan 2005
    Everyone that I've talked to that's actually ridden a Gravity Dropper absolutely raves about them.
    Just my .02
    Give Larry at Mtn. High Cyclery a ring. Got mine through him, for very good prices.
    Stop to use it? What? You just reach down and pop the knob on the post. No stopping needed. Some sections of trail I'll slow down a little bit, but you certainly don't need to stop or get off the bike to use it. It really is stupid simple, using the thing.
    I replaced both my QR clamps with allen bolt setups. If you ever have a time you want the seat lower than 4", yep, just loosen the clamp and lower the post like any other post.
    The only time I've done that so far has been while riding the lifts on the bullit clone, up at Keystone and Vail. Otherwise, a 4' drop has worked on both bikes incredibly well.
    No one is saying everyone has to rush right out and buy one, but don't knock them so hard if you haven't tried them.
    never ender
    Reputation: fat_weasel's Avatar
    Jan 2005
    Man, this thread really took off.
    Might as well have my say- I rarely raise or lower my seat, but that's because my main bike (Heckler, baby!) descends and climbs well with the seat at a range of heights. A lower seat height takes some strain off my knees on seated climbs, and helps me get behind on descents, so I actually have it both ways. I usually set the post so I have a decent bend in my knee and leave it there. Sometimes if I have a really long climb I'll jack it up all the way, but usually the only reason I mess with it at all is to get my bike in the back of the Volvo.
    On the other hand, on my hardtail I'll slam the seat down all the way for technical descents, and then adjust it to a few different pedaling heights based on terrain.
    HIKE!
    Reputation: sparrow's Avatar
    Gravity Dropper
    Gravity Dropper seatpost. www.gravitydropper.com most shops have demos, try before you buy. The perfect answer to your original post.
    [QUOTE=washedup]
    Why would I want to upgrade my Mavic hubs? My Crossmax XL wheelset is fine.
    I've got a Blackspire headset, again works just fine.
    XTR or Saint crankset? What are either of those going to do for me that my XT doesn't?
    Sorry, I get a real benefit from my GD that I notice on every single ride. If I'd spent the money on a XTR crankset instead, I wouldn't have noticed a blind bit of difference.
    Jun 2005
    It has been my experience that the longer you ride and the better you get, the less you will worry with dropping your seat. Pure shuttle runs-yes, Pure stunt riding-yes, but all around trail riding- No. With the exception of big drops, if you know how to ride you can get your rear back over the seat when the need arrises.
    Quote Originally Posted by ChipV
    Yeah, but it's never a good position with the seat stuck in your stomach. You always end up too far back off the bike. Might be ok if you have short legs, but for me the seat is way too high in the optimum pedalling position and right in the way of where I want to be on downhills. There's no argument that a lowered seat is better for the DH parts of the trail, even for railing fast corners on singletrack. Hence the GD on my bike.
    Am I the only reader here that uses a Hite Rite seat post spring? It's cheap and works great for scary downhill blasts. I've had one on my vintage Fisher HooKooEKoo for almost 20 years. It also keeps dirtbags from loosening the seat post quick release and stealing your saddle.
    http://www.bikepro.com/arch_products...ts/ahiter.html
    Just another FOC'er
    Jun 2005
    I don't know man. I'm always riding off little rollers on the trail (like the attached pic of me on my Bullit), or coming across a jump, and unless my seat is quite a ways down I'm just not comfortable with it. You just can't get your CG low enough.
    As a rider with mediocre technical riding skills, dropping my seat (I drop it 2 or 3 inches) gives me the control and confidence (probably the most important part) to do some really steep technical stuff. So far I have been leaving it up on most trails and only drop it on the real technical trails. I don't usually do too many miles on the technical trails so I just leave it low for the entire ride, standing up a little more frequently helps but if you are used to long rides with the seat raised it's hard to get out of the habit of sitting all the time. My bike does not have a quick release seat clamp (and the seat clamp is kind of integrated with the brake system so I don't think I can just get a quick release) so I have to bring an allen wrench with to adjust it. I have to say the gravitydropper seems like a nice solution and I am considering getting one but I'm struggling with the price tag. I read the reviews on MTBR and almost everyone that has one seems to love it.
    My buddy has a friend who used to do this. One time, he hit a big bump at high speed, causing his butt to slam against the rear wheel, which thrusts him forward so his family jewels get rammed into the caliper brakes. They had to remove the wheel and take apart the caliper to free his pride and joy
    Don't know about you, but I'd much rather pay $250 to avoid this.
    Dec 2005
    Quote Originally Posted by Good Grief
    LOL ! That's a beauty
    Not sure we needed to know that and please don't post any photos. Did you ever think that the "big bump" story was made up to cover up for an accident that actually occured as a result of someone really really liking their bike?
    I don't know that a GD seatpost would have prevented that. Good argument for a rack though.
