Results 1 to 3 of 3
    Did I catch a niner+?
    New question here. Dakine Drafter winter use
    So I got a Dakine Drafter Flanel (SICK!) on Chainlove for 31.50 (YAY!!!!) and am happy to have a larger pack vs my CB Classic. Well anyways I snowboard in the winter and it can get pretty cold here in MN. So I was curious if anyone used this pack in the winter? And if they can recommend a thermal hose for it? I understand it has a thermal lining around the bladder itself, but it can get pretty damn cold up here.
    pink
    pink
    Reputation: runawaymachine's Avatar
    I have an older Drafter that I use year round. If I want to keep water from freezing it needs to be under my jacket, that's the only way. If the temp dips below zero then I use a Dakine insulating sleave and a hose and valve cover, plus keep it under my jacket. Usually I just keep the bladder inside a space blanket folded to size. You should have a space blanket with you anyway... Right? C'mon their $3 and can save your life.
