Results 1 to 9 of 9
    May 2013
    derailleur question
    I have a Cannondale 2004 scalpel xc 2000 race, I'm looking to change the rear derailleur because the xtr is damaged. What other brands kind do you recommend. I was looking at SRAM but have no clue what model to get. I know the original is an xtr but that's it, is it a short,long, medium cage. Thanks for your help. I'm looking to order the parts I need, all new cables, tires, grips and such then take it to a shop to install and tune. Again thanks for your help
    Jun 2012
    Quote Originally Posted by JJamez1 View Post
    You're better off to stay with Shimano or you'll have to change your shifter too, not just the derailleur. If you still have three gears up front you'll need a long cage derailleur.
    Reputation: MSU Alum's Avatar
    Regardless of the brand, get the model with a clutch. I have the Shadow + and really love it. For SRAM I think it's the Type 2.
    May 2013
    Thanks I'll look into the shadow plus. So long cage with a clutch.
    May 2013
    Shimano XTR Shadow Plus RD-M986 Rear Derailleur, will this work?
    Reputation: shiggy's Avatar
    Dec 1998
    derailleur question
    The clutched RDs are 10-sp only. With a 2004 bike basically the whole drivetrain will need to be replaced.
    mtbtires.com
    May 2013
    What would be the new model version of the oem derailleur? Thanks
    Jun 2012
    No need to spend up big replacing the whole driveline on a bike not worth that much. Something like this will do the job:
    Shimano Deore M591 9 Speed Rear Mech | Buy Online | ChainReactionCycles.com
    May 2013
    Thanks for the info. I appreciate it.
  1. SL-R Front Derailleur Question
    By slurms mckenzie in forum Ibis
    Last Post: 11-22-2012, 11:25 PM
  2. Derailleur question
    By jfo9 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-10-2012, 03:58 PM
  3. Derailleur Question
    By ivanovnv in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-24-2012, 07:54 AM
  4. Question on which derailleur I would need.
    By nattyboh74 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-12-2011, 10:06 PM
  5. Derailleur Question
    By Ultimate G in forum Beginner's Corner
    Last Post: 10-11-2011, 07:58 AM