    Vaginatarian
    I dont know, climbing and flatter straights I like my seat up, tight and twisty , I like it about an inch lower. Can I ride with the seat all up or all down ? sure but if I keep it down an inch my knees start to hurt after an hour or so. so I can stop and fiddle around resetting the height or I can flip my thumb and drop my gravity dropper while riding
    Have Cake and beat it 2
    Reputation: AusMTB Orienteer's Avatar
    I agree Trailville. after reading the reviews I am considering having a chat to my LBS about it and see what they say
    Old man on a bike
    Quote Originally Posted by CharlesC
    You still ordering from bikepro too? Seriously, the hite rite should have come back out when the GD came out. Wonder if it's tied up in a legal dispute or something?
    I did get a Gravity Dropper after hearing some very nice things from some riders I know and admire. It's great. I can be at optimal height with no fooling around (like I did when I'd stop and fiddle with a qr). I can be at 1" down for rollers or twisties and still pedal well. I can drop it 3" for the really steep stuff. And go back and forth as needed without even slowing down. At one point I used a fixed position with no qr. After I started doing steeper and rougher stuff, I did get a qr to allow options, but I used to not bother a lot dropping the seat, unless it was a long dh. The GD gives you options (and you can customize the drops).
    OTOH the Maverick is coming out with a remote in the near future (saw the prototypes in use up at the D'ville Classic). GD has an improved model called the Turbo which doesn't require you to weight/unweight the seat as the model I've got does. I met some guys who developed their own version of a remote dropping post a couple months ago. Can't believe the hite-rite wouldn't do well again...
    suum quique
    Quote Originally Posted by .Danno.
    Agreed. For certain terrain, you can get away with not lowering your seat, but anyone who doesn't lower it for semi-agressive lines is asking for an endo. I've seen riders who never lower their seats crash too many times to count... The funniest thing to me is that even AFTER a crash, many people are reluctant to drop their seats--they just start walking when the going gets tough.
    I'm sure I would use the heck out of a GD/Speedball, and I'll probably get one eventually. In the meantime, I would rather spend my $$ on a new frame/fork/brakes than a trick seatpost. Besides, adjusting my saddle height at the top of a long climb gives me a good chance to catch my breath!
    Yeah, I think that's a sensible approach. No way would I buy a GD in front of a better frame, fork, wheels or brakes. But after those major items are sorted it's right up there on my "must have" list. Well in front of carbon bars, XTR / X0 level drivetrains etc. My GD sees loads of action on every ride and there's no way I'd ever take it off the bike.
    Some Assembly Required
    Reputation: man w/ one hand's Avatar
    I finally found a "happy medium" a few yrs ago that allows me to pedal up short climbs, (less than 10-15mins), and jump/drop stuff up to 4-5ft., decend relatively steep dh w/o raisin'/lower'n my seat on my Bullit, (black). It took a while for my legs to build up to the position. Meaning I had to start off slow w/the climbing. Having your seat too low when you climb can be hazardous to your knees. But after my knees had "developed" I have been able to really sit back and climb for an hr at a time w/no probs. Steep & long ascents, I'll raise my seat 2-3in.for better pedlin' geometry. However longer climbs can tend to "get to my back". I attribute most of that to the change in position of my heavy Camelbak due to the seat hgt., that & 26-36t chainrings. I guess I'm a lil overkill in what I carry but better safe than sorry. I can handle it.
    "Why are you willing to take so much & leave others in need...just because you can?"
  67. #67
    Dec 2004
    short climbs
    We don't have any 15 minute climbs where I ride. 5 minutes tops, which drives me to the same aforementioned "happy medium" position. All day long it's up a hill down a hill, maybe 60 times over.
    I continue to debate the GD for my riding, as I can see where it will make a quick jump in my technical capability. But, I ditched the bar-mounted remote lockout for the front fork because I got tired of having something else to think about constantly. (And I forgot to unlock it a lot too) I'd rather do a better job at shifting and steering at this point.
  68. #68
    Quote Originally Posted by heavyg
    Yeah, I can't see havin' more to deal with on th' h-bars. More than 1 guy rides w/us w/forks that lock-out & they're constantly gettin' to the btm of a dh run & realizing they have ridden it w/ their fork locked-out & feeling sketchy th' whole time. When trails are up-n-down its better to find th' happy spot & worry more about yer skillz like you said. I'm-widd-u-on-this. Everytime I'm on a trail that does make me raise/lower my seat, (maybe 2-3 times a month), it takes a lil while for me to get acclimated to th' new position, cause I do more riding at my "happy medium position". My daily ride is verryy up-n-down. So I'm used to it.
  69. #69
    Jun 2005
    LOL, that looks alot like the Wall of Death in Sedona...awesome line. Funny thing, I notice you are in a full face and body armor in that pic? When I don a full face and body armor, typically that means shuttle or stunt riding; not an everyday trail ride and, like you, I lower my seat for that stuff.
