View Poll Results: do you use a masterlink or a chain cutter
Voters
100. You may not vote on this poll
  • masterlink
    90 90.00%
  • chain cutter
    10 10.00%
Page 2 of 2 FirstFirst 1 2
Results 26 to 36 of 36
  1. #26
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by dirtyknobbies View Post
    Yeah if you're running 10spd doesn't matter..are no master links anymore...so guess your poll is obsolete.
    You are still using the wrong term, and there are quick connect links for 10-speed chains, though some are not suppose to be reused.
    mtbtires.com
  2. #27
    Reputation: nauc's Avatar
    is there any other kind of quick connects besides these, and the ones found on single speeds
    2010 GT Avalanche Expert
  3. #28
    Reputation: Haus Boss's Avatar
    Jun 2010
    My fingers hurt just thinking about a masterlink- I hate those things.
  4. #29
    Sep 2012
    masterlink
    i guess it actually depends upon the use. A master link or quick-release link is a bicycle chain accessory that allows convenient removal and reconnection of an installed bicycle chain without the need for a chain tool.
  5. #30
    Destroyer Of Tires
    Reputation: bear's Avatar
    Quote Originally Posted by ban View Post
    is there any quick link that works with a 10spd SRAM chain??
    The PowerLock connector that comes with the sram 10spd chains is reusable...I know sram doesn't say it is, but you can reopen it with a pair of pliers, it's just not as hand-friendly as the 9 spd version.
    I plan on using one on the next shimano chain I use.
  6. #31
    dwt
    dwt is offline
    Reputation: dwt's Avatar
    Highly recommend IRD Snaplink. Works with Shimano, SRAM, KMC 10 speed. 9 speed version also available. Smooth and easy on and off, without tools. Cleaning lubing dirty link with WD40 recommended prior to removal
    http://store.interlocracing.com/10snli.html
    Old enough to know better. And old enough not to care. Best age to be.
  7. #32
    Reputation: Wombat's Avatar
    And I found that if you (mistakenly) mix half a 9 and half an 8 speed SRAM connector they still work very well on an 9 speed chain.
    Tim
  8. #33
    Mar 2012
    As a youngster pro bike mechanic, and as a result; broke, I would save the left over links from new chain installs. Late at night my bong and I would stitch these bits-and-pieces into whole chains for my own bike. Never broke one, never paid for one.
  9. #34
    Nov 2012
    well, like most i use a masterlink more often and also keeps a chain cutter in case of some urgent use.
  10. #35
    Reputation: playdead's Avatar
    both, but if i had to go with one I would go with the chain tool.
    "Bound to cover just a little more ground"
  11. #36
    Nov 2012
    Yes I always use Chain Cutter.
Hot Deals
Contests
Latest Mountain Bike Articles