    I suppose it's a matter of perspective, but I ride the majority of everything with my seat in the same position. Sure, there is an advantage to lower the seat on stunts & DH's & I sure do it on occasion, but for the majority of trails (especially around here)I don't really find it necessary. Even when out west, the only time I saw anyone in my group (and that included a pro DH'r and several guys of equal skill) lower their seat was after we reached the top of Eldin and where about to come down. Everything else, we rode with the seat at one height- and that included up to 5 ft drops, vertical ledges, you name it....I couldn't count the times I've had the seat in my chest and thankd God for disk brakes. But, we were logging 50+ miles in a day and, quite simply, if you stopped to lower your seat you were playing catch up.
    A play ride? Hell yea, don the armor & f/face and drop the seat for some fun! Apples and oranges, though.
  70. #70
    Reputation: dcairns's Avatar
    Mar 2006
    Gravity Dropper. It is like a gear shift for your seat.
    Hiking and biking to get away from man's madness and enjoy God's creation for a bit.
    -Dave
  71. #71
    Just another FOC'er
    Jun 2005
    Yeah, I am playing around a bit posting that pic. No full face, but I do have arm and leg pads. No shuttle either for that trail.
    Here's a better pic of me on that drop - bigger bike, full armor. It's a cool roller, and actually very easy. There is other stuff in that area is not.
    It's in SoCal.
  72. #72
    Jun 2005
    It's in SoCal.
    Nice pic. I used to live in San Diego and did alot of riding around that area- some really fun stuff. That roller looks like alot of fun, and I know from experience that you are dead on about there being harder lines. I left my fair share of flesh on SoCal trails.
    But, you have to admit that there is a difference between going out in body armor and a full-face and going on a trail ride. If you don that stuff, it is with a certain type of ride in mind. If you are just sporting the baggies and an XC lid it is with another. You would no more log 40 miles in a armor than you would race DH in lycra...different tools for different jobs.
    That's my point with raising and lowering the seat, too. Sure, there are times you will crank up the height- like a ten mile grind up a mountain, and times you will drop it- like the screaming descent you just earned by that climb or when you are donning the armor. But, the idea of lowering the seat everytime you get to a technical area on a trail ride is ludicrous. In fact, one of the best pure tech rider I have ever met (who happnes to live in Chula Vista, by the way) never touches his seat binder..and if you stop to touch yours you will be playing catch up because they will be GONE.
    On the other hand, a gravity dropper type post makes things a little different, though, becuase it makes it so there is no reason NOT to drop the seat. You don't have to stop, get off the bike, remember where your settings are- you push a button and your done. Heck, why NOT lower the seat? It would be great for an AM bike. My only beef with those is the price ('cause I'm poor).
  73. #73
    Sure, let's open the armor discussion here too...
    Since I ride in a full face with armor 100% of the time, does that mean I've earned the right to ride with my seat down all the time too? Seriously though, the only times I DON'T have armor and a full face on my body is on long climbs and at that point, they are on my camelbak (and my seat is actually raised).
    There are enough fun spots on most of the local trails that I would rather just wear the stuff all the time and not worry about dressing up for each little gnarly section (talk about getting left behind for stopping to raise your seat--it takes minutes to don armor). The same goes for my seat--I just keep it low. It's all about the terrain your riding and your personal riding style.
    The bottom line here is: do what is fun for you on the trail you are on. If you can get more enjoyment by dropping the seat and cleaning a gnarly section than walking it, do it! If raising your seat for a climb makes you get to the top faster and more efficiently, do it! If you can afford a height adjusting seatpost, do it! Just make sure you are not pigeon holeing your style by NOT dropping your seat (or raising it for that matter). Both positions have their place on most trails.
    Now someone needs to invent a "Gravity Dropper" that will automatically put your armor on for you at the top of the climb....
  74. #74
    Just another FOC'er
    Jun 2005
    I guess it depends a lot on who your riding buddies are. Sure we'll race on the uphill, but when we get to the top we'll usually BS a bit, drop the seats, and have some fun on the down. We also usually pick the hardest way down to get the best payback for the climb
    I understand what you're saying though, but it's just not the way I tend to ride. It's a different kind of fun.
    If I had a GD, it would mainly be used when I'm riding solo. In that case I usually like to just keep on moving.
  75. #75
    3 solutions
    1. Gravity dropper mentioned above
    2. Maveric's version
    3. Actually learning to raise and lower you QR-ed seatpost while riding, easier than it sounds, using my Heckler and a nice big levered QR. Raising the seatpost is done by hugging it with the interior aspect of ones thigh
  76. #76
    Quote Originally Posted by HENRI8
    LOL, No. 3 sounds like a recipe for a few large shunts
